Advice on tool
Discussion in 'Hangout Lounge' started by saftie, Apr 7, 2019.
  1. saftie
    New York, NY
    Hey there,
    Bummer, I just found out that the shims on my bike do not have any sizes stamped onto them.
    Now I need a good and reliable tool to measure shim thickness. I don't even know what it's called: caliper, micrometer? Both the same?
    Any suggestions? Self explanatory that it has to be accurate measuring small thicknesses.
    Digital would be ideal and way easier.
    G
  2. Franz
    Best using a micrometer that is what I have. With a micrometer you can measure the centre of the shim where the cam lobe is bearing. A vernier caliper will measure across the shim the micrometer allows you to measure the centre as stated.
  3. saftie
    New York, NY
    Thanks.
    Looking for good brand/model that people have good experience with, or which to stay away from
  4. Franz
  5. saftie
    New York, NY
    Awesome, thank you
    Franz likes this.
  6. XJ550H
    get one new shim that you know the size of and use it as a standard to test device. shim sizes are not dead on to the stamped size. closest shims to marked size are oem shims and BMW shims
    saftie and Franz like this.
  7. Polock
    go to harbor freight and get a 6 inch caliper, it's more accurate than you need to be for $15 bucks
    vashtsdaytona likes this.
  8. kosel
    MInneapolis, MN
  9. saftie
    New York, NY
    Thanks guys.
    I ordered one. I actually use my caliper a lot so upgrading to digital will be nice. Well, that and the fact that I can finally finish the valve clearance job soon.
