Aftermarket Exhaust Suggestions - No re-jetting Required
Discussion in 'XJ Modifications' started by Recordless, Mar 27, 2018.
  1. Recordless
    Recordless New Member
    Ontario
    Hey all,
    Does anyone have experience in aftermarket mufflers for an XJ 750 that will not require re-jetting? I'm currently set up on the stock 4-2. I'm looking to slap on two new mufflers.
    I tried a spare aftermarket 4-1 exhaust system (headers and muffler), however I could tell the engine wasn't running smoothly. After a day of riding I pulled a sparkplug and it looked dry AF. Went back to the stock 4-2 but I cant stand the look and its too quiet!
  2. Jetfixer
    MAC sells both a 4 into 2 exhaust as well as a 4 into 1 exhaust . Both systems have removable baffles . I'm running a MAC 4 into 2 system stock airbox with 124 jets ( stock is 120 main) I like it and has a good sound .
  3. Polock
    hd sportster mufflers are supposed to work
    NEEDtoRIDE likes this.
  4. Oldmansin
    Oldmansin Member
    Nc
    If you fart too close to the intake you need to rejet. These bikes carbs have very sensitive settings that need to be balanced
  5. Recordless
    Ontario
    Based on these responses, there is no clear cut muffler that's just an easy swap without the need to re-jet.
    Guess I'll have to wait until I'm ready to assess the fuel mixture when making the change.
  6. chacal
    In reality, if you only change the exhaust, re-jetting is not necessary.......the stock exhaust system flows about as well as any aftermarket system design.
    Re-jetting is almost always required when you free up airflow on the intake side of the cylinder head........that is where the restriction is (the airbox and paper pleated air filter element). Anything you do to free up flow thru the intake system is what really leads to the requirement to re-jet (i.e. more fuel is needed since more air can be flowed thru the system).
    One caveat though: most of these bikes (at least in the USA) were jetted pretty lean from the factory in order to meet EPA emission regs. You can always fiddle with the pilot mixture screw to richen up the pilot circuit some, but going up 1 size on both the main and pilot fuel jets isn't a bad idea even on purely stock bikes.
  7. Recordless
    Ontario
    Hmm, interesting @chacal .
    So in the event that I do re-jet the carb, for whatever reason (new intake, exhaust, or just the hell of it), do you have any links for a step by step backyard tune? Is it possible to diagnose your mixture and determine what - if any - adjustment is required.
    For example, if I'm running too lean how would I determine the proper jet size?
  8. chacal
    Best method for tuning the pilot fuel circuit is via the use of a "see-thru" Colortune spark plug:
    j5) Aftermarket Gunson COLORTUNE TUNING SPARK PLUG KIT....brand new, no display box, includes all accessories and instructions. If you really want to tune your multi-carbs to perfection, you'll have to use this unique "see-through" spark plug that allows you to view the combustion chamber flame color in real-time, thus allowing accurate (rather than guesswork) adjustments to your idle mixture screws. Use it once and you won't believe how you ever got by without it, and will pity those who don't have one of their own. Beware: you'll find that a lot of people now want to be your "friend" and have you come and tune on their bikes, once they find out you have a Colortune!
    Also, please note! you can find quite a few of these plugs at a discount at various places, but most of these places are selling an older, now-discontinued "automotive" version of the Gunson colortune plug. While there are no fitment differences between the automotive and "motorcycle" versions of these plugs, just be aware that the automotive versions were designed to be used in a water-cooled engine, and thus have a significantly lower heat tolerance----and if these plugs overheat, the "clear" window either goes cloudy or just simply fractures.
    NOTE: the proper use of the Colortune plug requires you to:
    a) have your valve clearances within spec,
    b) have the engine proper vacuum-synched,
    c) have the YICS chamber blanking tool installed (if it is a YICS engine),
    d) perform a re-synch of the engine after each cylinder is color-tuned. This colortune - synch - colortune - synch etc. iteration is necessary as any adjustments made to each cylinder (as determined by the results of the colortune operation) throws the engine out of synch.
    e) the above procedure is the only way to truly and properly "tune" a multi-carbed engine!
