Are they the same ?
Discussion in 'XJ Technical Chat' started by Door dude, Aug 24, 2022.
  1. Door dude
    Door dude Active Member
    Mountain Home Arkansas
    Are the carbs on the 82 750 seca the same for the 82 750 maxim is my main question but are the engines the same also?
  2. chacal
    Carbs: the same:
    Engines: almost the same, but the Maxim engines use rubber bushings at the engine-to-frame mounting points, while Seca models use solid aluminum bushings at those mounting points.
  3. Door dude
    Cool, thanks for the info.
  4. Simmy
    And the shifter pivot is in a different location, necessitating an external linkage in the Seca shifter.
    All the parts are easily interchanged though.
  5. Door dude
    Im not looking to do this but, so the engines can swap frames ?
