bensalf's 4 year caferacer build
Discussion in 'XJ Modifications' started by bensalf, Dec 26, 2015.
  1. chacal
    Excellent idea, consider it done.
    Beautiful work, I think you give Wizard and BigFitz a run for the money........
  2. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    oh ,no , they're way above my league.
    I only got this far ,from litening to them, and reading , (and taking heed) of all the info on here.
    thank you all for your comments so far
    stu
  3. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Thanks. I think future members will enjoy this build as much as the others. Camelman and Salty Dog's 1100's is another one of my favorites.
    Gary H.
  4. bensalf
    yorkshire ,england
    so-- on with the build,
    and so to the er, -----carbs--------- the subject of so many posts on here.
    and I can only endorse the advice in "the church of clean" and the whole 9 yards.
    they were in a bit of a state, throttle shafts were seized solid.
    soaked the throttle shafts in paraffin overnight, and managed to free them off.
    broke the rack apart and started to strip each carb
    whilst stripping the carbs down , I noticed this tiny ball bearing ,on the bench towel. I hadn't a clue where it came from, and there was no reference to it in the Haynes, or on here, you can see it here at the end of the ruler
    then I found another bxgger,so I had to take a closer look at the carbs.
    and this may help others working on carbs
    what I found ,was that where the enrichment shaft slides through each carb, on #2 and#3 carbs, there is a tiny spring and ball ,that locates in a notch on the enrichment shaft ,to keep it in position, very lucky I found these
  5. 81550Seca
    81550Seca Member
    Yakima, WA
    This is all looking f'ing pretty!
  6. bensalf
    yorkshire ,england
    continued to strip each carb
    marked up the butterflies for which way round and which way up
    sprayed up the carb bodies, new throttle shaft seals obtained, cleaned all passages in each carbs,
    started rebuilding carbs
    wet set the floats using a plastic jug I made to fit under each carb, using a dummy tank, to fill the jug, and allow the floats to rise
    sprayed up the carb brackets ,also had the middle 2 carb hats chromed, and stainless steel screws fitted all round
    stu
  7. Polock
    Damm, you do nice work. Are you really going to ride it?
  8. bensalf
    yorkshire ,england
    onto the carb to head boots, they weren't in too bad condition, but had slight cracks on the outside, but not all the way through. new ones were almost £100
    and good used ones were unobtainium. so I decided to repair them, I've seen the innertube method used on here, but as I was an electrician by trade in my working days
    I looked into getting some heatshrink tubing to do the job.
    I got hold of some 4" tubing with 7 times shrink ratio.
  9. bensalf
    yorkshire ,england
    already have, only done about 50 miles last year before the weather turned bad.
    stu
  10. bensalf
    yorkshire ,england
    test, tried a piece on a scaffold pole
    shrank it with blowlamp
    all seemed ok . so onto the boots
    cut some strips the same width as the boots ,put a pin hole in to slot over the vacuum tube.
    smeared some black silicon sealant over the boot spigot and shrank the tubing on, but just enough to grip the boot.
    all 4 done and blanking caps fitted to the vacuum tubes
    test tried boots onto carbs, all ok
    stu
  11. Urra
    Urra Member
    Miami, FL
    This makes me want to take my bike apart ten times over and scrub with a nylon toothbrush until everything is spotless>.< I wish I had these tools! Awesome work mate
    jordan smith likes this.
  12. bensalf
    yorkshire ,england
    thanks for your comments ;)
    having some problems with photobucket at the mo, I may have used up my allotted space,
    although it says I have only used 28 %? be back soon!!
    stu
  13. bensalf
    yorkshire ,england
    onto the airbox now.
    I wanted to keep the area at the back of the engine , under the seat, as clear as possible ,to create that open look, that is recognised as a café racer.
    but at the same time didn't want to go down the "pod" route.
    so I made provisions to house all the electrics in a shallow underseat tray, and to move the battery back into the seat "hump".
    so next to modify the airbox, to make it smaller and much shorter.
    so I cut the air filter housing ,away from the airbox.
    enlarged the hole to take a circular filter
    this filter is for a Honda 90------oh well ---nothing ventured.
    enlarged the hole in the filter to allow more air
  14. bensalf
    yorkshire ,england
    made a plate to mount the filter to the airbox
    here's the filter mounted inside the airbox
    plate cut out and mesh and venturi fitted
    stu
  15. bensalf
    yorkshire ,england
    here's the modified airbox sprayed up and fitted in frame
    with filter about to be screwed in
    here's the airbox all finished with venture fitted
    incase you're wondering where I got the venturi,
    its -----er-------- a cooling fan venturi ,from inside an old computer tower system
    stu
  16. bensalf
    yorkshire ,england
    next the under seat tray to house the electrics, these will be .......
    battery, tci unit, reg/rectifier unit, battery isolator, card reader ignition , fuse box, ignition relay, voltage regulator for card reader. and starter solenoid
    also rear reservoir for rear brake ,and tool space.
    obtained some 1.5mm alloy plate
    here's the tray polished and bent to shape with corners welded up, cut outs for frame tubes done
  17. bensalf
    yorkshire ,england
    here it is in the early stages, test fitted to frame, also added the small alloy angle, for the seat rails.
    researched the sizes of batteries and amp/hour ratings on the "yuasa" website, and made a block of wood ,the same size as the battery will be, as a test fit for the seat to fit over
    stu
  18. k-moe
    You are making the winter easier to bear.
