A serious look into custom Middle Gear Ratio
Discussion in 'XJ Modifications' started by skylrk62, Aug 25, 2017.
  1. Polock
    just out of curiosity, what do you think the driven gear with external and internal teeth will cost ?
  2. skylrk62
    skylrk62 Active Member
    Illinois
    Easily into the 4 figures. I'll know hopefully soon
  3. skylrk62
    Illinois
    got my plastic mock gears in. I'll be making the middle gear tomorrow. here is a taste.
    Kickaha likes this.
  4. chacal
    I don't like that last image...........
  5. Kickaha
    New Zealand
    It'll wear down after a few KM and give itself some clearance
    Ross B. likes this.
  6. k-moe
    Easy fix though; cut a bevel on that side of the gear.
    XJ550H likes this.
  7. XJ550H
    do not forget about heat expansion.
    desmotom likes this.
  8. skylrk62
    Illinois
    Sorry for the delay on the update. I had been searching for a company that could do this with a feasible budget. I knew this was going to be a pricey part, so I set aside around $2,500. I could not find one company that would touch it for under $4,500! I've dug deep into my pockets for this build, but that's just too deep for me. On the positive note, we know that this mod is possible. Maybe someday, if this build turns out like I hope, I'll look into this again.
  9. k-moe
    Look into just the cost of having the gear heat-treated. If you have access to a lathe with an indexable headstock, you can cut the gear yourself.
  10. desmotom
    desmotom Active Member
    Canada MB
    send me the gear specs, see what I can do.
    Ross B. likes this.
  11. vashtsdaytona
    vashtsdaytona Active Member
    Fargo
    did anything come of this?
  12. XJ550H
    nope cost 4500 for the first piece