    The following video presentations, although definitely not Academy Award quality, show the Colortune Plug in action:
    http://www.gadgetjq.com/Vulcan_1500_Idle_Mixture_Test.wmv
    and
    http://www.gadgetjq.com/Vulcan_1500_Mixture_Test.wmv
    and here's a few more:
    going from orange (rich) to blue:
    showing the blue to orange to blue changes:
    showing a colortune being hooked up incorrectly (arcing):
    And here's a super-sized colortune plug, don't try this at home kids!:
    Please remember, though, that a Colortune is NOT used to set your carbs at anything other than idle rpm's!!
    HCP95C Aftermarket Gunson COLORTUNE TUNING SPARK PLUG KIT, for 14mm spark plugs. NOTE: NGK plugs that begin with the letter "B" are 14mm, and are used on all XJ650, XJ700 non-X, XJ750 non-X, XJ900RK, , RL, F, N, and FN models, XJ1100, and all XS1100 models.
    Although you can tune the pilot circuit by "ear/sound", it takes a bit of experience to do it properly and consistently. The main difficulty is that it can become an almost "endless loop" process, because each cylinder that you adjust throws off the other 3 cylinders, and so the process has to be repeated again, and again, and again......
    Of course, a proper running synch of the engine is just as important as the fuel mixture settings, so the best advice is to use a Colortune plug AND a 4-tube synch gauge simultaneously so that the "endless loop" of adjustments can be whittled back to just 1 or 2 iterations (and then it purrs like a sewing machine).
    Main fuel circuit tuning is typically accomplished by observing spark plug insulator colors after doing numerous "plug chops".....in effect, the spark plug insulator colors give you the same type of information as the colortune plug does, but in a more-difficult, much less easier manner.
    After that, there are also adjustments that can be made to main jet needle heights (shimming needles) and/or adjusting the fuel levels in the bowl (as the fuel levels have an effect on rich/lean conditions), but now you're getting into the realm of race-tuning, which you really need to just go find someone with a cycle dyno and plan to spend a bit of time trying out different configurations. And all of this is complete overkill for street-driven bike (unless you're the "can't sleep at night" kind of person who requires something akin to perfection in certain endeavors in your life).
    That's why most people choose the colortune/synchronization route and just follow these basic guidelines:
    WHAT ABOUT RE-JETTING FOR PODS, ETC?:
    Before we even start down this bumpy road, let's get this out of the way: changing the mufflers (only) will generally not require re-jetting, as the stock mufflers are pretty darn free-flowing as it is. The major airflow restrictions (by design) in these engines is on the INTAKE side (the airbox system and its pleated paper filter). Changing to a high-flow air filter (like a K&N) will definitely require increased fuel jet sizing.
    That being said, all of these bikes were jetted a bit lean from the factory, in order to satisfy EPA emissions requirements of that era. So even a stock engine can benefit from slightly larger fuel jets; for example, a stock XJ650 non-Turbo USA model, increasing fuel jet sizes to #112 on the mains (from the stock #110 size) and to a #41 on the pilot (stock is a #40 size) can be beneficial. Note that the pilot jet size is not as critical as the main jet size, since the pilot circuit mixture screw allows you to “open up” the pilot circuit independent of the jet size.
    But what about when you do make other intake/exhaust system changes? It's a question we get asked often and unfortunately, one that we cannot answer honestly about your specific bike besides with "it depends".
    Which is a nice way of saying "you're about to enter the seventh circle of hell......."!
    Carb jet tuning required by aftermarket modifications is somewhat of a black art, part science, part skill, part luck. It depends on the current state of tune of your engine, your altitude, the mix of aftermarket parts on your bike, etc........a lot of variables.
    The best advice we can offer is: Just Say No!. Don't do it! Leave everything stock!
    But, since most people---with good reason, I might add---don't always listen to our well-intentioned advice, then the next best recommendation we can offer is: "if you want more power get a bigger bike!".
    And since that doesn't cut it with many owners, either, for the remaining stalwarts out there who insist on "experimenting" with aftermarket intake and exhaust systems, here's the best information that we've come across to give you some GUIDANCE, which you should take as just that, and not as ANSWERS, because it isn't!