  19. bensalf
    yorkshire ,england
    ha,ha, yes I'm already well into my # 2 xj600.
    stu
  20. bensalf
    yorkshire ,england
    back to the tray, here it is with the seat hinged back over, the battery-- er---block of wood, and concealing the tray.
    and here it is on its final fit
    here's the tray , later , filled with the gummings.
    stu
  21. bensalf
    yorkshire ,england
    now , onto the exhaust and footrest hangers.
    this is the original pig-iron hanger, so I decided to move the footrests back, and up ,to make the caferacer position easier with the
    new clipon and lowered handlebars, to give the laid down look.
    so the hangers had to go.
    I mocked up some hangers out of white conti-board. to try the position.
    also I bought 4 shorty silencers, so I could have 4 stainless steel exhaust pipes custom made, into a 4 into 4 system
    at this , I loaded up the bike, and took it 80 miles to a firm of stainless steel fabricators to have the 4 pipes made.
    they had the bike over a month, as they are normally out on site ,making stainless steel pipes for the food industry.
    bikes are their spare time work.
    eventually collected the bike with the pipes fitted, all pipework was tucked underneath the bike as instructed.
    stu
  22. k-moe
    Hey now...those hangers are made from the highest quality pig-ALUMINUM. ;)
  23. bensalf
    yorkshire ,england
    quite right!!----- but they're piiiiiiiiiiiig ugly:eek:
    stu
  24. bensalf
    yorkshire ,england
    I obtained some 10mm alloy plate from a local scrap metal dealer," quite cheap".
    after reshaping the wooden hangers I made, and working out where the pivot point should go for the gear linkage and brake pedal, I marked the shape out onto the plate.
    first test fit on r.h. side
    extra holes drilled and started to polish up
    here it is fitted ,with brake pedal and master cylinder fitted and footrest bracket and exhaust bolted on.
    l.h. side, with pivot hole for gear linkage ,footrest bracket and exhaust hanger
    stu
  25. bensalf
    yorkshire ,england
    now for the gear linkage, as I moved the footrests backward and upward, then the original lever would not reach my foot.
    heres the original set up
    note the lever moves on a dummy shaft and is not fitted directly on the splines.
    so I needed a longer linkage, and also to keep the linkage away from my foot I needed a lever with the pivot on top.
    I managed to find one on ebay , from a Kawasaki gp500, that was the correct orientation, and length, also it meant the gears were still in the original place.
    i.e. 1 down and 5 up
    cleaned up the lever and had the linkage rechromed
    result.
    stu
  26. bensalf
    yorkshire ,england
    onto the chain guard, which is a bland plastic one.
    [​IMG] [​IMG]
  27. jayrodoh
    jayrodoh YimYam
    Cleveland
    Stunning work!
  28. bensalf
    yorkshire ,england
    thank you for your comments, apologies for some of the blurry pictures.
    decided to make a new chainguard form ally plate.
    marked out the shape of the plastic one ,onto the plate ,and cut it out.
    drilled some holes along the length, and bent it to shape.
    wired the bent bit at the end, and had it ally welded up
  29. bensalf
    yorkshire ,england
    polished up and fitted.
    stu
  30. bensalf
    yorkshire ,england
    next onto the oil cooler. matrix was pretty well mashed up
    split a clothes-peg in half ,and shaved the ends down, and began the painstaking task of straightening each fin out,
    nearly there
    done what I could, and sprayed up
    also found out the oil cooler pipe ends are brass!!, polished these up
    made a mesh guard for the front of the cooler
    stu
  31. chacal
    Just stop it, for goodness sake!
    You're making the rest of us look bad........ :)
  32. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    This bike is gonna be insane! Magazine quality!
  33. bensalf
    yorkshire ,england
    can't stop now ,, otherwise it never happened;)
    stu
  34. bensalf
    yorkshire ,england
    onto the electrics now , and this was my trade till a few years ago, when I retired from house bashing!.
    first I unravelled the outer tape from the entire harness, and replaced with zip ties.
    then I pulled out all the wires I wont be needing, like feed up to the front ignition switch, auxillary feed for parking lights .
    and run in new wires for ,sump temp sensor, wires for card reader ignition, and for acewell digital dash.
    taped back up with new loom tape.
    next the handlebar switches, they were pretty gunged up inside
    sprayed up the housings also painted the switch knobs yellow.
    had some new stickers made up at a local sign shop, these applied and clear-coated over
    stu
  35. MattiThundrrr
    Did he say "card reader ignition"?
    Yes. Yes he did.
    Mind fully blown.
  36. mc1oo1
    mc1oo1 Member
    LB,Ca
    NOICE!
    Ive thought about making new stickers for my switches but instead of the general stuff I would put something like this.
