Alternative brake calipers?
Discussion in 'XJ Technical Chat' started by Arnaud, May 28, 2026.
  1. Arnaud
    Arnaud Member
    Netherlands
    ..since after swapping the discs and pads the pads keep clicking.
    The guiding pins (is this the correct English term?) are okay.
    Maybe the calipers are simply worn out.
    I have a set of R6 calipers on my '91 FJ1200.
    Is a similar swap possible for my '88 xj900f?
  2. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
    My 1988 FJ1200 3CV has also got R1 blue spot calipers and are a direct fit to the 298mm front discs.
    The 1988 XJ900 has got 267mm front discs so doubt R1 or R6 front brake calipers will fit without some adapters.
  3. Arnaud
    Arnaud Member
    Netherlands
    Indeed, hence my question..
    Maybe replacing the anti-vibration spring/plate will help?
  4. FJ111200
    Are you using EBC sintered pads with new EBC discs? My FJ has a slight clicking when the brakes are applied.
  5. Arnaud
    Arnaud Member
    Netherlands
    I have new Lucas/TRW discs and pads from the same brand.
    I noticed that the holes for de guiding pins have widened- i think, i do not know how much play is original.
    I could drill 'em out and place bushes but.. where to find such small bushes?
  6. Arnaud
    Arnaud Member
    Netherlands
    But, no alternative, more recent built callipers are known?
    Maybe from the Diversion?
