Beginner restoration of a 82 XJ550 Maxim
Discussion in 'Hangout Lounge' started by Mancub, Mar 2, 2021.
  1. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Here is the part from Len's catalog:
    HCP5191 OEM single FUEL INLET - FLOAT VALVE ASSEMBLY, fits all XJ550, 1980-82 SR250 Exciter, 1980-82 XS400 Specials, 1984-85 FJ600, all 1980-84 XS650, XJ1100, and all 1980-81 XS1100 carbs. Includes the float valve brass seat, the needle with its retaining clip, and the seat o-ring. The filter screen for the brass seat is included. Each:
  2. Mancub
    Mancub Member
    Pleasant Grove
    The question would be then if you can just get the O-ring and if that fits on the original seat. Or if that only goes with the full assembly kit. Surprised those O rings aren't in the carb rebuild kits, seems like an important piece of rubber that could wear out.
  3. Huntchuks
    East Rochester, NY
    The o-ring really shouldn't wear out too easily. Looks to me, for my carbs, the OD is about .330", thickness .078" (2mm), ID around .174". Coat o-ring with silicon before inserting seat into the carb body.
    Mancub likes this.
  4. Mancub
    Mancub Member
    Pleasant Grove
    Picture for reference, the o-ring is no longer rounded, it's flat like the body of the seat. That's why I thought you couldn't replace those, maybe that's the culprit for the leaking.
    No to figure out how to wet set the dang things and not be conquered again!
  5. Mancub
    Mancub Member
    Pleasant Grove
    Gentleman and thanks to the wizard of the week @Huntchuks we have solutions.
    Soo after a quick trip to O'rielly, $2.50 and 4 #010 o-ring (close to the OD .32 ID 1.8) those fit on the needle seat body. From my pic you can see the old one is flat and was sneaky I didn't even realize it was an O-ring.
    I just replaced all those O-rings, adjusted the float level to 21.5mm to the top of the floats. Then I filled and checked, had to tweak one or two to get them all within 2mm from the bowl lip on the wet set measuring. The trick was mentioned, pull the hose higher than the drain so that it fills without bubbles. I actually think it was less that and more that by the time I was measuring the bowls would give me one reading, then when I came back to check it was higher, and then leaking. That was why I was so frustrated thinking I was doing the tube wrong, but it was the leak.
    Let my experience be a lesson to someone who reads this haha. (I left them sitting while I typed this, and so help me if I go out there and find it's leaking again hahaha)
    Next up:
    - Remount the carbs
    - Screw in the new rebuilt fusebox (I was having electrical problems on starting, would have to push the old fuses with my finger till I would hear a click then could start)
    - Replace the oil, oil filter, oil filter ring, crush washer
    - Double check my valve clearances
    - START THIS PUPPY UP
    - Do a carbtunePro vaccum sync, anyone have a good step by step for using that tool and doing it right? I know I saw it somewhere I can start googling the forum again.
    - Remount the tank
    - go for a ride and test out my new brake job, tires, chain adjustment and all the thingssss. I can maybe see the light at the end of the tunnel
    Am I missing anything?
  6. chacal
    They're included in all of our carb rebuild kits......... :)
  7. Mancub
    Mancub Member
    Pleasant Grove
    For the vaccum sync. I neighbor has a two port manometer. It seems like that would work right? The manually has you just do two at a time anyways.
  8. Dan Gardner
    Minneapolis, MN
    You can get away with two port.
    I don’t know the exact procedure but it’s something like sync 1-2, then 3-4, then 2-3. Something like that
    if you find the proper procedure it should be fine - just a little more work
  9. Mancub
    Mancub Member
    Pleasant Grove
    So with the YICS engine, what are the special things I need to do for the running vacuum sync. I think I understand pulling the plugs and putting on the vaccum hoses, then watching the levels and tweaking the butterfly sync screws to get two in sync at a time. But whats the YICS port or tool? And what is YICS anyways! haha
  10. Mancub
    Mancub Member
    Pleasant Grove
    Okay I had a second to look into YICS I understand what they were trying to with it from the factory.
    However advice on if I need to buy a tool, or if I can just hook up the carbtune and go for it. Also if I do need the tool, how do I use it properly for the vacuum sync of the carbs. Resources would be great. Thanks.
  11. Roast644
    Roast644 Well-Known Member
    WASHINGTON
    The factory correct way is to synch with the YICS tool. But you can do it without blocking the YICS passages also. I don't know if its a 50/50 split in the way guys do it here, but many, many synchs have been done without it.
    I would suggest doing it without for the first time just to avoid the tool cost, get things running, log some miles....and then in a year if you are still a diehard XJ guy, buy the YICS tool and try it that way and decide which camp you fall into.
    Mancub likes this.
  12. Dan Gardner
    Minneapolis, MN
    The debate over whether or not a block off tool is necessary to do a carb sync has been raging for a long time.
    Lots of people say you don’t need it. I don’t know, but I have a tool and Yamaha says to use it, so I do.
    In your case, I think it would be fine to proceed without it. It is not something that is going to make it break the build. Worst case Ontario you will need to re-do it at some point. Not a huge deal.
