Battery light
Discussion in 'XJ Technical Chat' started by jerry57g, Aug 9, 2021.
  1. jerry57g
    jerry57g New Member
    Iowa
    I put a new AGM style battery in my bike and had to remove the sensor plug from the original battery. Some one posted that you can get rid of the warning light by putting a resistor on the sensor lead. Anyone know the size or an easier fix?
  2. Polock
    about 2.2K resistor to + or take the bulb out
    or get a kit from chacal
  3. Rooster53
    You can bump that up to 6.2K 1/4 watt and it gives you a bit of a voltage monitor so if the battery light comes on you need to investigate why. The 2.2K will work also, but you won't get any useful monitoring.
  4. Polock
    it's been a long time since i measured it, off on choke, flicker at hot idle, off by about 2K. could set it with a 10K pot and see what he likes.
    6.2 doesn't sound familiar, must be getting old :)