    Definitely not plug-and-play:
    https://www.youtube.com/watch?v=Vt6HtsggcqU
    And some pod filters make a difficult situation even worse.........read all about it:
    http://www.caferacer.net/forum/technical/19639-pod-filter-thread-geeto.html
    Yoji himself cautions against it:
    http://xjbikes.com/forums/index.php?attachments/mikuni-article-jpg.15101
    Also, if you’ve ever wondered what the numbers on your jets refer to:
    - on Hitachi fuel jets, the numbers refer to the actual physical size of the passage hole expressed in millimeters, i.e. a #114 fuel jets is 1.14mm in diameter, a #42 fuel jet is 0.42mm in diameter, etc.
    - on Mikuni fuel jets, the numbers are a measurement of the volume (cc’s of gasoline) that will flow thru the jet when poured in from a height of 50cm.
    - we do not know what air jet numbers refer to…….although we suspect it is a volume of air that can pass through the jet at some level of vacuum. Anyone who has insight into this issue please let us know more!
    MAIN FUEL JET SIZE CHANGES NEEDED PER TYPICAL MODIFICATION:
    Typical Exhaust Changes:
    +2 main fuel jet size for custom 4-into-2 exhaust
    or
    +4 main fuel jet sizes for 4-into-1 exhaust
    or
    +4 main jet sizes for no muffler (open headers)
    Typical Intake Changes:
    +2 main fuel jet sizes for single K&N filter (inside a stock airbox)
    or
    +2 main fuel jet size for drilling holes in the airbox with stock filter
    or
    +4 main fuel jet sizes for individual pod filters (no airbox)
    Additional changes:
    - Add up all the main fuel jet size increases and subtract 2 sizes.
    - Decrease main fuel jet size by 2 sizes per every 2000' above sea level.
    - Under a mis-match condition, such as when using pod filters with a 100% stock exhaust, or 4-into-1 header with stock filter and air box, then subtract 2 main fuel jet sizes.
    PILOT FUEL JET SIZES CHANGES NEEDED PER TYPICAL MODIFICATION:
    Pilot fuel jet size changes are related only to the change in main fuel jet sizes according to the main fuel jet size formula described above. Note that this pilot fuel jet rule is for the main fuel jet size change BEFORE any main fuel jet altitude compensation is factored in:
    Increase the pilot fuel jet size +1 for every +3 main fuel jet size increases.
    Additional changes:
    - Decrease pilot fuel jet size by 1 for every 6000' above sea level.
    PRECAUTIONS:
    - Make sure your carbs are in perfect working order before making ANY jet changes....meaning fully cleaned internally and rebuilt, operating properly in their stock configuration, proper sized air jets and needles, etc. Otherwise, you'll like find that all of your efforts are going to be a HUGE waste of time.
    - Check plug color often and adjust as needed, 2 main fuel jet sizes at a time and 1 pilot fuel jet size at a time. Bright white plug insulators are a sign of an overly lean fuel mixture condition and WILL cause damage to your engine over time, up to and including engine seizure!
    - Synch the carbs after each jet change.
    - Make sure the floats are set correctly
    - Seriously consider purchasing a Colortune Plug Tuning kit.
    - You may find it necessary to make changes to the size or shimming of the main jet needle. There are no guidelines on what or how to do these changes, this is true trial-and-error tuning!
    EXAMPLE:
    A 1982 XJ750RJ Seca using an aftermarket Supertrapp 4-into-1 exhaust and a single K&N air filter in the stock, unmodified airbox. Bike is primarily operated at an altitude of 2600 feet above sea level.
    XJ750 Seca Stock Hitachi HSC32 Carb Jetting:
    #120 Main Fuel Jet
    #40 Pilot Fuel Jet
    #50 Main Air Jet
    #225 Pilot Air Jet
    Y-13 Needle
    MAIN FUEL JET SIZE CALCULATIONS:
    Changes made:
    Exhaust:
    4 into 1 with Supertrapp = +4 Sizes Main Fuel Jet
    Intake:
    K&N Pod Filters = +4 sizes Main Fuel Jet
    Equals: +8 main fuel jet sizes above baseline
    Subtract: -2 main fuel jet size per formula above
    Equals: +6 main fuel jet sizes due to modifications, thus:
    Stock main fuel jet size is: #120
    + 6 additional sizes
    = a #126 main fuel jet size
    Subtract: -2 main fuel jet sizes for Altitude of 2500' Average
    = #126 calculated from above
    -2 jet sizes for altitude adjustment
    = a #124 main fuel jet size.
