Bend your ear ? 1982 seca 650
Discussion in 'XJ Technical Chat' started by Moto psycho, Apr 25, 2018.
  1. Moto psycho
    Moto psycho Member
    Xenia ohio
    I went to start my 1982 seca 650 after I did my carbs new p pilot jet main new needles and now it's only firing on cylinders 2 & 4 but they all have compression and Spark it will start and it won't let on better than during throttle it will block it will not take off as soon as you engage the clutch it will stumble so hard and it wants to die all of this is with the choke disengaged
  2. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Does it fire on all 4 with choke on? If so, you may have a big air leak or the pilot screws may be closed too much.
  3. Moto psycho
    Moto psycho Member
    Xenia ohio
    There is spark and compression and the plugs are wet the plugs are all brand new could it be a synchronization issue?
  4. tabaka45
    Brunswick, Georgia
    Getting way too much gas if the plugs are firing but still wet. Did you do a wet setting of the float heights? Is the enrichment circuit leaking? Pilot screws could be open way too much.
  5. Moto psycho
    Moto psycho Member
    Xenia ohio
    I did not do a wet set on the floats but I got them to the specified height and you mean the idle adjustment is open too much because if you get it up too 3500 RPM it will smooth out of bed but if it's under load it will bog
  6. tabaka45
    Brunswick, Georgia
    You have to wet set the floats. The “specified” setting is just a starting point. Especially if you installed new float needles.
  7. Moto psycho
    Moto psycho Member
    Xenia ohio
    I did but they were OEM parts all stock how do you wet set ?
  8. chacal
  9. Moto psycho
    Moto psycho Member
    Xenia ohio
    That was a good post thank you carbs are coming off tomorrow .. again
  10. tabaka45
    Brunswick, Georgia
    Thanks, Chacal. I was looking all over for that link.
    Moto psycho likes this.
  11. Moto psycho
    Moto psycho Member
    Xenia ohio
    So I adjusted the float hight ( out of spec) bike is running good on all four ! Thanks you guys but now my rpms hang on deceleration a little bit??
    kosel likes this.
  12. tabaka45
    Brunswick, Georgia
    Did you do a running sync of the carbs?
  13. Moto psycho
    Moto psycho Member
    Xenia ohio
    No that is a job for Friday I have to build a bottle rig wich I have never done also after I put my tank back on my turn signal stays solid instead of flashing?
  14. tabaka45
    Brunswick, Georgia
    Syncing will probably solve the hanging idle. Someone else will have to help with the electrical issues.
  15. Moto psycho
    Moto psycho Member
    Xenia ohio
    I think it's just grounding out somewhere and did it once before but I can't remember how I fixed it
  16. tabaka45
    Brunswick, Georgia
    Be sure to use glass bottles--plastic bottles will collapse.
  17. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Could be the throttle cable, has it been inspected and lubed?
  18. Moto psycho
    Moto psycho Member
    Xenia ohio
    Cable was new at the end of last season
  19. Moto psycho
    Moto psycho Member
    Xenia ohio
    Should I sync them to the third cylinder or the one with the lowest pressure?
  20. cgutz
    cgutz Well-Known Member
    SE South Dakota
    I believe it is the same process as my XJ550:
    Synch #1 to #2 using screw 1
    Synch #3 to #4 using screw 3
    Synch 1/2 to 3/4 using screw #2
    Someone correct me if my memory is failing....
  21. tabaka45
    Brunswick, Georgia
    With my two bottle set up I used 2 and 4 for the final sync, but any combination of using either 1 or 2 to sync with either 3 or 4 will work.
  22. Moto psycho
    Moto psycho Member
    Xenia ohio
    This is why I ended up with but it's airtight
  23. tabaka45
    Brunswick, Georgia
    That should work fine as long as the tubing fits tightly on the vacuum nipples and everything is air tight.
  24. Moto psycho
    Moto psycho Member
    Xenia ohio
    It's quarter inch internal diameter but I have hose clamps as well if need be
  25. Moto psycho
    Moto psycho Member
    Xenia ohio
    The first screw ajust carb one on cylinder one correct ? Seems to make no difference to vacuum
  26. Moto psycho
    Moto psycho Member
    Xenia ohio
    Cylinder 2 is much stronger then one
  27. tabaka45
    Brunswick, Georgia
    There are 3 screws. The screw on the left is used to sync cylinders 1 and 2. The screw on the right is used to sync cylinders 3 and 4. After getting these two set in sync, then attach your tubing to vacuum ports #2 and #3 and use the middle screw to sync the which puts all cylinders in sync.
    While doing all of this make sure to hav a fan blowing to cool the engine.
