Wanted 900 Seca oil pump cover
Discussion in 'For Sale, Trade/Swap, Wanted' started by Andrew Nichols, Aug 6, 2021.
Tags:
  1. Andrew Nichols
    Andrew Nichols Active Member
    Minneapolis, MN
    Parts diagram lists it as
    22N-15416-01-00. Does anyone know if one from a different bike would fit?[​IMG]
    Thanks!
  2. chacal
    I'm pretty sure that the 1983-84 XJ750 Midnight Maxim pump covers (NOTE: the MIDNIGHT maxim covers only! The standard 1982-83 XJ750 Maxim covers are different) and the 1984 XJ750RL Seca covers are the same physical size/shape covers, but will differ in finish and emblem type (YICS vs. DOHC badges). Your pictured 1983 XJ900RK should use the cover with the YICS emblem, bright polished finish, black-painted Y A M A H A wording.
    We have brand new left or right covers, with either the YICS or the DOHC emblems, but they aren't cheap.
    We also have the YICS or the DOHC badges (only) available if you are just trying to restore an older cover.
  3. Andrew Nichols
    Minneapolis, MN
    Thanks Chacal, it doesn't have to be historically accurate, I've already moved the better one off of this bike onto another 900 Seca. As long as it doesn't say Suzuki I'm ok with that. The one that I have is cracked but I'd rather fix it with JB Weld than pay $180 for another one...
  4. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    They are a tad brittle, and usually when you think you have a dented one, in reality it is usually cracked as well. But you can tig weld and dress them. Find someone in your are that welds Ali, shouldn't cost you much - like $20 bucks?
  5. hogfiddles
    Andrew, I’ll see if I have any floating around
  6. Andrew Nichols
    Minneapolis, MN
    Țhanks, yes, it's cracked but I didn't think it was weldable. If Hogfiddles doesn't have one I might have to go that route.
  7. XJ550H
    are you talking about the filter cover?
    I have one on a parts bike.
    i
  8. Andrew Nichols
    Minneapolis, MN
    This is the part in looking for. Previous owner used a half tube of gasket material...
  9. XJ550H
    ok crank cover,
    just a note the other xj covers fir properly
    I will look at the ones I have if hoggfiddles cant help you
    I think the plastic on my left side is broken but the logo cover is good sounds like that may solve your issue.
    i will look at them shortly
  10. chacal
    I may be wrong....and the Fiddles can correct me here if I am.....but I don't believe that all of the "other" round pump covers (like on XJ550, XJ650, XJ700, etc.) covers will actually work on a 900 engine....the design and shape of the cover is different, the models that I mentioned above use a very shallow, "edgeless" cover which doesn't even have bolt "holes" in it. The 900 (and others noted prior) use a very shallow cover and a separate supporting structure, whereas the XJ550 etc. covers have the support structure and the "dish" all integrated as one structure. While it may be possible to use a 550 (etc.) cover on a 900 engine, you'd have to do away with the support structure, the rubber ring, and the lock plate.......and even then, I'm not sure that they'd fit, and even if they did, they might look very odd.
    Hog, let us know!
  11. Andrew Nichols
    Minneapolis, MN
    The silvery part is broken but the piece that it's fastened to from the back is ok. You can see the backplate sandwiched between the silver piece and the block. I'llrage a picture of the back when I get home.
  12. XJ550H
    I ment to use the whole cover they do fit,
  13. XJ550H
    this is the one i have unbroken needs cleaning
    left side
  14. Andrew Nichols
    Minneapolis, MN
    Thank you everybody for your assistance, XJ550H has a part for me.
    This is a very helpful community!
  15. XJ550H
    we try, Its nice to see an XJ get some more rider time
  16. Andrew Nichols
    Minneapolis, MN
    This is my current commuter bike, an 83 900 Seca that I painted to look like the Canadian version. I have 3 other 900 Secas and I think Dave probably has 10 of them...
  17. Andrew Nichols
    Minneapolis, MN
    chacal likes this.
  18. XJ550H
    I like the Canadian paint job seems like it went to the wrong location though maybe that's just me
    chacal likes this.
  19. Andrew Nichols
    Minneapolis, MN
    That was my 1st 900 and I didn't know much about them at the time but it's always liked the 1980s Honda Interceptors and at the time the red hadn't grown on me yet. It came to me as a redneck Midnight Special but I transformed it using good 'ol Rustoleum (see attached before/after picture). The dark blue seat and blue windscreen are my ?artistic touches. Polish_20201112_075149942.jpg
  20. Andrew Nichols
    Minneapolis, MN
    Here's the one that I'm replacing. I think the black base is reusable. 20210807_225740.jpg 20210807_225740.jpg
  21. Fuller56
    Fuller56 Well-Known Member
    Are these covers generic to the XJ engines? I will check the pile of retired parts and see if there is one from a long since gone 650 and get back to you. Do you want the "YICS" cover or a plain one?
  22. Andrew Nichols
    Minneapolis, MN
    Hi Fuller. Thank you but XJ550H has already found one for me. Apparently there are only a couple of models that this part is interchangeable with (see Chacal's response).
  23. hogfiddles
    I believe that is correct. The midnight ones are finished in black. I THINK THE 750rl ones are brushed aluminum, not bright like the 900, but not positive on that.....
    I think I have a midnight 750 one to compare, and I’ll see about others fitting just for fitting’s sake
  24. XJ550H
    yes they all cross fit from the 550 650 750 900 , the 650 has plain covers for the non yics which are nice for those who want to etch or paint some design to the cover.
    the 900 cover has a plastic base rim with an alumninm face cover.
  25. Andrew Nichols
    Minneapolis, MN
    So, only the 900 has the plastic base and the discs that attach to them are somewhat interchangeable?
  26. hogfiddles
    The disc is interchangeable between just the 900 and the midnight.... probably the 750rl but I don’t have one to verify
  27. chacal
    Correct, and the 750RL uses it, too.
  28. XJ550H
    the other covers can be used as complete covers .