    PILOT FUEL JET SIZE CALCULATIONS:
    The formula is: +1 pilot jet size increase for every +3 main jet sizes increased.
    Stock pilot fuel jet size is: #40
    + 2 additional jet sizes (since we went up +6 main fuel jet sizes before the altitude compensation was factored in):
    = a #42 pilot fuel jet size.
    Note that no altitude compensation is needed on the pilot fuel jet since our elevation is less than 6000' a-s-l.
    RESULT:
    A #124 Main and #42 Pilot is A GOOD STARTING POINT.
    Note that the above calculations do NOT take into account any possible changes in the sizes of the main or pilot air jets, the main needle or main needle jet size, and thus are additional variables and opportunities for tuning excellence. These are areas which are largely unexplored by most tuners, but logically should allow for additional fine tuning or additional rage and frustration.........
    Normally, changing to an aftermarket exhaust does NOT require re-jetting, (or minimal re-jetting) as almost ALL of the airflow restriction in the airflow path thru the engine (meaning: ATMOSPHERE > AIRBOX > FILTER > AIRBOX BOOTS > CARBS > INTAKE MANIFOLDS > CYLINDER HEAD PASSAGES > EXHAUST SYSTEM > BACK OUT INTO THE ATMOSPHERE) is within the intake side of this air flow path, and primarily within the stock airbox/air filter. Your stock EXHAUST system can already flow more air volume than the stock INTAKE system allows.
    Thus changing only the stock EXHAUST system, with no changes to the intake side of the heads, normally makes NO DIFFERENCE IN TOTAL AIRFLOW, and "no difference in total airflow" means "no difference in TOTAL FUEL FLOW" either, and thus bigger jets are not needed.
    But once you start freeing up the INTAKE side of the entire system, you will produce more system airflow, even with a stock exhaust system (because, the stock exhaust system has the capability to flow more air through it than what the stock intake system allows).
    This is why re-jetting is usually needed even if you keep the stock airbox and the stock exhaust, but use a K&N low-restriction filter, or even if you drill holes in the stock airbox, or leave the filter lid off.
    All such actions free up the intake side airflow restrictions; the stock exhaust will move this additional airflow, and without providing addition FUEL flow to match the increased airflow (within limits, an engine will gobble up the maximum amount of airflow that it can; an internal combustion engine is actually just a self-powered AIR PUMP) then the engine will run "lean"---meaning not enough fuel to match the amount of airflow that the engine can (and now will) gulp.
    Most pod type filters allow for vastly increased airflow, and thus require fuel re-jetting, and although no one really talks much about it, probably also require AIR JET changes to match the additional fuel flow, but since no one likes to deal with two parameters at once, it becomes a "tuning nightmare".
    BUT, when you read all of the common symptoms of people who use pods, you quickly come to the conclusion that it's not possible to reproduce the stock "smooth in all rpm ranges" engine response. The reality is that you SHOULD be able to match it pretty darn closely, even with the increased airflow through the system, but ONLY changing the fuel jets isn't going to accomplish that. There are also air jets in the system, and they are there for a reason, as well as needle tapers and vacuum piston responsiveness issues.
    For further insights and understanding, the Holy Grail (meaning: the whole miserable, un-varnished truth of what a real chore carb tuning is going to be, written by people who actually know what they're talking about, rather than by people who are trying to sell you something) can be found at:
    www.factorypro.com
    and then click on the "Product Support/Technical Support" link at the top of the page, then on the "Motorcycle Tuning Tech" link, and then the "CV Carb Tuning" link........and then read, weep, study, and do....if you still dare to! HINT: if reading through it makes you think to yourself "sheesh, this sounds like an incredible amount of effort!", well, you're right! That's just some of the joys (and pitfalls) of getting to play "tuning engineer", which is what you're going to be doing. Yamaha probably has 10 of those types of guys on staff, and millions of dollars of test equipment, both physical and computer-aided, that allowed them to get the mixture settings just right---from an overall drivability AND power output standpoint----and now, since you're changing the airflow parameters thru the engine, you'll have to figure it all out "from scratch", but WITHOUT the benefit of 10 trained engineers and all that test equipment and experience.