  28. Moto psycho
    Moto psycho Member
    Xenia ohio
    No matter how far I go it does not a thing ?
  29. Moto psycho
    Moto psycho Member
    Xenia ohio
    The first screw is currently bottomed out to the right even if I open it all the way up turning it to the left it does nothing
    to the pressure and the vacuum bottles
  30. tabaka45
    Brunswick, Georgia
    If you have the two tubes attached to the #1 and #2 vacuum ports and turning the screw between them makes no difference then either your two bottle manometer is not set up correctly (possibly an air leak), your starting beach sync is way way out, or perhaps there is a big air leak around the carbs. Also could be that the carb linkage is not set up correctly.
    Try switching the tubing. Put your finger over each vacuum port and see if you feel vacuum. Unless your piston has a big hole in it it has to pull some vacuum. You might do a compression test on the cylinders.
    Put your tubing on #3 and #4 and see what you get. Hopefully, it is something simple that you are missing.
  31. Moto psycho
    Moto psycho Member
    Xenia ohio
    I'm leaning towards the man I'm either having a leak I've sprayed starter fluid around the boots and there is not a rise in RPM
  32. Moto psycho
    Moto psycho Member
    Xenia ohio
    It's that srew is it not ?
  33. tabaka45
    Brunswick, Georgia
    That is the screw. I’m still a little worried about the size tubing you are using. Also, did you start with fluid in both bottles? It looks like one is empty in the picture.
  34. Moto psycho
    Moto psycho Member
    Xenia ohio
    The outside of the tubing is thick but the internal diameter is 1/4 and I started with two bottles that were half full and an it all got sucked into the second cylinder bottle almost immediately and will not disperse back
  35. Moto psycho
    Moto psycho Member
    Xenia ohio
    Ok it's moving now but it won't sit even it's very close is it but not equal
  36. SQLGuy
    SQLGuy Well-Known Member
    For the turn signals: are both lighting and not flashing, or is only one lighting? If only one is lighting, of course make sure the bulb is good, but also you may need to disassemble and sand/brush the spring and washer and any other contact pieces inside the base of the turn signal. If both are lighting but not flashing, check that the bulbs are the correct type (should be 27W 32CP aka 1156).
    If they are both lighting and are both the correct type, then you probably need a new flasher module.
  37. tabaka45
    Brunswick, Georgia
    Getting the fluid level and constant takes patience and very small adjustments. It doesn’t take much to cause it to overshoot. Sometimes I thought I barely touched the screw. You will get the knack of it pretty soon.
  38. Moto psycho
    Moto psycho Member
    Xenia ohio
    They both light and say solid
  39. joejr2
    Santa Fe,NM
    the tubes look too fat to me. try some of that 1/8" vinyl tubing they sell at tractor supply or home depot. heat the tips to fit over the vacuum ports and seal the holes where the tubes penetrate the rubber corks with silicone.
  40. SQLGuy
    And are 1156s, or equivalent, 27W lamps?
  41. Moto psycho
    Moto psycho Member
    Xenia ohio
    So since I tried to sync my carbs I have found a air leak in the second intake boot but I just want to replace all four but I can't find them anywhere??and I need the gaskets to it's my understanding that the left two boots in the right two boots are a different size?
  42. XJ550H
    different part numbers because of the mounting studs
    try emailing len at www.xj4ever.com he should have them.
    you can clean boots off with carb cleaner then coat with black oil resistant rtv this is what was done before boots became available. if you want you can also wrap them with an innertube over the rtv.
  43. XJ550H
    clean the bulb sockets and wiring connectors. the relay can be popped open and cleaned too.
    sometimes a bulb will light and still be bad. or your connections in the headlight bucket are to the wrong connectors check the wire colors.
    chocolat (dark brown) and dark green for power and black for ground
    if you still have the canceling unit start by unplugging it
  44. tabaka45
    Brunswick, Georgia
    I cut gaskets out of gasket material I got at the local auto parts store. I would try the black rtv and then wrap them tight with self amulgamating tape. That stuff works great.
  45. Moto psycho
    Moto psycho Member
    Xenia ohio
    Just paper ? I thought it was supposed to be metal
  46. XJ550H
  47. tabaka45
    Brunswick, Georgia
    Not just paper, but gasket material for heat applications. Probably has asbestos in it, but easy to cut. As the parts store.
  48. Moto psycho
    Moto psycho Member
    Xenia ohio
    I'm going to try and save them if I can I'll post pictures of the damage tomorrow
  49. Moto psycho
    Moto psycho Member
    Xenia ohio
    What would you recommend I use to re bench sync my carbs
  50. tabaka45
    Brunswick, Georgia
    I used an index card cut into 1/4 inch wide strips.
