Aftermarket tachometer & yamaha xj 750 1982
Discussion in 'XJ Technical Chat' started by Laurensvdm, Jul 7, 2022.
  1. Laurensvdm
    Laurensvdm New Member
    Belgium
    Hii,
    I'm working on my xj 750 maxim and turning it into a caferacer.
    Almost done so now i'm doing the smaller things like the tachometer.
    I bought a cheap aftermarket one like this :
    Now when connecting it doesn't give a reading.
    I'm sure i connected everything properly ( tried multiple configurations )
    I measured the voltage from my coils and they give a proper reading (4V and above when revving up)
    So that shouldn't be the problem.
    How can i be sure that the tachometer is faulty ? Can i test it with something ..?
    Is there a way to connect it to give a reading for testing purpose ?
    Wiring is like this :
    Yellow = coil
    green is power negative ( ground)
    Black is power positive
    And there is also a red & black wiring for the light ( that is working)
    Thanks in advance
  2. Rooster53
    Can only guess since you didn't provide a link or supplied wiring diagram
    There are two types of tach detection circuits:
    One is a pulse detection with a preset bias, usually just a diode drop and any pulse above that drop is detected as a pulse - this works with the primary coil output from the TCI.
    Two, a zero crossing detector where each time the signal crosses zero a pulse is detected - this works with the pickup coil output.
    So, could be if you have it wired per the directions it is looking for a zero crossing pulse, so perhaps try connecting it to the pickup coil output
  3. Laurensvdm
    Belgium
    Okay after long searching and trying i found out that the manufacturers wiring information was incorrect.
    For others interest in the future :
    black = power
    yellow = ground
    green = coil signal
    Works like a charm now :)
