Beginner restoration of a 82 XJ550 Maxim
Discussion in 'Hangout Lounge' started by Mancub, Mar 2, 2021.
  1. Mancub
    Mancub Member
    Pleasant Grove
    Sadly a quick search for 96 radian 600 tank (I believe that’s first gen) comes up just about as fruitless as a xj550 tank search... open for ideas on the tank, I’m hoping to keep working on getting things running in the meantime, aux tank on the way.
  2. cregoryjames
    cregoryjames New Member
    Saginaw, Michigan
    I might have a 550 tank. I can check tomorrow night if that works for you. Not sure the condition, but I'll check everything and send pictures if I find it. Just moved this winter and have been working on my 650 so I snag xj parts whenever I find them local
  3. Mancub
    Mancub Member
    Pleasant Grove
    Update and in need some help. I did all this before I was gone for a few weeks, just got back and want to figure out the next steps.
    I got the carbs all apart, cleaned, thought things looked good, put them back together. I then put them back on the bike(sweet mercy those carbs are ugly and tough going off and back on). The tank is off right now so I hooked up an auxiliary tank(doesn’t have a petcock I don’t know if that matters). I got it all reconnected, changed the spark plugs, changed the oil, turn it over and.... nothing. I can get it to turn and try but it’s not igniting. Then I realize that gas is draining out the bottom, looks like an overflow hose that comes out of the air box. Looked inside the airbox and saw what carb air hole gas was coming out of. Sooo does that mean that carb has a problem with the float and is flooding? Is that enough to flood the whole thing and not allow it to start at all? It looked like it basically drained the whole aux tank, till it leveled out to not leak anymore, and there is just some gas in the hose now.
    I am just trying to get it running, make sure I got that going, before I make air pod adjustments and take everything apart for customizing and cleaning. Thoughts?
  4. Simmy
    Did you wet set the carbs before reinstalling? That will tell you if any float valves are leaking as well tell you the correct gas level.
    Check your oil it may be full of fuel
  5. XJ550H
    One thing to remember about the 550 carbs is on first refill you have to
    Rap a hammer handle or screwdriver handle against the car bowls because the float needles tend to get stuck that could be what your problem was with the leak
  6. Mancub
    Mancub Member
    Pleasant Grove
    No... after I cleaned them and reassembled I just put the carbs back on. Then poured gas in the aux tank thinking I could just let them fill up and they would take what they needed, stop, then I would try to run it. Turned it over but couldn’t get anything to catch. Put some buster in the cylinder to try and get things going but that didn’t work. Maybe there isn’t spark? That’s an easy check but I don’t think that’s it.
    So what’s the next step? Pull them off and try to Wet set them, If that doesn’t work then go about replacing the float needles?
  7. Mancub
    Mancub Member
    Pleasant Grove
    Been awhile! Okay I pulled the carbs out and then rapped around on the bowls, then put fuel into them andddd.... fuel started coming out of the air intake side... My best guess is the float needles right? Would that be why it wouldn't start, it was just flooded so I couldn't get anything to catch. I'm ordering a few things from Len, curious if you guys think I'm missing anything.
    HCP895SET4 - Orings set idle screw
    HCP896SET4 - Washer set, idle screw
    HCP1670SET4 - float needles set, this is the main thing
    HCP18412SET4 - bowl gaskets, might as well
    Also I'm still on the hunt for a GAS TANK! Anyone got any leads for an xj550 maxim tank!?
  8. hogfiddles
    What did you set your floats at for the initial height? Initial setting before wetsetting is 21.5mm.
    if your floats aren’t close to that, they may not close properly.
  9. Mancub
    Mancub Member
    Pleasant Grove
    I tried to get them all pretty close to that 21.5, I did feel like the sensitivity was a little too much like it wasn't cutting off or pushing down really.
  10. Mancub
    Mancub Member
    Pleasant Grove
    Ok folks so I got some new float needles and a few other things things to just update it while I had it apart from our by Len at xj4ever.
    Wet set and no fuel was coming out the air intake so looks like that worked! Hopefully:) However when put them all together and tried letting some fuel down to test the connections I see a leak in that T bar fuel connecter in the middle! Like it’s not sealing.
