Best way to manually crank the engine
Discussion in 'XJ Technical Chat' started by steelrain121, Sep 11, 2019.
  1. steelrain121
    steelrain121 New Member
    USA
    83 XJ750 Midnight Maxim - If it matters
    Has been sitting for a couple years, am in the process of replacing all fluids, plugs filters etc. Wanted to drop some oil in the cylinders and crank the engine by hand a little to get some oil moving there. Any way other than dropping it into fifth and turning the back wheel?
  2. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    If it is like my XJ700N, you can remove the left side plate and turn it with a wrench, but putting it on the center stand, in gear, plugs removed, and turning the rear wheel seems to me to be easier.
  3. k-moe
    Yep.
    Remove the cover on the left side of the engine (YICS on the cover) and use a 19mm box-end wrench to carefully turn the crankshaft counterclockwise.
    Take great care to avoid damaging the ignition pickup coils.
    Jetfixer and Melnic like this.
  4. steelrain121
    USA
    Yeah I am already raised up, plugs out.
    Any downside to just turning the wheel?
  5. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    You will have to be careful not to knock the bike over. Turning the wheel by hand will leed to dirty hands.;)
  6. Pizzaman
    Pizzaman Member
    north Seattle
    no. Just turn it in the right direction
  7. Sonny smith
    Sonny smith New Member
    Macon Georgia
    I need help with my 82 750 I can’t get the starter to turn my flywheel I’ve tried everything that has been recommended
  8. Dan Gardner
    Minneapolis, MN
    So the starter runs but does not engage? Does it sound like shaking a can full of marbles?
  9. Melnic
    Melnic Active Member
    Start a new thread
  10. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    sit on it, go up through the gears and walk it forward, better than skinned hands turning the bloomin wheel..
  11. Oblivion
    Oblivion Active Member
    Northeast Illinois
    Another necromanced thread.
  12. Sonny smith
    Macon Georgia
    Update I’ve taken the side casing off and manually turns it the piston rings were a little stuck so starter is turning flywheel now. Now I’m having trouble getting enough power to the starter any ideas
  13. tabaka45
    Brunswick, Georgia
    How do you know the rings were "stuck"? Put some Marvel Mystery Oil in each cylinder and let it sit for a day or so. Doesn't take much, maybe a tablespoon or so. Then turn it one or two times before letting it sit. I wouldn't think stuck rings would make it hard to turn unless you have some rust in the cylinders.
    Franz likes this.
  14. Sonny smith
    Macon Georgia
    No rust cylinders are fine now I’m having trouble gettin spark.
  15. Sonny smith
    Macon Georgia
    Once they released no trouble at all moving it was the initial turn that was trouble
  16. k-moe
    New battery?
    Rebuild the starter if so. @chacal has the correct kit.
  17. Sonny smith
    Macon Georgia
    Now I’m getting no spark from plugs any ideas?
  18. tabaka45
    Brunswick, Georgia
    If the starter is turning the engine but the plugs are not firing I agree wth K-Moe about the battery. A weak battery will do that--at least it did with me. I know very little about the ignition electronics, but I would check out the coils, although it would be unusual for both to go out at the same time. You might also have to look at the brushes in the alternator. Mine got hard to start and then began shutting off at idle if I hit the brakes. There wasn't enough energy to fire the plugs and run the brake lights at idle. New brushes from Chacal solved the problem.
  19. prulla
    prulla New Member
    Tempe
    Would this be the plate with the yamaha logo on it?
  20. Franz
    Yes use a 19mm wrench and turn anticlockwise.