    That's why we warn you that setting up a bike for pods can be quite a bit of trial-and-error procedure. You can make the calculations according to what is shown in that guideline and then order the jets that the "formula" recommends, and that should serve as a good STARTING POINT............you may (or may not!) have to do more tuning and trial-and-erroring substitution of different jet sizes, etc. to get it performing to you satisfaction, with the recognition that you may ALWAYS end up with a situation that has some kinds of trade-offs.....lazy at the lower end but runs well at mid/upper-ranges, or runs well at the lower end but a "flat-spot" at some other rpm range, etc. Unfortunately there is no magic formula........you might want to read through the factorypro.com article that I list at the end of that section, and you will get a better understanding of what is involved to get the carbs set-up properly in a non-stock configuration.
    As one of our favorite experts says about pod filters: "Get a Rubik's Cube instead.....it's less trouble and actually has an eventual solution!"
  9. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Excellent write up as a starting point for selecting jets - but a couple of points I'd make:-
    The use of a colourtune will only work if the engine is in good condition, valve clearances etc correct. Most of all, it must not be burning oil. Furthermore, it can only work when you can see it - so that means idle and early progression. Pretty much useless on the road type range then. Wideband lambda is the only answer sadly.
    Secondly, the rules of thumb are guestimates only - but you have to start somewhere right?
    Oh, and there is a third point not often mentioned - if you go for podfilters one thing that really changes is the pressure the carb sees from the outside. This increase in pressure raises the piston relative to where it was previously, the effect is likely to be a weakening of the mixture - at mid to high range anyway. Fitting a larger jet only fixes the top end, so the weak mid range remains. The answer is to fit stiffer springs - but how stiff? You're on your own, but each coil on the spring is one part of the total number. So for a 20 coil spring, cutting off 2 is a tenth stiffer, or thereabouts. The trouble is cutting coils off actually shortens the spring, reducing the preload - you might consider a spacer, or stretching the spring to original length - again good luck.
  10. Polock
    how about a weight on top the slide
  11. kosel
    MInneapolis, MN
    I've seen a lot of varying opinions on this, but trust @chacal.
    I have a XJ650 RJ where a PO replaced the original exhaust pipes with 4 into 1 and an Kerker muffler. The pipes are in rough shape and will need replacing. If I keep the intake stock (air box, OEM filter, original carb jets) and replace with a new 4 into 1 and a new muffler, there is no need to re-jet?
  12. joe elliff
    joe elliff Active Member
    illinois
    I’ve heard the same about Harley mufflers
    And I have a set here. Maybe I’ll try them at some point
    Andrew Nichols and Ketchup like this.
  13. Scottie1
    Scottie1 Active Member
    Columbia SC
    They work well and sound good
  14. hughie1987
    hughie1987 Member
    pennsylvania
    So where can I get an aftermarket exhaust? Cant find anything for my 550 on google, the stock exhaust is ugly, I only want one muffler!
  15. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    Look at MAC exhaust products.
  16. Polock
    ebay has them, nobody said they were cheap
  17. sybe
    sybe Active Member
    NYC - Brooklyn
    be careful with the Harley mufflers. I used a set on mine and i had to get custom spacers and extensions to clear the rear brake.
    What i used was a 2010 Harley fxs 1800cc slash cut with heat shield. I got them for $40 so i couldn't pass them up. They are super long, so i cut a chunk off and shortened the baffle and removed the packing. I sealed them back up with a small tac weld. If i didn't add the spacer about 6" if i remember correctly, the rear brake would hit the muffler and wouldn't work.
    IF you aren't prepared at the possibility of doing all that, then buy whats made for the bike.
  18. Scottie1
    Columbia SC
    I didn’t have any problems really straight bolt on once i made a bracket. Disregard picture without pipes wrong one
  19. sybe
    sybe Active Member
    NYC - Brooklyn
    you used a different muffler than i did. if it was just a bracket job, do you mind telling the OP what muffler you used so he knows.
