bent forks?
Discussion in 'XJ Technical Chat' started by ant797, Apr 12, 2016.
  1. ant797
    ant797 Member
    western australia
    i took my xj750 for inspection and the inspector seems to think the forks are offset bent i mention they might need a kit through them or it might be because the antidive units have been bypased he didnt know what antidives where and he wasnt optimistic about seals anyways im sure its been dropped at some stage what kind of forks off other bikes also fit this that make it ride and mounouver to a u turn mounouver this is what he couldnt do
    Get yourself two broomsticks. Lash them to the forks one above the other. Use them as a set of parallels to sight down the forks to see if they are just misaligned in the trees.
    If you see both sticks then the forks are likely twisted in the trees. Undo the pinch bolts, set the wheel against something that won't move, twist the bars until you only see one broomstick, and re-tighten the pinch bolts.
    If tht thought is that the forks are bent longitudinally then you can check for straightness with..... a straight edge. Since you want to replace seals you can roll the upper tubes on a flat plate of glass (or a table-saw bed if you have one handy) to see if they are bent.
    Bypassing the anti-dive will not cause the forks to twist or bend. All the parts needed to rebuild the forks (and the anti-dive) are available through Chacal.
  3. XJ550H
    all of the XJ750 (except the XJ750-X and the XJ750RL) are 36mm, and
    the XJ750X and RL models are 37mm.
    37 Yamaha XJ-650 LK "Seca Turbo" (83)
    37 Yamaha XJ-900 RK "Seca" (83)
    37 Yamaha XV-920 RH/RJ "Virago" (81-82)
    37 Yamaha XJ-1100 J "Maxim" (82)
    37 Yamaha XS-1100 E/F/G/H (78-81)
    37 Yamaha XS-1100 LG/LH (80-81)
    37 Yamaha XS-1100 LG/LH "Midnight Special" (80-81)
    37 Yamaha XS-1100 SF (79)
    "36(mm) Yamaha XJ-650 RJ "Seca" (82)"
    1983 (supposedly) Turbo Seca.
    Measure the OD of the (chrome) fork tubes, 1982 models used 36mm fork tubes, 1983 models used 37mm tubes.
  4. ant797
    ant797 Member
    western australia
    thanks for the list and thanks for the right up on twisted forks il have to check that although broomsticks in australia have a habbit of sitting in the sun and bending
  5. ant797
    ant797 Member
    western australia
    another issue why it flunked is the neutral light on dash it doesnt light up i got a new bulb for it and traced the wiring seems all good as far as i can trace it is there any fixes for this
  6. ant797
    ant797 Member
    western australia
    all good i found the neutral safety switches hiding .the wire on it is rusty il give it a clean n sea what happens ...lol at 1st i mistook the oil pressure sender for the n s w ended up with oil all over the garage floor ohwel i needed to change it anyway
  7. saftie
    New York, NY
    Is that the inspection to get your sticker/show that it is roadworthy?
  8. ant797
    ant797 Member
    western australia
    yes to licence it there where a couple of things the forks the neutral light and leaking brake fluid wich there is no fluid leaks i just made a mess at the master cylinder
  9. DrewUth
    DrewUth Active Member
    South Jersey
    It would take a pretty serious impact to bend the forks.
    Curious, the burden of proof falls on you to prove they aren't bent, rather than the inspector having to show that they are? That's kinda messed up. If someone tried to tell me mine were bent, I'd say "prove it"!
  10. saftie
    New York, NY
    Wow.
    Whenever they "inspected" my bikes it was horn, turns, light, brakes and tires. Took a minute.
    But then again, it is the US...
  11. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    If your forks are really bent, then there's probably more then just your forks that are bent. ??
  12. ant797
    ant797 Member
    western australia
    i looked at them out of alighnment definately not sure about bent ..but when i took apart the brake calipers there was a bit of fur in them maybe previuous owner hit an animal
