Are YICS and non-YICS bottom ends the same?
Discussion in 'XJ Technical Chat' started by pillowmaster50, May 31, 2020.
  1. pillowmaster50
    pillowmaster50 Member
    Can I put a non-yics jugs and pistons and head on a yics bottom end?
    Also, can I do this without removing the engine from the frame?
  2. Mezzmo
    Mezzmo Active Member
    Answer is yes it can be swapped, but not without removing the engine. Check out my videos,
    I just put a YICS head, barrels and crank onto a non YICS engine. So reverse to your plan.
  3. k-moe
    You can do that swap with the engine in situ.
    The bottom ends are identical.
    Gentelmen,
    Please add your XJ model(s) to your signatures.
  4. pillowmaster50
    Awesome, thanks guys!