  20. XJ550H
  21. Scottie1
    Columbia SC
    I have no idea LOL i just went to a second hand Harley shop and he had hundreds laying around i just picked up the best one i could see.
  22. LarryMc
    LarryMc Active Member
    Lakewood, WA
    In the US, pretty much your only option is Mac or Kerker. If you shop on eBay UK or look on Webike your options will multiply greatly. Be ready to pay a bit for shipping.
  23. Dave in Ireland
    Ireland
    I used a pair of slash-but Dyna shorties on my 4-into-2, but there are a couple of mods needed.
    The reducer needed was simply cut off the front of the old previous mufflers (not OEM, but they were a replacement system that were near enough identical to the stock set) and used as a packing piece on the inlet of the Dyna mufflers.
    When the mufflers were on the Dyna, to suit the differing characteristics of each cylinder and the unequal lengths of pipe on the Harley, the internal baffle plate on each muffler is placed differently. I solved this by removing them and rigging up a temporary spacer equally set on each side to match them in for my use. Said spacer holds back a stainless steel pot scourer internally, and forces the gases through the silencing slots and into the deadening material. Some also goes right through the pot scrubber and exits in a free-flowing manner, but as it's doing so down a tube lined with baffling holes backed with more deadening material, it does so quite quietly.
    Fastening the mufflers was quick and dirty - I just used car exhaust clamps at the front *ugly but effective* and I'll try a different solution some other time.
    The mounting of the muffler bodies was easy - a pair of stainless steel hose clamps round the muffler bodies and locating over the lower portion of the alloy footpeg bracket there. This is on an XJ900F, so other models probably don't have that handy feature.
    The overall result is quite pleasing - the bike pulls as well as it ever did, and is nearly as quiet as stock. If I want to make it a bit noisier I can unbolt the scouring pad retainers and move them back or even reduce the size of stainless pad.
    The best part is; the mufflers cost about two bucks. :D
  24. Tim O
    Tim O Active Member
    Charlottesville, VA
    I've been looking for mufflers off and on... anyone know the outlet diameter of my 75o Seca collector?
    I'm too lazy to take it off and measure myself. :rolleyes:
    Besides, there are newer gaskets there so why disturb them I'm thinking....
  25. May_J_Aaron
    May_J_Aaron Josh May
    Chandler, Arizona
    From reading this and living in Phoenix, AZ at 1080' elevation.
    On the 83 Maxim 750, if I put a MAC 4-1 and K&N filter into the stock box I should need
    Main Fuel +4
    Pilot Fuel +1
    Main Air- unchanged
    Pilot Air- unchanged
    Would this be correct?
    I currently have stock air and just stock headers on it, (that's the way I bought it) it would have the occasional "popping" sound while riding it home but rode very well!
  26. XJ550H
    stick with the oem style filter
    Jetfixer likes this.
  27. Polock
    on my 750 seca, i run a mac 4/1, a filter with two layers of uni foam and a supertrapp muffler
    122 main, everything else original. things didn't come together till the supertrapp happened
    i didn't try real hard with the mac muffler because i didn't like how it sounded
  28. Jetfixer
    ^^^+1 Do NOT waste your money on the K&N filter . The PO of my bike had put one of these bike struggled over 75 , swapped to paper filter WOW bike would bury the 85 mile an hour speedo . Later went through my carbs church of clean , as experiment I put in bigger jets 124 main and tried the K&N results bike popped and did not run right , put paper back in and problem solved.
    hogfiddles and XJ550H like this.
  29. PJC750
    PJC750 Member
    Northeast
    Hi Guys,
    Been away for a while,but I came across this exhaust article and it triggered a couple questions. I think for my 1981 Seca, the exhaust is a little noisy, and moreso on one side. Valves in spec, stock jets, stock air filter, Balanced carbs, Colortuned( need to rebalance 2nd time after colortune), idles fine at 1000rpms, and it sounds roughly like a sewing machine(a lower DB range sewing machine). The stock bike videos I watch, have a higher pitch whine at idle and thru acceleration(like moms old Singer).
