BEST SOURCE FOR CARB REBUILD PARTS
Discussion in 'XJ Technical Chat' started by REUBEN, Apr 13, 2017.
Tags:
  1. REUBEN
    REUBEN 1985 XJ700N (NOT PICTURED) Premium Member
    Midwest United States
    I've recently purchased a 1982 Maxim 650 (g?). PO said ran when parked 12 years ago. Motor has good compression but the carbs sat with that lovely mid-west gasohol in the bowls for all that time. They are in sad shape. I've had to soak them in chem-dip just to be able to disassemble. All 4 diaphragm upper retainer rings are split and I do not trust the diaphragms themselves. all 4 starter circuit plungers were seized (came loose after soak). I'd image ir the rubber was not toast from sitting that long all, it is after that soak.
    My question is simply, what is the most recommended source for rebuild parts? I've found the Flea-Bay kits for $40.00 for all 4, but they do not appear to contain throttle shaft seals, or transfer tube seals.
    I really aprciate the help and I plan to do a build thread at some point ( I already have over 80 pics).
  2. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    XJ4Ever - upper right hand corner - click the icon.
    kosel, Lightcs1776 and TheCrazyGnat like this.
  3. Lightcs1776
    Lightcs1776 Active Member
    Upstate NY
    To add a bit of an explanation, Chacal (XJ4Ever) is extremely reliable for parts. For example, I purchased a clutch lever from Amazon that "fit my bike," according to the website. It didn't. I turned around and ordered one from Len and it fit perfectly. Anything XJ specific can be purchased from Len without worrying about the fit and knowing you will get excellent service. Things like fuses, headlights, and bulbs can, of course, be purchased locally.
    Stumplifter likes this.
  4. REUBEN
    Off subject, but how would I go about adding a signature to my profile (year, make, model of my ride). I looked for a few minutes and could not find that option.
  5. XJ550H
    click on your screen name by the inbox upper right of page
    then click signiture
    on subject chacal (len) at xj4ever is where you get your parts for your bike. correct parts every time
    Lightcs1776 and Stumplifter like this.
  6. Toomanybikes
    Tsawwassen bc
    IMG_1062.JPG Len supplies all the parts for me and many customers bikes
    So you can get them like this with the right stuff. I will show you complete set after parts arrive ( very quickly even to the west coast)
  7. XJ550H
    1982 maxim 650 would be a XJ650J
    G=1980
    H=1981
    J=1982
    K=1983
    No I is used
  8. Jetfixer
    Two Thumbs up XJ4ever ...no second guessing ...be wary of eBay carb kits they might work.. might not .
  9. k-moe
    The diaphragm retaining rings are supposed to be split. That's how they can be put on in the first place; just like a piston ring.
    If the diaphrams have no pinholes or tears, and are still flexible, they will still do their job properly.
  10. REUBEN
    I read here the upper ring will split on the Hitachi carbs. Seems that split would be a good place for a leak and all the pics I've seen online have a solid piece.
  11. XJ550H
    mine are split. but I read someplace you have to split the ring to replace the diaphragm
  12. REUBEN
    I found replacements that do not use the rings. Can't recall the name off the top of my head. They are aviation grade rubber with a 'bead' that sits in the groove of the old piston. Around $20.00 each. Good thing I got the bike cheap, because the carbs are going to close a couple hundred o rebuild right.
  13. REUBEN
    What all do you recommend be replaced? Could you be bribed into building a list? Carbs are... well.... Rough.
  14. k-moe
    Actually I'm not a dummy (maybe). My recollection is that Hitachi used different types of rings at different times. There is a flater solid type, and a round spilt type.
    Since they can't be used as-is, go ahead and tear them down, order parts after you have evaluated things.
    IN THE CHURCH OF CLEAN
    Rule of thumb: All rubber parts, except the diaphragms. All other parts will depend on condiion.
  15. k-moe
    http://jbmindustries.com/HITACHI.html
    REUBEN likes this.
  16. hogfiddles
    Clean EVERYTHING before determining what needs to be replaced.
    Then, order your list from Len.
    I don't order parts anywhere else.
    Lightcs1776 and k-moe like this.
  17. REUBEN
    Any experience with those? Seems like a solid idea.
  18. Toomanybikes
    Tsawwassen bc
    Installed them on a members bike last summer and found them to fit very well and had no issues tuning the bike. Just make sure that you orientation is correct because they do not have a pimple to align them. the 2 air holes in the slide MUST face forward
    chacal likes this.
  19. Toomanybikes
    Tsawwassen bc
    Have seen carbs with broken upper plastic ring and the slide had moved putting air holes in wrong place(my seca)
  20. REUBEN
    Another question. on carb #2, the jet needle (one attached to piston) separated from the plastic nub that sat on the end. This means I will be replacing the needle, should I replace the jet as a pair?
    What is the wisdom regarding jet replacement?
  21. k-moe
    Is the needle jet worn? If the hole is still round it does not need to be replaced, but can be if you have it in your budget.
  22. REUBEN
    So I just e-mail the company with a parts list to get price and availability?
  23. k-moe
    Yes, or use the conversation feature. Click on your inbox in the upper right of the window. Username Chacal.
  24. mr blackstock
    mr blackstock New Member
    Victoria, Australia
    I have been using jbm diaphragms in my 650 and FJ1100 for 6 years or more and they are great! They are a tight fit. Regarding the carbs, replace whatever you can afford, if the engine is low mileage, less than 60k, don't replace the brass bits, just all the O rings and rubber bits. Things like the rubber choke plunger seal on a high mileage engine can harden oblong and mess with your idle.
  25. Cafe_Guy94
    Cafe_Guy94 Member
    Ridgecrest, CA
    That's exactly how my carbs looked on the '82 maxim I just purchased. I ordered the $39 rebuild kit off eBay. Ill let you know how it works out.
  26. StahlMaster
    StahlMaster Active Member
    Southgate, Michigan
    How did it work out?
  27. k-moe
    If it's the kit I'm thinking of, it didn't work out well at all.
