A few questions from a first time Rebuilder
Discussion in 'XJ Technical Chat' started by Adam Walker, May 28, 2015.
  1. Adam Walker
    Adam Walker Member
    United States
    the length is my major problem finding
  2. Adam Walker
    Adam Walker Member
    United States
    taking apart my forks last night.. one of the spring caps won't budge.. i layered on some liquid wrench and let it sit over night.. still not a budge.. any ideas?
  3. k-moe
    Spray with Kroil or PB Blaster. Give the plug a good rap with a hammer and dowel. Repeat daily until it frees up. Liquid wrench is a fine light machine and cutting oil, but it's not going to penetrate much.
  4. Adam Walker
    Adam Walker Member
    United States
    nvm i got it.. elbow grease
  5. Adam Walker
    Adam Walker Member
    United States
    ohh thanks!
  6. Adam Walker
    Adam Walker Member
    United States
  7. Polock
    I used engine enamel for cars on all but the head. It worked. Look at Eastwood.com
    The head gets kind of hot, remember cars and boats are water cooled.
  8. Adam Walker
    Adam Walker Member
    United States
    Yup, i just found some info saying it was rated to 200 degrees.. something like the VHT brand engine enamel rated to 550 degrees would be good for any engine part including head right? I don't see it getting near that hot
  9. Adam Walker
    Adam Walker Member
    United States
    nvm.. just saw it says in description, will not stand up to cylinder head temperatures... what wold be the best choice for cylinder head paint then?
  10. Adam Walker
    Adam Walker Member
    United States
    Would the VHT flame proof paint work? i see it used on exhaust manifolds, but not the actual head in any of the pictures or descriptions i am seeing.
  11. Polock
    I think 550 would be good on a head.
    Pipes get the hottest more than 550
  12. Adam Walker
    Adam Walker Member
    United States
    I have made some super progress.. i'll share it with ya'll when i have time to sit down and go through pictures, but right meow.. I'm having an issue...
    I am installing the cylinder head and camshafts following the clymer manual..
    i have the crank position at #1TDC as specified..
    I also have the camshafts lined up correctly in the head with the bearing caps torqued to spec in proper positions
    my next step is to install a sprocket bolt in each sprocket, however, these caps are in the way.
    These caps that are in the way look like they aren't actually contacting the camshafts, so i was wondering if my best course of action would be to remove them, insert a sprocket bolt, and then reinstall them, but I'm not sure if that would have an effect on anything else in the valve train..
    any suggestions? it's an 81 550 maxim
  13. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Yes, but don't install them until both bolts are in.
    It won't. Hope this helps.
    Gary H.
  14. Adam Walker
    Adam Walker Member
    United States
    it does... thank you so so much
    back to it!!!!!!!!!!!!!!!!!!!!!!!!!!
  15. Adam Walker
    Adam Walker Member
    United States
    here's a glimpse of the progress...
    i have new rear shocks, which are mostly black, i just haven't assembled them yet.. threw the tank, seat, and old shocks on just to get an idea of if my color scheme was working.. i think it is!
    anyone know which sizes fork boots work the best on these forks? all the pairs i've found are just a little off from my measurements, or the kind that have like 100 accordion folds.. i'm looking for the kind that have like 5-6 folds.. like so
    also, anyone know the cable routing for the 81 550 maxim? i lost my notes from tear-down..
  16. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Noice! You switched the back tire and fender for a pair of legs and a tail! Very unique!
  17. Adam Walker
    Adam Walker Member
    United States
    You noticed... it's the AllBalls Boxer/Lab kit!
    BigT likes this.
  18. Adam Walker
    Adam Walker Member
    United States
    another glimpse of progress...
    rocs82650 likes this.
  19. Adam Walker
    Adam Walker Member
    United States
    More progress...
    So close.. drain plug stripped out, new(used) one on the way. Then I can fill er up and put the exhaust on.. starting carbs tomorrow.. tank cleaning and sealing also..
    My last (hopefully) mechanical issue, is that I am missing my drive sprocket collar.. the sprocket has quite a bit of rattle without it and I can't find one anywhere.. I am hoping someone that reads this either knows where one can be located, or has the dimensions/can measure one for me so I can make one..
    Was also wondering if someone could give me a diagram, however crude, of the throttle and clutch cable routing..
    I don't think I would be this close to done without you guys and my appreciation cannot be described in any written language..
