another CL optimist
Discussion in 'Hangout Lounge' started by Polock, Mar 3, 2017.
  1. joe elliff
    joe elliff Active Member
    illinois
  2. hogfiddles
    Oooooo........that's nice
  3. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    Need me to go pick it up for you Dave? Hahaha
  4. Simmy
    https://www.kijiji.ca/v-motorcycle-...8666?enableSearchNavigationFlag=true&uli=true
    I just checked this bike out as it is literally 2 blocks from my work.
    There is not much to be excited about, it is just too far gone for any reasonable restoration.
    I already have a rust free RJ tank but it needs a dent repaired. The tank on this one is showing serious rust and would need more work than the one I have now.
    I made a deal to swap his valve cover for a Turbo valve cover.
    I hope it fits, sure looks tidier than that YICS 3-stripes thing.
  5. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    That's a decent price for a pile of parts!
  6. Simmy
    The seller said the fact it has a registration is why he values it as high as stated.
    The motor turns but I noticed broken upper case where the RH crank end cap bolts on.
    Also broken cooling fins.
    Might be of value to someone trying to right a messed up bobber frame.
  7. Tim O
    Tim O Active Member
    Charlottesville, VA
  8. Paul Howells
    Paul Howells Active Member
    Victoria, BC
  9. Bluegray57
    Bluegray57 Active Member
    US
  10. hogfiddles
    Lightcs1776 and Bluegray57 like this.
  11. turpentyne
    turpentyne Active Member
    Desert SW
  12. Bluegray57
    US
    Well he did come down to 1200. Still too much in my eyes as thats what i paid for mine complete and original.
  13. Paul Howells
    Victoria, BC
    It's funny when they say they replaced the air box with pods for better performance. Like there are a bunch of Yamaha engineers standing around going 'Why didn't we think of that?'
    Maxim-X and Lightcs1776 like this.
  14. Paul Howells
    Victoria, BC
    It's more like the air filter costs $100 (in Canada) and you can buy some pods from China for $20.
  15. hogfiddles
    Well.....a lot of people DO replace the airbox with pods THINKING they will get better performance. BUT---the reality for a lot of them is that they then find out that they DIDN'T GET better performance that they THOUGHT they would, though.....
  16. Tim O
    Tim O Active Member
    Charlottesville, VA
  17. hogfiddles
    The wmblemnis the same.
    The pipes are slightly different, they do sort of interchange, but realize that the angles and lengths vary-- sonit may not fit as snug as you'd like. Personally, I found you can swap things around as long as you use all 4 pipes from one model.--- 4 maxim pipes on the seca, 4 seca pipes on the maxim.....
    But also--realize that the collector snouts vary in length, and the heat shields are different lengths too. So long and short of it--- thing can switch around, but they won't necessarily fit as good or look as good. I would be cautious of trying to mix and match a set pipes though
    Tim O likes this.
  18. Tim O
    Tim O Active Member
    Charlottesville, VA
    I keep seeing these individual NOS pipes come up from time to time and I always have in my mind that maybe I could slowly piece together a set of brand new pipes
  19. hogfiddles
    It would be beautiful. I have the same thoughts
  20. turpentyne
    Desert SW
  21. hogfiddles
  22. Simmy
    I have the same dream. Currently I have a pretty good set of 4 from a 700n for my project bike but #4 has a good dent in it. We need someone who has an assortment from the various models to lay them out on top of each other for comparison, someone did this for gas tank fitment, anyone know who I'm referring? LOL.
  23. Bluegray57
    US
  24. Simmy
  25. Tim O
    Tim O Active Member
    Charlottesville, VA
  26. Paul Howells
    Victoria, BC
  27. Tim O
    Tim O Active Member
    Charlottesville, VA
  28. Polock
  29. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
  30. Tim O
    Tim O Active Member
    Charlottesville, VA
  31. Simmy
  32. dkavanagh
    Rochester, NY
    Why people don't keep these things inside, I'll never understand.
  33. jayrodoh
    jayrodoh YimYam
    Cleveland
  34. hogfiddles
    Definitely.......put the correct mufflers on, and probably do a guidectomy----
  35. Simmy
  36. Tim O
    Tim O Active Member
    Charlottesville, VA
  37. Tim O
    Tim O Active Member
    Charlottesville, VA
  38. XJ550H
  39. XJ550H
  40. hogfiddles
    It's obviously neither a 650 OR a 750........that a hideously painted 550r.
  41. Mark John Smith
    Mark John Smith New Member
    USA
  42. Mark John Smith
    USA
    This is a TX500 right ? Not a XS500 I think. This is the little Brother to the TX750, which has a nice powerband, but Yamaha in all their ingenuity, forgot about keeping non-frothy oil in the engine. This mistake is a lot like the mistake in that the Seca 750 needs to have it's cases split to fix the (another) starter problem.
  43. hogfiddles
    That is a 1983 or earlier xj750 Seca. It is not a TX, and it is not 1987. Too bad it's not close to me, I'd have bought it already.....the right side cover is still there!!! Lol. That's a steal of a parts bike. The seat is still on it, the airbox is still on it.......the carbs are crusty, but appear intact-----I would be a bit surprised if the engine is still good. With all those things in place, it would be very hard for water to get inside unless the spark plugs are loose.....
  44. Tim O
    Tim O Active Member
    Charlottesville, VA
    I was thinking 4 the cover too
  45. Bluegray57
    US
  46. hogfiddles
    Yup. It's not an XJ, and it isn't a 650. I guess it could be an 850......
  47. xjyamaha
    xjyamaha Member
    Omaha, NE
    That's insane. $500 would be a stretch...
  48. joe elliff
    illinois
    Hmm. I thought the triples held their value decently. ??
  49. hogfiddles
    They do…When they're not butchered. That's why I have two squirreled away in a hollow tree
  50. Polock
