A little help please
Discussion in 'XJ Technical Chat' started by Rusky39, Sep 1, 2008.
  1. Rusky39
    Rusky39 New Member
    the tail light on my 85 maxim X700 has stopped working brake lights still work and a quick look shows both bulbs all ok HELP
  2. schmuckaholic
    California
    It could be as simple as a burned-out filament; just because it looks okay doesn't mean it is. ("Occam's Razor", doncha know.) Perhaps later I can go out and look at mine to see how it can be determined with a multimeter if it's the filament or the electrical system.
    If it is indeed the bulb, stop by Chacal's Wonderful World of Bulbs and pick yourself up a...
    HCP7570 Aftermarket dual-filament tail light - brake light BULBS. Fits all XJ550, XJ650, XJ700, XJ750, XJ900RK, and XJ1100 models. NOTE: these bulbs are also used in the XJ700 and XJ1100 models for the front turn signals.
    Each: $ 2.50
  3. Rusky39
    Rusky39 New Member
    bulbs ok check fuses ok it seem to be ig switch it was a little lose managed to wedge for tomorrow but how is it held in what needs to come off to chek mountings
  4. schmuckaholic
    California
    Mrmph. Good question -- I don't know.
    You might want to consider hopping over to this site and send mail to the webmaster. If he doesn't know, I'm sure he can find somebody who can.
    I remember having the same thing happen to my last bike, a Kawasaki KZ750 CSR. I ended up wiggling the key in the ignition, and it lit back up. The bike before that (Hondamatic 450), the headlight failed and I ended up replacing the ignition switch itself.
