Battery voltage
Discussion in 'XJ Technical Chat' started by Plug, Sep 4, 2017.
  1. Plug
    Plug Active Member
    Missouri
    Wondering if someone knows off the top of their head at at approximately what battery voltage does the tci fail to work, or you would lose spark?
  2. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    Around 9 or so I believe? Someone will correct me I'm sure
  3. Plug
    Plug Active Member
    Missouri
    Thank you!!! I appreciate it!
  4. Chitwood
    Of course. I say I believe it's 9 volts as when you do a standing/cranking test of the battery voltage you want the voltage 12.2 or above standing, and no less than 9 when the start button is pushed otherwise you will likely end up with a crank no start/no spark condition
  5. k-moe
    Anything below 10 volts is sketchy. Below 9 and it's definitely a no-go.
  6. XJ550H
    9.8 by the xj4ever info if i .understand it correctly. 10 and up should be good to go
  7. ziggy1
    ziggy1 New Member
    Los Angeles
    Wait so if the battery is below 9 volts it will crank but not start? this might be my problem
  8. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    You may just hear a click.
    Buy a new battery... this coming from the cheapest guy this side of the Mississippi.
    Wish I had a nickel for how many times a bad/weak/ spent battery has been an issue... this coming from the cheapest guy this side of the Mississippi.
    Jetfixer likes this.
  9. XJ550H
    starter will spill well after battery will no longer power TCI to start bike
  10. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Took me almost 20 years of XJ ownership to figure this out. It was why I often could not get my XJ started, esp. at the beginning of riding season, when my battery started to age. It would crank and crank, but no fire. Once I jumped to a car battery, or cranked it with a charger attached, it would fire right off.
  11. Jetfixer
    I upgraded to AGM sealed Battery ..was not cheap but if I only get one season out of a conventional Wally World Battery ( CHINA) and have to buy another one next season ... Bought the best this year supposed to be 3 yr battery. and no mess !!!! Bike seams happy have yet to have it run down cranking engine. Just my 2 cents worth.
