Beef up the rear.
Discussion in 'XJ Technical Chat' started by Thrasher, Apr 17, 2010.
  1. Thrasher
    Thrasher Member
    Oak Ridge, Tennessee
    You may want to try the Radian swingarm and some diffrent shocks.
    The swing arm will bolt right on my shocks are about 13' giving it more clearance.
  2. stereomind
    stereomind Active Member
    Tulsa, OK
    Is that a Radian front sprocket cover I see there?
    I have a spare Radian swingarm... Too bad I don't have a 550 anymore :(
  3. bigfitz52
    Ya bum. I suspect the swingarm on my '83 is slightly tweaked, and I have a BRAND NEW NOS replacement ($9 off eBay) sitting here and now I probably won't use it.
    Is the Radian swingarm radically stiffer or improved over the original round-section one?
  4. Thrasher
    Thrasher Member
    Radian motor. I think the box design is stronger.
  5. bigfitz52
    Now I wanna see what one looks like. Have you got a spare you can snap a pic of, from above say, so I can compare the design with the original?
    Or from any view that would show how it's different from the stock one?
    That's quite an increase in rear ride height-- I'm comparing swingarm angle to stock-- does it change the handling much, as it shortens the front numbers? (Less rake and trail...)
  6. dwcopple
    dwcopple Active Member
    bay city, michigan
    should be, but I highly doubt anyone here is gonna push the limits of the stocker...LOL
  7. stereomind
    Tulsa, OK
    Fitz, here you go.
    Sorry, it's filthy...
    EDIT: it should be noted that the Radian and the XJ550 share the same frame.
  8. bigfitz52
    ..."he don't know me vewwy well, do he?"...
    That being said, the jury is out. I don't like the "kink" in the inside wall of the tube where it bends; the original swing arm's round section tubing didn't kink with a bend that mild. And I'm not so sure that the cross-beam "box" is necessarily stronger than the stamped "web" welded across the original.
    I'll shoot a couple pics of the stock one and we can compare.
  9. Kickaha
    New Zealand
    What are the footpegs you're using off?
  10. Thrasher
    Thrasher Member
  11. Kickaha
    New Zealand
    Not a model we saw a lot of here
    The stock footpegs touch down very easily so I am looking for alternatives that go in the same spot
    I have a pair of the same shocks I am going to try while I save for my spanky ones