  37. bensalf
    yorkshire ,england
    /\--------/\--------/\---------/\ :D:D:D
    stu
  38. bensalf
    yorkshire ,england
    ok, ok, the card reader ignition, its nothing flashy or complicated, its a standard card reader, normally used to open security doors.
    as I did away with the yoke mounted key ignition, to make way for the digital acewell dash. I mounted the card reader under the seat, to the underside of the electrics tray
    When you think about the positioning of the electrical components on a motorcycle, for example the feed for ,say, the rear lights.
    the feed goes from the battery, (in my case in the rear seat hump" ), up to the ignition switch, back to the fusebox, back up to the light switch, and back to the rear lights
    this circuit is somewhat shortened by moving the ignition switch, near to the battery.
    any way here's the card reader.
    there's a little red light on the reader, and basicly , you push the card inside ,red light turns to green, this switches a relay, turning on the ignition.
    the only difficulty was the reader needs a 9 volt supply, which I obtained using a small electronic voltage regulator, they're only pence, from a local ,radio shop.
    here's the complete ignition circuit
    this is a voltage regulator, they're only tiny, but they get hot, really hot, they need a heatsink to stop them overheating.
    you can see it here on the top left of the seat tray , mounted on the heatsink.
    stu
  39. bensalf
    yorkshire ,england
    next I decided to fit a battery isolator, as this will be only an "occasional" bike, so I could turn everything off when not in use.
    you can see the isolator knob in the above picture, to the right side under the battery
    here's a stand I made to sit the battery on top, and the isolator underneath.
    stu
  40. bensalf
    yorkshire ,england
    found a nice ,new 7" chrome headlight on ebay quite cheap.
    stu
  41. bensalf
    yorkshire ,england
    I also decided to fit a couple of small front running lights ,either side of the headlight.
    looked at various types of lights, but found most automotive led lights were too large and expensive.
    but found that the small led torches can be found in all sorts of sizes and very cheap.
    I settled on these tiny torches, but they run off small 6volt button cell batteries, so I would need to convert them to 12volt.
    I needed to reduce the voltage from 12volt to 6volt to run the lights, there are a couple of ways to do this.
    one is to use the small "transistor" type voltage regulator, that I used for the card reader.
    but these were too large to fit inside the torches, and the heat would be to great to dissipate from inside.
    I could have mounted the regulator and heatsink inside the headlight.
    but I decided to use 2 small 1 watt resistors, inside the torches ,to reduce the voltage.
    I got rid of the torch batteries and push button switches, from the torches , soldered some wires directly onto the led circuit board, to test try them
    here they are lit, from a 12volt battery charger
    made some small brackets and mounted the torches onto the indicator stalks
    here they are running from the bikes 12volt system with resistors soldered inside
    stu
    Urra and BJ Ramirez like this.
  42. mc1oo1
    mc1oo1 Member
    LB,Ca
    YES!
  43. Polock
    pretty sure when you turn off the battery your Acewell is going to loose it's wheel circumference setting. better write it down somewhere
  44. bensalf
    yorkshire ,england
    nope,! I enquired from acewell before I bought it, the only thing that is lost is the time clock, used it several times and all other settings are retained.
    stu
  45. bensalf
    yorkshire ,england
    here's the acewell mounted on a bracket I made, on top of the triple tree.
    I made some tiny led idiot lights for the L and R indicators (orange) headlight (blue) neutral (green) and oil level (red).
    and mounted them in the acewell surround
    here it is powered up with most of the sensors set up
    this is an amazing little machine , it cost around £130 all in, with the various sensors.
    it does, ----- mph,,----- rpm, bar graphic and analogue,------ fuel level,----- engine temp,------ clock,------over rpm warning, light------
    --over temp warning light, ----gear indicator, (haven't set that up yet), -------volt meter, ------2 x trip meters------riding time ------ highest speed.-----
    neutral indicator------average speed, and possibly some more indicators
    stu
    BJ Ramirez likes this.
  46. bensalf
    yorkshire ,england
    next up were the rear lights, I decided to incorporate these in to the back of the seat
    I bought some led rear ,stop/tail bulbs, and set about finding some 19mm inside dia, plastic tubing to house them in
    I found that the legs off kitchen cabinets were the correct size.
    I cut 3 lengths and cut 3 holes in the back of the seat, to resin the tubes in.
    here's the finished article
    stu
  47. k-moe
    If you find that the LED warning lights are too bright for nighttime use they can be dimmed by coloring over the lenses with a black permenant marker. It's just enough to dim them for nighttime use and still let them be easily visible during the day.
    Your patience with the details shows.
  48. Blackfnttruck
    Blackfnttruck Member
    Harrisburg Pa
    OK....wow...just wow...that is one fantastic build, nice work.
  49. mc1oo1
    mc1oo1 Member
    LB,Ca
    Urra and MattiThundrrr like this.
  50. bensalf
    yorkshire ,england
    yes, apart from the turn signal indicator lights, the only other one that will be lit at night whilst riding would be the blue, headlight indicator, oil and neutral would be off.
    I could increase the size of the in line resistor for any that are too bright.
    but the felt pen idea may be worth a try
    stu