    Besides replacing it which I don’t want to do cause it seems fine, there aren’t rubber gaskets on that piece, is there something I can put on it, or do to seal those fuel connectors all up? I wanted to ask before I did something dumb. I have some gasket maker stuff, plumbers tape... yeah just wanted to ask my smart friends.
  11. Franz
    The T bar connector the fuel line goes onto has O rings to prevent fuel leaking which are not visible with the carburettors assembled. Unfortunately the carburettors have to be split from the mounting rails to replace them.
  12. Mancub
    Mancub Member
    Pleasant Grove
    Yeah I have the carbs all the way into pieces, cleaned and was in reassembly doing the wet setting and putting those fuel line connectors in when I found the T was leaking. When I had it apart I could see ridges but there were no O rings that would come off like the pieces between the other carbs.
    I just need something to seal that, I’ve got them all apart so it would be easy. Maybe I can find an O ring at the hardware store I can just put on there?
  13. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    Some of the tees are rubber coated steal with ridges that acted as o-rings. Some tees had just o-rings. Get a new tee with o-rings. Do it right do it once.
    chacal and Franz like this.
  14. Mancub
    Mancub Member
    Pleasant Grove
    Lostboy thats what it is, steal T rubber coated so those act like ridges, but yeah they aren't doing so great haha
  15. XJ550H
    600 fuel tee and it has orings , Len sells those too.
  16. Mancub
    Mancub Member
    Pleasant Grove
    Hey guys I'm going to be putting the carbs back on and trying to get things to run now with what I think was the issue with the flooding fixed. I'm remembering how terrible the airbox experience is, I also think longterm I'll be pulling the airbox to clean things up. What would you guys suggest for this 82 xj550 in this area? I know Pods are options, just curious what you guys would suggest before I do anything.
  17. Xj550newbie
    Xj550newbie New Member
    madison
    If you need parts for anything I've had a really good experience with Oldbikebarn
  18. Mancub
    Mancub Member
    Pleasant Grove
    Howdy folks! Been awhile, but I'm back at it. I got the engine running, Whoot whoot! But a few things were happening. 1. It sounded a little rough close to idle, had a hard time keeping it in idle it wanted to die out even after adjusting things. 2. A few times when I was letting things run and revving it, it would start to rev up in RPM's on it's own! I wouldn't touch anything and it would just be climbing, I'd have to usually kill it to stop it.
    Moving forward.
    First, I haven't done a valve clearance adjustment yet so I'm getting into that now. Where do you guys recommend getting the shims once I measure and know what I need? Also any recommendations on gauges? I tried two that were way to big, the lowest gauge was bigger then specs for this bike.
    Second, any ideas on the ghost revving?
    I'd like to get the engine purring before I move into all the safety stuff and taking things apart again. I also do not want to take the carbs off again with the airbox. So I need some pod suggestions. This is my brain dump, send me wisdom:)
  19. hogfiddles
    Shims-
    Pool, talk with me
    Wanna order new, talk with LEN
    sync gauges- get a set of the Morgan Carbtune Pro
    ghost idle-most likely due to not being Running-synced. If it continues after syncing, then it’s likely a vacuum leak. But don’t diagnose it as that till after you’ve done your running-sync.
  20. Mancub
    Mancub Member
    Pleasant Grove
    Hogfiddles thanks for the advice. Let me ask some clarifying questions.
    1. Great, I'll reach out when I know what size shims I need. The question I had on "gauges" where to get ones small enough to slide in and measure the shim clearances. Are those called Feeler gauges maybe? I don't know, but the two I tried, (look like thin metal pieces on a keychain) were too big for the clearance specs. Autozone didn't have small enough ones, I'll find some on amazon or something in the .10mm-.25mm range for these clearances.
    2. After I measure, change the shims to get clearances in spec, then are you recommending doing the running carb sync? Do you know places that do that so I don't have to buy the tool?
    3. It's more of a Ghost Rev haha it's idling, then randomly it starts to climb in rpms and can't be stopped till I cut it. Just to clarify.
    Step 1 I need to get the right feeler gauges or whatever they are called to measure the shims and then get the right onces and swap them. I know I saw videos in here on how to do that. Then...?
