Aftermarket side panels?
Discussion in 'XJ Modifications' started by PlzHelp, Mar 1, 2019.
  1. PlzHelp
    PlzHelp Member
    Arkansas
    As is the case with a lot of people, I am missing the right side panel on my 1982 Xj650 Maxim.
    As I have been looking at other people's builds, I noticed quite a few have what looks like a piece of smokey colored plexiglass that fills the entire triangle slot in the frame on either side of where the airbox is.
    I replaced my airbox with pods, so now there is just a big gap on my right side where there is no cover. I really like the look of these side panels, but I can't seem to find the name of them anywhere. They look professionally produced, and some even have a logo on them that I can't quite make out.
    Does anyone know what these are called or where I could find them?
  2. 50gary
    50gary Active Member
    Saginaw, Mi. USA
    What's up with the Maxim right side cover??!? Are they prone to falling off or what? I happen to like them as they clearly identify the 750 Maxim. 45 C.I.D. 3/4L
    They are also well made, not just plastic.
    Cheers, 50gary
  3. PlzHelp
    PlzHelp Member
    Arkansas
    I don't know whether it is due to the right side being the battery cover, which makes it the side that you manipulate the most, or whether that is just how they are built, but the right side panel is definitely prone to falling off. As such, they are scarce to find and in high demand. If you do find one, they are going to be very expensive.
    I can't even find any right side covers for the 650 Maxim, so whether I like them or not is a moot point. If I could get my hands on one for cheap enough, I would obviously prefer OEM, but I'll take what I can get at this point to make sure my battery isn't just hanging out.
    Here is a pic of the type of side panel I am looking for. I believe this one is black metal, which I would be totally cool with as well. So long as it covers that side we're golden. I just want to know where to find these.
  4. XJ550H
    side panels are made by the person who customized the bike. there is no aftermarket manufacture of sidepanels .
    why are right side covers missing?
    it is the panel removed the most because it covers the battery.
    the more it is removed the higher the chances of breaking the mounting tabs
    people remove them to service the battery place them on the ground and step on them.
    or drive away leaving them on the side of the road.
    a little gremlin on the side of the road reaches out and grabs it as you go buy unless you have a bell on your bike
  5. PlzHelp
    PlzHelp Member
    Arkansas
    Odd. I see a lot of identical side panels among rebuilds of XJ650s. Can every single one be custom?
  6. XJ550H
    the space on the bike is the same on all xj650 maxims. tape a piece of card board in the space and trace along the frame tubing and you get that shape.
    go to tcbros.com they make all kinds of parts for custom builds no side panels for the xj bikes not that much of a market share out there.
    if you ask them they might make some for you
  7. XJ550H
    the photo you posted looks like a 750 seca to me
  8. PlzHelp
    PlzHelp Member
    Arkansas
    It is, but since I was looking for the side panel it didn't really matter. Slot is the same size and shape on both bikes.
  9. XJ550H
    they are even bolted in place and quite nice with the metal frame
  10. PlzHelp
    PlzHelp Member
    Arkansas
    The panels on my XJ650 Maxim do not bolt in place. They just have plastic pegs that fit through grommets.
  11. XJ550H
    so how much do you think an aftermarket set of side covers is worth or would sell for?
  12. XJ550H
    yup but the 750 maxim has 1 bolt to hold it in place 50gary kinda jacked your thread with a comment about the 750 maxim sidecovers. very nice construction
  13. PlzHelp
    PlzHelp Member
    Arkansas
    I don't know how much an aftermarket cover would cost. I assumed what everyone was using for the builds I saw with that panel wasn't a part that was made specifically for the bike, but rather a piece or part from something else that was merely lashed or otherwise attached to the frame, like a side panel from an unrelated bike that somebody figured out just happened to fit in that slot. I didn't think that each of them could be custom made, because quite a few are nearly identical, with the difference usually being some paint theirs.
  14. XJ550H
    so if some right sidecover hoarder happened to have a right sidecover for a 650 maxim in need of paint ,what would you offer me I mean him for it?
  15. XJ550H
    if after market side covers were out there I guaranty someone here would know where to get them and would also be available from our supporting vendor
    have you asked chacal if he has the stock side cover you are looking for?
  16. PlzHelp
    PlzHelp Member
    Arkansas
    Idk man. I don't have much in the way of money right now, and I need to replace my tank anyway because when I got the bike the tank had rust holes in it that a new liner failed to seal, and JB Weld isn't cutting it anymore, so I have to prioritize that. I just wanted to see if anyone was aware of panels like that out there so I could price them out and pick up one after I find a replacement tank.
  17. PlzHelp
    PlzHelp Member
    Arkansas
    I'd love to find a 3D models of the OEM side panels, as I have a 3D Printer and being able to fabricate a new one whenever needed would be a godsend
  18. XJ550H
    I check ebay for right side covers every couple of days. persistence pays off.
    the secret is buy them when you see them.
    you could make the panels it is not that hard sheet aluminium, plexi glass or diamond steel would work well . start with a card board templet make a cardboard model then find the material you like/want to use.
  19. XJ550H
    what is a 3D model would that be a sidecover that someone has scanned to produce a digital copy of a side cover?
    or can a 3D printer do a scan then reproduce the cover?
  20. XJ550H
    a 750 maxim tank is a direct bolt on replacement for a 650 Maxim tank and it holds more fuel.
  21. XJ550H
  22. PlzHelp
    PlzHelp Member
    Arkansas
    Some 3D printers have built in scanners. My last printer actually had one built in, but I sold that printer to a friend in order to buy one with a laser engraver instead since I barely used the scanner at the time. The most common 3D scanners though are standalone devices. To get a 3D model of the OEM panels, you would either need someone to scan the originals or recreate them in modeling software using measurements from the original. Either way, once you have the model you could print new ones all day long for $1 a piece.
  23. XJ550H
    is the scaned format a universal fit for all printers ?
  24. PlzHelp
    PlzHelp Member
    Arkansas
    Should be. If not, 3D models are pretty easy to convert into any other format.
  25. XJ75082
    XJ75082 Member
    Central Texas
    How bad is your tank rusted. What locations are rusted?
    I've done a lot of thin sheet metal repair. Patching a cleaned & purged out tank isnt difficult. Tig welds being the best but mig welds will do just as good.
  26. XJ75082
    XJ75082 Member
    Central Texas
    Is there a mirror option in the program of the printer?
    If so, there is the right side cover plate. Scan left, mirror, print right.
    I've looked at them close and noticed the 82 has a radius from the outer edge toward the inner triangle. Along with a radius across the entire cover panel.
    I can fab the panels but not the radius (lack of equipment) aluminum diamond plate or lexan is looking like a better option over finding replacements.
  27. Brian Abel
    Brian Abel New Member
    High Island, TX
    My XJ700 is missing the panel on the left side of the bike (kickstand side). I just bought the bike from a friend of mine and I’m working on getting it running. I can’t figure out how to get the panel on the right side off. Doesn’t the battery get replaced/serviced by just taking the seat off?
    I’m very new with all of this.
  28. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    The panel on the right side only hides a small storage area. The panel pulls straight off, same for the right. Examine the way the left panel would mount. Be careful to not pull/rock one end drastically more than the other as you can break the tab/s off the cover.
  29. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Some probably lost side covers because the rubber grommets holding them on (at least on my XJ550) cracked, and the covers fell off.
    I replaced the rubber grommets, and now I have to be careful not to break the pegs when removing. As stated, the right side is off and on more as the battery is on that side. Likely it is therefore broken more.
