Add USB port.
Discussion in 'XJ Modifications' started by xjyamaha, Jan 30, 2020.
  1. xjyamaha
    xjyamaha Member
    Omaha, NE
    Anyone added a USB port to their bike? My bike has the storage boxes on each side of the frame underneath the grip and I wonder what's the best line to splice into if adding a USB port.
  2. raskal
    raskal Active Member
    Abbotsford B.C. Canada
    My 750 Maxim has the auxiliary light with it's own switch. I disconnect the light, jumper in some wires and connect it to a 12v USB socket
    I like it cause I don't have to cut anything and I have a switch to turn it off if I want.
    I never use the aux light anyways
  3. xjyamaha
    xjyamaha Member
    Omaha, NE
    Ah, sounds like a good option. Unfortunately I don't have the ability to turn on/off auxiliary lights.
  4. Timbox
  5. mlew
    mlew Well-Known Member
    Apex, NC
    I used the same one as Timbox. Mounted in the saddle bag and wired directly to the battery. Turn it off when not in use .