  21. hogfiddles
  22. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
  23. Mancub
    Mancub Member
    Pleasant Grove
    Thanks guys. I'll get in and do the clearance measurements, I'll let you know my measurements and I might see if you have some shims in your pool hogfiddle that I could get from you. Appreciate the help! Stay tuned!
  24. Mancub
    Mancub Member
    Pleasant Grove
    I’m alive! Time to get this thing ready for summer.
    Ok, so valve clearances. I finally got a gauge that could do it and got things measured. Things are all over the place which might explain running rough, remember the bike sat for years before I got it. Help me out here with knowing what shims I need, here are my measurements.
    In: 1 - .02mm?(.04 wouldn’t fit) 2 - .10mm 3 - .13mm 4 - .02mm?(.04 wouldn’t fit)
    Out: 1 - .13mm 2 - .15mm 3 - .10mm 4 - .18mm
    What do you guys think? Can I know what I need just from that or do I need to pop out all the shims first? I was hoping to pop out the old ones and put in the new ones at the same time but maybe I can’t do that.
  25. XJ550H
    intake .11mm to .15mm
    exhaust .16mm to .20mm
    In:
    1 - .02mm?(.04 wouldn’t fit) tight
    2 - .10mm tight close but still out of spec
    3 - .13mm in spec
    4 - .02mm tight
    Out:
    1 - .13mm tight
    2 - .15mm tight
    3 - .10mm tight
    4 - .18mm in spec
    first step is to remove shims (one at a time) and look on back side to get size. when you have the size you can determine replacment shim size.
    if marking has worn off you will need to measure shim thickness with a caliper.
    you may be able to swap some shims around to bring some valves in spec.
    it is a good idea to have a spare place holder shim or get some plastic place holders from xj4ever, to help with swapping around shims
    get a note book and record shim locations and sizes then when you replace shims record that data too.
    with this info the next time you need to measure and change you will have the info you need to get a new shim
    always keep the history of your measurements.
    then you measure your ignition system record that info too.
    same with charging system voltages and ohms measurements.
    this will all help with future problems that may arise.
    Hogfiddles posted a link above on how to do the shims read it a few times.
    valve shims are the first step in getting bike running correctly.
    if you have access to a compresion tester it would be nice to see those values.
    you could do that now just to see how bringing shims into spec changes those values.
    this will help understand the importance of shim spec,
  26. Mancub
    Mancub Member
    Pleasant Grove
    This is great thank you, it was about as I finished the post after cleaning things up I realized I probably would need the shim sizes inside…
    So I’m going to go back and take each one out, read and record, then I’ll know what I need to get from maybe some of y’all’s extra stashes or somewhere else.
    When I pull them out, before I move to the next one do I have to put that one back in or can I leave them empty knowing I have to replace many of them? Will it cause any harm being empty waiting for the new ones?
    I don’t wanna wait for fakes and I don’t have any spares yet so I just need to know if when I pull it if I should put it right back or if I can pull all the needed ones and leave empty.
    I have initial compressions, and yeah I’ll measure again after I get them in spec that will be cool to see.
  27. Franz
    Don't leave the buckets without shims, you can cause damage if you do.
    hogfiddles likes this.
  28. hogfiddles
    And I run the shim pool so let me know what you need....and feel free to send a pm with your figures and I’ll doublecheck them for ya
  29. Mancub
    Mancub Member
    Pleasant Grove
    Alright! Note to others, after you measure the clearance pull the shims and get the numbers so you can do the math and know your replacements rather than being like me and taking it apart twice haha
    In review now with shim numbers:
    In: 1 - .02mm(285) 2 - .10mm(275) 3 - .13mm (270) 4 - .02mm(285)
    Out: 1 - .13mm(260) 2 - .15mm(265) 3 - .10mm(280) 4 - .18mm (260)
    Soo I’m thinking for the replacements :
    Intake into spec (.11mm-.15mm)
    1. 285 - (.13mm(spec)- .0(measured)= 285-.13=272
    2. 275 - (.13(spec) - .10(measured)= 275-.03= 272
    3. .13mm is good
    4. 285 - (.13 - .0(measured))= 285-.13=272
    Exhaust into spec (.16mm-.20mm)
    1. 260 - (.18mm (spec)-.13(clearance measured) = 260-.05= 255
    2. 265 - (.18mm(spec) - .15mm(measured))= 265-.03= 262
    3. 280-(.18-.10)=280-.08=272
    4. .18mm good
    Ok, I tried to share my math to help but this is the finals please check if I’m right. Also I’m guessing that they come in multiples of 5 so I’m going to round to that number going wider knowing they get tighter over time.
