Bench Sync Question
Discussion in 'XJ Technical Chat' started by chris123, Sep 5, 2023.
  1. chris123
    chris123 Active Member
    Benicia, ca
    I’ve read through the Bench Sync tutorial , but I have a quick question:
    What position should the idle adjustment screw be in when I start the bench sync process?
    Totally clockwise? Totally counter-clockwise? Or right in the middle?
    Thank you for all the help!
  2. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Can't remember where mine was, but it wasn't completely closed. I would think that as long as the plates can close completely you would be ok. But, I'm sure someone else with more knowledge will speak up.
    chris123 likes this.
  3. chris123
    Benicia, ca
    Thanks for your reply.
    I worked it out. I think it’s a hard thing to explain, probably why no one replied.
    I ended up starting the bench sync with the idle adjust screw about three turns past contact.
  4. Roast644
    Roast644 Well-Known Member
    WASHINGTON
    3 turns past contact works. Sounds like you figured it out. The amount #3 carb butterfly is open doesn't matter, as long as you can make the others match.
    Shim method with business card, paper clip or drill bit.
    Visual reference using pilot screw holes or sliver of light.
    Many methods, whatever makes you happy. These are all semi-crude precursors to a vacuum synch anyhow.
    JCH and chris123 like this.
  5. DaRealSanti
    DaRealSanti New Member
    Philadelphia
    Chirs could you share the link for the Bench Sync Process?
  6. chris123
    Benicia, ca