    Mancub, Timbox and Roast644 like this.
  13. Mancub
    Mancub Member
    Pleasant Grove
    Thanks guys, that's the type of wisdom I needed. I just didn't want to do something that will ruin or be the reason the bike won't run right. I get that might be the way to get it more exact, but good to hear that's down the road as I decide how much of a "diehard XJ guy" I wanna be.
    Exciting! Last night I checked the valve clearances again. They are good. So now I'm hoping to mount those carbs, do a quick oil&filter change while I'm at it just to be safe (I think the leaky needle seats might have let gas into places). Now with the brakes done, tires, carb rebuilt and CLEAN, bench sync and wet set done.... I hope this thing runs like it's supposed to, I've never seen that yet. Always had some issue so far in this restoration.
    Question, the vacuum sync tool is still on it's way, would you guys say it's cool to ride around on it while I wait for that to come? Or should I wait till then because the idle/running/whatever is going to be off or hurting something until I do sync it?
  14. Roast644
    WASHINGTON
    If you do a careful bench synch, and start it up and it idles, responds to small changes in the idle screw (the big horizontal adjuster between #2 & #3), responds evenly to changes in the choke lever, and all 4 are firing at idle (check the exhaust headers for heat) then its as close as you can get without the vacuum gages. Then absolutely go ride. You won't damage anything.
    Typically though before synching you get erratic idle, poor choke response, missing etc. Tiny changes in the butterfly don't mean that much at half open, but if you can't get it to idle its not very enjoyable to ride. I wouldn't say you'd damage anything like this, but your poor starter might get a workout.
    Vacuum synching can feel magical sometimes, going from "Holy crap this engine is shot" to "Purrs like a kitten" with a tiny twist of the screw.
  15. Mancub
    Mancub Member
    Pleasant Grove
    How exciting, I dream of it purring haha Sounds good. Thank you.
    Surely I'll be back here soon. I should get an award on consistent effort over time for a newbie haha
  16. Mancub
    Mancub Member
    Pleasant Grove
    Good news after a rebuild haha I can fire it up! I need some tips though.
    Manual says to get the bike using the idle screw to around 1200 rpm before you start adjusting... well I'm having a hard time getting it to sit steady at 1200 on idle. How much do you have your idle screw in typically? I started with it at none, and feel like I've added quite a bit.
    I've had a few spikes in rpms as I'm putting choke and no choke just to try and start it up. @Roast644 your right I would give my starter a workout I can see that. I'm hoping all i'm facing is not being synced right. I'm trying it on a digital 2 port. I just can't get it steady enough without giving it throttle to stay alive to really get any good results...
    Anyways, tips on how to get it right. Do you leave a little choke to just keep it running and begin the balance? Is there something else happening? Seems odd. My carbtune doesn't come for a week so I I'd like to get it somewhat balanced as I wait. But yeah... can't get it stable enough to sync. The bench synce was a pretty dang close on a paper clip end just as a heads up.
  17. Roast644
    WASHINGTON
    The 2 port vacuum gage you are using is digital? I haven't seen one like that but I can imagine that makes it really difficult. Typically on an analog gage the needle is bouncing and you use the needle valve to quiet it down, but still might have to split the difference.
    It sounds like you're experiencing typical issues that the sync will resolve. Maybe somebody here uses digital gages and has some tips for you.
  18. Dave in Ireland
    Ireland
    A digital gauge using the vacuum pipery will respond to clamping the pipe, exact same way as an analogue gauge.
    Aquarium air pipe clamps.
  19. Mancub
    Mancub Member
    Pleasant Grove
    I think I'm just going to have to do the analog, the digital (even with the claps is jumping around)
    However. If you can't get it to idle around 1200 before syncing do you just start doing a little bit even with a little choke or something and then bring it down, and just keep running the cycle till it works?
  20. Huntchuks
    East Rochester, NY
    Syncing should be done with a warmed up (hot) engine with no enrichment, I believe.
  21. Mancub
    Mancub Member
    Pleasant Grove
    Yeah I can see that ideally you have it warmed up and idling with no choke at like 1200 before you do the final sync.
    I'm just struggling to get it stable and idling at 1200 to start, so I'm thinking I might have to tweak some to get it closer and then eventually resync it once I can get it to idle with no choke, then I can do the final.
  22. Mancub
    Mancub Member
    Pleasant Grove
    Hey guys! Well it's been about a month I've actually be riding the bike around, to and from work, it's working! hah what a journey.
    Now I'm starting to think of what's next, and noticing some things that aren't working right or need help.
    1. I noticed for some reason that the blinkers aren't working right... I redid the fusebox, and I did notice that before they had bypassed the box and just butted the signals line. Not sure what changed there.
    2. My exhaust pipe has some holes in it, I can feel little puffs of air. Are there ways to repair that, is it a replace thing, or is it a don't worry about it thing
    3. Riding around is stiff and rattley as could be, guessing that back shock is not doing much.
    4. I have an oil leak I think from the head plate, the gasket seemed ok when I was in there, I'm thinking it might be that those pressure washers on the inside and out are flat.