    Need Replacement Shims:
    In: 1 - 272(270 rounding would give me .15mm gap) 2 - 272(270) 4 - 272(270)
    Exhaust: 1 - 255 2 - 262(260 rounding so .20mm gap) 3 - 272(270 rounding so .20mm gap)
    wow that’s a novel, I’m trying to be helpful and organized writing it out. I hope this helps someone some day. You experts grade my work;) thanks!
  30. XJ550H
    In: 1 - .02mm(285) replace with 275
    2 - .10mm(275) replace with 270
    3 - .13mm (270) good no change
    4 - .02mm(285) replace with 275
    intake
    swap cylinder 2 into cylinder 1
    get 270 for #2
    get 275 shim for #4
    Out:
    1 - .13mm(260) replace with 255
    2 - .15mm(265) replace with 260
    3 - .10mm(280). replace with 270
    4 - .18mm (260) good no change
    exhaustt swap cyl 1 shim into cylinder 2
    get 255 shim for #1
    get 270 shim for #3
  31. Mancub
    Mancub Member
    Pleasant Grove
    Thank you, I started a PM with hogfiddles to try and get these shims and contribute to the pool. Hopefully I can get them soon so I can move on!
    Question, on those .02mm measurements, my gauge only went down to .04 and that didn't fit. So its possible that they are just straight .0. So should I go for the 270 instead of 275 on those because it's better to be higher knowing that things get tighter? Curious if anyone else has ran into that decision before.
  32. XJ550H
    if you use a 275 you would be at you should be at .12mm
    if you use a 275 you would be out of spec at .17 mm+
    the valves do not get tighter that fast.
    best option would be pick up a spare 270 and try it incase your 0.02 is 0.00
    what you can do is when you get your shims try one of the 270 shims where the 0.02 intake #1 rotate the motor a few times and measure
  33. Roast644
    Roast644 Well-Known Member
    WASHINGTON
    Just read through your post today and enjoyed seeing somebody starting a project at novice level, which is where I'm at also. The only comment I have is...what in the flippity flop filth and foul did they do to your tank!!!! That looks like it was smashed in a press!! Crazy.
    Best of luck on your bike!
  34. First82maxim
    First82maxim New Member
    Drayton ontario
    looks like i will be in the same boat soon here ! got my junkyard 82 xj650 running pretty good for the first time in over 20 years with just a budget carb rebuild. was not even thinking about checking valve clearances but i suppose if i plan to ride this bike i should take the proper steps. at the same time i have a xj750 sitting right beside if for parts an a good motor so maybe i will overhaul the 750 and prepare for a swap in the future !
    either way this thread has been great for where to go on the next step. looking forward to hearing of everyones progress !
    ps. this is my first motorcycle and am definitely far from knowledgeable on these machines lol
  35. XJ550H
    it is an absolute must to check and bring the valves in spec first.
    that allows you to do a proper running sync.
    any carb adjustments will have to be done over
    doing a running sync before you do the valves is a waste of time.
    First82maxim likes this.
  36. hogfiddles
    The xj750 engine will fit in the xj650. Particulars are available here for doing the swap.
  37. First82maxim
    Drayton ontario
    Might be a dumb question, but will the valve shims from the xj750 work with the xj650 ? might save me from having to buy too many new shims.
    I plan to try and get some measurements tonight and see where im at ! fired the bike up with some fresh oil last night and it definitely ran much worse than previously and almost wanted to run away so i will definitely check the valves before i get the carbs set up. (might still try slapping on the 750 carbs with pods and see how it reacts)
  38. Simmy
    Get a carb synchronizing manometer if you have the bike running now.
    It might be just looking for the final tweak of the carbs.
