Anyone want a beautiful, Electric Maxim?
Discussion in 'XJ Modifications' started by Michael R, Dec 29, 2018.
  1. Michael R
    Michael R Member
    Seattle
  2. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    WOW what a sexy bike ;)
  3. chacal
    There's a rear disc brake on it? On the left side? And what appears to be a drive chain/sprocket on the right side?
    Do those batteries travel around WITH the bike?
    We better get Dr. Polock in here, stat, to comment on this............
  4. hogfiddles
    I don't even know where to begin......
  5. XJ550H
    it has a Kryptonite New York Legend Chain lock to keep anyone from stealing it...
  6. hogfiddles
    I don't know as 'beautiful' is the word I would have used......
  7. XJ550H
    and only droped 3 times
  8. chacal
    And you wouldn't want anyone to steal it, as it is a bit "top heavy" and the theif might drop it and break a turn signal or two, and then might sue the seller for selling them a bike that was top-heavy and prone to falling over and not telling them about that problem.
  9. k-moe
    Poor choice of batteries and controller. It's about 15 years out of date for a homebuilt in that regard.
    The rear wheel looks to be from a Ninja 500.
  10. Polock
    the helmet that goes with it
  11. 50gary
    50gary Active Member
    Saginaw, Mi. USA
    Kryptonite lock?, I'd leave it parked and running.
    The instant I saw it it thought, Arnold Schwarzenegger in his drugged up prime couldn't lift that thing. let alone "The bike is too heavy for me. " Don't feel bad it's too heavy for anyone this side of a Silverback Gorilla.
    Probably has those foam filled tires like some earth moving equipment does?
    Fugly doesn't begin to describe..
    One should never speak ill of the dead but.. the builder Dave Cloud probably died from embarrassment, or hari kari the only honorable way out?
    Cheers, 50gary
  12. hogfiddles
    The whole swingarm disaster is hideous, too..........regular swingarm that had has the end chopped off, an ugly who-knows-what mass of stuff welded on, to bypass the driveshaft and rear gear.......and then the ridiculously large sprocket for the chain on the other side.
    Rim looks kind of like a 900rk or a turbo 650, or a 550 Vision rim that has been turned around and modified......
  13. Simmy
    both brakes appear to be hand operated, so where did he get a LH brake master cylinder?
    He must have used a clutch master, never heard of anyone doing this other than Mick Doohan when his right leg was too mangled to operate a foot brake.
  14. k-moe
    There is a fairly large market for that sort of thing. It's not just Mr. Doohan that has a bum leg. Some people ride without any legs at all.
    It could be that a scooter master cylinder was adapted as well.
  15. hogfiddles
    It would not be for the clutch as we know it. The xj engine/transmission is not in the bike. This is an electric engine with one gear. So it's probably a hydraulic "engage/disengage drive" of some sort. Too bad we can't see the damage on the OTHER side
  16. jayrodoh
    jayrodoh YimYam
    Cleveland
    I’m thinking it’s a brake for the rear, you can see the copper? line running out back. If electric one speed there is probably no clutch or would there be a need for one.
  17. hogfiddles
    I think the rear left disc brake is probably engineered to be hydraulic right foot pedal. If things are re-arranged to be opposite hands/feet/order, I believe 1) it's illegal, 2) it's very dangerous
  18. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    I just would not want that much electricity that close to my nuts!!!
  19. 50gary
    Saginaw, Mi. USA
    I have "Thumb brakes" on two (and soon to be three) of my bikes. It's not that difficult and quite natural to use, left thumb operates the rear brake. I don't use rear brakes much anyway. My XJ 750 Maxim will have a rear thumb brake for sure, part of my winter's project. This is the first bike I built back in 2003/4 XS 650 everything was changed, geometry, total suspension change the works, and the thumb brake. You can see the left thumb "paddle"
    Cheers, 50gary
  20. Maxim-X
    Whoa, that's different! How much travel before engagement? 1/4 turn throttle and all that safety wire makes me think you have racing in your portfolio.
  21. 50gary
    Saginaw, Mi. USA
    Zip, but with your thumb it's easy to modulate. It's not a race bike but very much a minimalistic thing, raw, I call it Arte Primitivo, Latin for primitive art, like cave art, not Da Vinci art ha ha. Bicycle speedo, headlight/taillight, no key just a toggle, exhaust is straight through.
    Cheers, 50gary