    -From my pic does it appear to be the stock exhaust?
    -I see some models around, that have a chrome conical part at the tail, is that stock?
    -Should I look for exhaust leaks (replace the header gaskets, ck other joints along the way)? I am not sure if a baffle ever existed on these exhausts(I still see the black insert at tail exit,which appears to be welded in there, so I couldn't really get a look inside.
    -I was also considering a pair of small silencers which 'snap in'
    Any suggestions are appreciated
    Patrick
  30. Jetfixer
    MAC makes a nice 4 into 1 and a 4 into 2 set up have a nice exhaust note , not cheap but in my opion a good set up. I had this on my seca till I scored a stock system that is mint. So for now the MAC system sits in my storage.
  31. PJC750
    PJC750 Member
    Northeast
    Thanks JF. Am hoping not to have to replace(has 9k orig miles) it. It runs great, no backfiring, no sputtering, and is much quieter upon returning from a ride. I will prob start with simple things ,gaskets, tail pipe connections etc, I am sure they are crap. I have a new back tire,bearings and rear drum that have priority.
    I am not a purist, but lean toward keeping what I can original. As you know we can find parts for the bike.(Except of course for the dreaded 'right side cover'. )
    Did you end up rebuilding your rear springs or replace?
  32. 50gary
    50gary Active Member
    Saginaw, Mi. USA
    Not to hijack a thread but what's the deal about the right side cover? Do they all fall off on the road?
    Cheers, 50gary
  33. Jetfixer
    The battery is on that side,so cover is removed and often lost, I had to buy one for my Seca 750 and bought another as a spare.
  34. PJC750
    PJC750 Member
    Northeast
    50 Gary,
    here in the US for some reason 1981 Seca 750, right side cover is hard to find.
    In fact if I ever sell my bike I will sell it to the next person exactly like I got it, no right side cover. Maybe it'll go from $100 to 2000 and then I can go find another used xj750. I do have an extra left side cover which I'd be happy to sell of 30 bucks.
  35. PJC750
    PJC750 Member
    Northeast
    I think what happened is the bike sat for a while with the last owner because I did find Bike in a leaf pile. He didn't want his wife to know you owned a motorcycle haha.
    water collected in base of headerpipes sat there so I'm thinking it rotted through pipes , explaining Muffler noise. We have weep holes in window sills why we can't come up with an ingenious way to drain moisture out of our Muffler pipes is a mystery motorcycle Engineers need to solve, especially since on these bikes pipes pitch back towards the front.Duh.
  36. XJ550H
    I hunt ebay for right side covers then buy a bike to put it on.
    right side is lost because someone removes it sets it on the ground and steps on it .
    take cover off for battery to go to winter nap and lose or forget where tgey put it
    I have heard that most bike accidents hapen with bike falling to right side and destroying cover , I do not think this is a big factor but coud be another reason.
    PJC750 likes this.
  37. Dave in Ireland
    Ireland
    Some of them do, but mild steel pipes will rot out eventually no matter what you do.
    PJC750 likes this.
  38. PJC750
    PJC750 Member
    Northeast
    Pipe wrap baby and some JBWeld
  39. Dave in Ireland
    Ireland
    Stainless is a better long-term solution. Once a mild steel pipe starts to rot away, it's time to start looking for a decent replacement.
    Given the price of motorcycle-specific mufflers, I've been using Hardly mufflers, which are pretty well built and seem to last a long time.
    Right now I'm seriously looking at a car resonator final muffler, built entirely from stainless, 4" or 5" in diam, 2" or 2.5" inlet/outlet and say 20" long (length can be specified). All this for around 40 or 50 quid and a lifetime's use out of it.
    Once I get my AFR settings properly dialled in, I will either fit the genuine Delkovic muffler or a car muffler.
  40. Franz
    Can you post some photos Dave if you fit the car muffler? Interested to see how it will look.
  41. Dave in Ireland
    Ireland
    Will do. Oddly enough, it wouldn't look too far out of place given the stupidly large exhaust silencers fitted to many bikes as stock nowadays. Some of them could double as trombone cases.
  42. Franz
    I saw a Honda the other day with a huge triangular silencer hideous looking it was.