    They are not expensive when you total up all the parts for a carb rebuild which I recommend you do anyway.
    I like your idea of restoring the 750 motor to swap in.
    But if your 650 is running now just might need a carb sync to ride it.
    Valve shims are the same,
    This Yamaha 1J7-12169-N1-00 PAD, ADJUSTING 2.95 (2.95) fits the following models and components:
    In addition to Yamaha these shims are the same size Kawasaki use.
    Apparently BMW also.
    Yamaha Motorcycle 1982 XJ750J Valve
    Yamaha Motorcycle 1982 XJ650J Valve
    Yamaha Motorcycle 1982 XZ550RJ Valve
    Yamaha Motorcycle 1981 XJ650LH Valve
    Yamaha Motorcycle 1981 XJ650 - XJ650H Valve
    Yamaha Motorcycle 1981 XS1100LH Valve
    Yamaha Motorcycle 1981 XS1100H Valve
    Yamaha Motorcycle 1981 XS850SH Valve
    Yamaha Motorcycle 1977 XS750D Valve
    Yamaha Motorcycle 1985 FJ600N Valve
    Yamaha Motorcycle 1978 XS750SE Valve
    Yamaha Motorcycle 1979 XS750SF Valve
    Yamaha Motorcycle 1979 XS1100F Valve
    Yamaha Motorcycle 1980 XS1100G Valve
    Yamaha Motorcycle 1982 XJ650RJ Valve
    Yamaha Motorcycle 1980 XS850LG Valve
    Yamaha Motorcycle 1982 XJ1100J Valve
    Yamaha Motorcycle 1990 RADIAN - YX600AC Valve
    Yamaha Motorcycle 1986 RADIAN - YX600SC Valve
    Yamaha Motorcycle 1978 XS750E_227 Valve
    Yamaha Motorcycle 1978 XS750SE-31 Valve
    Yamaha Motorcycle 1978 XS1100E Valve
    Yamaha Motorcycle 1979 XS750F Valve
    Yamaha Motorcycle 1985 FJ600NC Valve
    Yamaha Motorcycle 1984 FJ600L Valve
    Yamaha Motorcycle 1984 FJ600LC Valve
    Yamaha Motorcycle 1980 XS1100LG Valve
    Yamaha Motorcycle 1980 XJ650 - XJ650G Valve
    Yamaha Motorcycle 1980 XS1100SG Valve
    Yamaha Motorcycle 1988 FZ600UC Valve
    Yamaha Motorcycle 1988 FZ600U Valve
    Yamaha Motorcycle 1980 XS850G Valve
    Yamaha Motorcycle 1980 XS850SG Valve
    Yamaha Motorcycle 1983 XJ550RK Valve
    Yamaha Motorcycle 1983 SECA - XJ900RK Valve
    Yamaha Motorcycle 1981 XJ550RH Valve
    Yamaha Motorcycle 1981 XJ750RH Valve
    Yamaha Motorcycle 1989 RADIAN - YX600W Valve
    Yamaha Motorcycle 1983 XS400K Valve
    Yamaha Motorcycle 1983 XS400RK Valve
    Yamaha Motorcycle 1986 RADIAN - YX600S Valve
    Yamaha Motorcycle 1987 FZ600T Valve
    Yamaha Motorcycle 1987 FZ600TC Valve
    Yamaha Motorcycle 1985 MAXIM - XJ700N Valve
    Yamaha Motorcycle 1987 RADIAN - YX600TC Valve
    Yamaha Motorcycle 1987 RADIAN - YX600T Valve
    Yamaha Motorcycle 1990 RADIAN - YX600A Valve
    Yamaha Motorcycle 1982 XJ650LJ Valve
    Yamaha Motorcycle 1981 XS850H Valve
    Yamaha Motorcycle 1981 XS1100SH Valve
    Yamaha Motorcycle 1985 MAXIM - XJ700NC Valve
    Yamaha Motorcycle 1986 FZ600S Valve
    Yamaha Motorcycle 1986 MAXIM - XJ700S Valve
    Yamaha Motorcycle 1986 MAXIM - XJ700SC Valve
    Yamaha Motorcycle 1983 XJ750K Valve
    Yamaha Motorcycle 1983 XJ750MK Valve
    Yamaha Motorcycle 1983 XJ650LK Valve
    Yamaha Motorcycle 1977 XS750-2D Valve
    Yamaha Motorcycle 1978 XS750E Valve
    Yamaha Motorcycle 1982 XS400J Valve
    Yamaha Motorcycle 1982 XS400RJ Valve
    Yamaha Motorcycle 1983 XJ650K Valve
    Yamaha Motorcycle 1983 XJ750RK Valve
    Yamaha Motorcycle 1983 XZ550RK Valve
    Yamaha Motorcycle 1981 XS850LH Valve
    Yamaha Motorcycle 1982 XJ750RJ Valve
    Yamaha Motorcycle 1982 XJ550RJ Valve
    Yamaha Motorcycle 1986 FZ600SC Valve
    Yamaha Motorcycle 1988 RADIAN - YX600U Valve
    Yamaha Motorcycle 1988 RADIAN - YX600UC Valve
