Air adjustable forks:
Discussion in 'XJ Technical Chat' started by RL.Noble, Apr 18, 2026.
  1. RL.Noble
    RL.Noble New Member
    Oregon
    i did a fork rebuild the other day (it's been a few weeks) and my air adjuster caps need new o-rings. they weren't holding air more than a day before and releasing faster now.
    does anyone know what the size is for those?
    apparently, rebuild kits don't exist, but i can still find seals and dust caps.
  2. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
    What bike are you working on?
  3. Fuller56
    Fuller56 Well-Known Member
    You need to check with Len (@chacal here) at XJ4EVER.com or from the logo at the top right of every page here. He has almost everything for our XJ's, his site has about all the XJ info you need and is the best fellow to do business with you will run across anywhere.
  4. RL.Noble
    RL.Noble New Member
    Oregon
    XJ650 Maxim
  5. RL.Noble
    RL.Noble New Member
    Oregon
    thank you for the input.
    i'm asking here because i have already exhausted those resources and not found the answer. this includes a forum search.
  6. FJ111200
    Can you take the o ring off the cap and take the o ring to your local automotive parts supplier for a comparison?
    Is this the part? > O-RING for Yamaha - order at CMSNL
  7. RL.Noble
    RL.Noble New Member
    Oregon
    nope.
    probably should have taken the time to measure them when i had them apart.
    i'll keep looking.
    looks like they're called "Fork Cap Bolt O-ring, 35mm", but i'm looking for the dimensions at this point. if it's a 35mm diameter, then i need the thickness.
  8. Roast644
    Roast644 Well-Known Member
    WASHINGTON
    If you go to Partzilla or any of the other online parts places you can search the diagrams for part numbers. #10 below is the oring I think you are describing. Also handy is the cross reference to other models that use the same part, so you can often find parts on ebay by searching for the other models. Click on the part number, then the "product fitment" tab to see the cross reference. And since that one is a static seal, you can get away with an inexact fit out of a standard or metric variety pack kit. But the one you are describing shows as available.
  9. RL.Noble
    RL.Noble New Member
    Oregon
    yes, i found that.
    no, it doesn't answer my question.
  10. chacal
    RL Noble: do you need the o-rings for the big CAP BOLT (item #10) or the tiny o-rings for the schraeder (air input) valves (item #20)?
  11. RL.Noble
    RL.Noble New Member
    Oregon
    i was looking for the size of the big ones, but i should probably have the size of the small ones too.
  12. RideAlong420
    RideAlong420 Member
    USA
    I literally just did a fork rebuild on my 1982 XJ650 and there were 4 in each fork
    the o-ring on the top plug (large)
    the o-ring on the schrader valve (small)
    the o-ring on the bleeder valve (small)
    the o-ring on the valve stem (smallest)
  13. RL.Noble
    RL.Noble New Member
    Oregon
    did you happen to do any measurements?
    we're coming to a point where we're going to lose our commercial sources for part number acquisition and having the dimensions will benefit us.
  14. RideAlong420
    RideAlong420 Member
    USA
    I did not, sorry. I just replaced like with like. I had bought the fork rebuild kit from Chacal here on the forums
    I saved two of the o-rings I can check saturday and report back and try to approximate the sizes
  15. RL.Noble
    RL.Noble New Member
    Oregon
    that would be helpful.
    TIA