    Yamaha Motorcycle 1989 RADIAN - YX600WC Valve
    Yamaha Motorcycle 1981 XJ550H VALVE XJ550H J K
  39. hogfiddles
    All xj airhead shims are 29mm shims
  40. hogfiddles
    750 carbs with pods on a 650 are gonna be a hassle..... waaay too much air, too much fuel, etc.....
  41. First82maxim
    Drayton ontario
    If anything I will try and make my own carb sync tool, cant say i want to spend the big bucks for something i wont use much. this is a very budget build and would love to keep it that way
  42. Huntchuks
    East Rochester, NY
    https://www.xjbikes.com/forums/threads/homemade-manometer.126761/
    This is a bit fancy, as Polock says, but you can do something less fancy but similar for transmission fluid. Better (more accurate) than any bottle method but you would need to use much longer tubing since any regular liquid is much less dense than mercury. There are many videos on YouTube about this.
    Simmy and First82maxim like this.
  43. First82maxim
    Drayton ontario
    I'll see what supplies I got laying around and see what I can make up ! Probably try some clear line and some ATF see what happens. also plan to try syncing carb 3 and 4 together first, then 1 and 2 together, then i will sync 3/4 to 1/2 using just a 2 chamber tester. this seams to be an easier route according some research.
    this is all trial and error and i'm not scared to mess up so i'll give it a shot !
  44. Huntchuks
    East Rochester, NY
    Check YouTube videos, the length needs to be longer to prevent fluid from being sucked into your engine. Also make sure you use restrictors, they have a very small hole to restrict rapid/large fluid movements.
  45. hogfiddles
    It’s a hot-button debate issue (YICS tool).....
    But as far as I’m concerned, you don’t need to do that. Unless you’re racing and trying to wring out that last 1/100th of a second, don’t worry about the YICS tool. Just balance the carbs (running sync).
    I have one, never needed it, still in the plastic
    cgutz and First82maxim like this.
  46. First82maxim
    Drayton ontario
    well that's good to hear ! if I can get this bike running good enough to boot around some back roads and get me 25 minutes to work and back (also back roads) i'll be more than happy ! $200 bike to save on some expenses with my diesel pickup truck lol
    I plant to play around some more this week but we got snowy weather back here in Ontario so i'm in no rush until it melts again
  47. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Huntchuks likes this.
  48. hogfiddles
    Yup, just need to balance the carbs......Many homemade ones work just fine.
    personally, I’d recommend springing for the Morgan CarbTune Pro.... you’ll end up using it A LOT— you’ll be the guy everyone comes to, and you’ll end up hosting your own carb clinic in your area, and 15yrs from now, you’ll be looking back saying “man this is fun....” :)
    And someday you might even have a YICS tool that you never use, too.....
  49. First82maxim
    Drayton ontario
    Okay well this week I'll have to rig up something and get the carbs balanced ! really wanted to get at it this weekend, but the home renovations take priority in the Mrs. eyes lol still running the homemade pod filters so might get something a bit better ordered for it this week too. my plan is to tig weld up a custom 4 into 1 intake then use a single filter positioned where the old box was. hopeful this works for something a bit different
  50. Simmy
