Biggo,s Covid XJ900f Rebuild
Discussion in 'Hangout Lounge' started by biggo, Nov 10, 2020.
  1. biggo
    biggo Member
    Kapiti Coast New Zealand
    I have a 1986 XJ900F that I have owned for over 30 years so when I see a non-runner for sale for $400 I thought it must be good as a spares bike. We went into COVID lockdown here in New Zealand so I though I would try and get it running. Some oil down the bores got it turning over a strip of the carbs and the exhaust borrowed from my other XJ and she ran. Should I strip or should I re build that was the question ?
  2. Fuller56
    Fuller56 Well-Known Member
    My thoughts go to what is it worth to you. I am more of a rehab and make it a nice runner guy. Rather than a restore and make it a museum like piece. I appreciate the time, effort, cost and effect of the piece by piece restoration but don't have the dedication to the project. There are bikes out there that are worth more when done due to their own history but I have not had one yet. The cost of going from a nice safe daily rider to the perfect show piece goes up fast.
    What ever you do with it, primarily..... Have Fun!
    John
    Andrew Nichols likes this.
  3. Marchy
    Marchy Member
    Canada
  4. Marchy
    Marchy Member
    Canada
    I’m about to do the same thing 84 750 it does come down to what’s the purpose I just like taking things apart and making them better
  5. Franz
    If your other XJ is your everyday runner you can take your time over the rebuild depending on how much you intend to spend on it. What exhaust system do you have on the bike?
    XJ_theodore likes this.
  6. biggo
    biggo Member
    My other XJ is my nice day ride that I am very attached too. My son wants it when I am past riding and I am sure it will mean the same to him. The exhaust on the other bike is totally shot however I have a 4 into 1 system that I will swap with a reasonable aftermarket exhaust with a friend who is doing a cafe racer XJ
  7. biggo
    biggo Member
    Hi John .
    The decision I made was to do a rebuild on a budget but to get a good reliable everyday runner .
    Phil :)
    Fuller56 likes this.
  8. biggo
    biggo Member
    So I have established the bike has good compressions on all cylinders but Carbs still need some TLC . Time to strip the old girl down and see what else we need. :)
    • Frame is surprisingly good condition was able to get sandblasted before lockdown but not powdercoated or painted so decided to go for brush pained hammerite finish.
    • Front forks leaking but I have a spare set in the shed so work out which ones are best and refurb as required.
    • Steering bearings knackered so got some bearings with built in seals
    • 4 times carb overhaul kits and brass fuel tee piece ordered.
    • New swing arm bearings and clean and paint as required
    • Wiring loom cleaned and all connectors treated with white vinegar / Baking soda and finally ACF50 all connection like new now :)
    • New fusebox fitted
    • Dash housing repaired from previous drop
    • All brake calipers and master cylinders stripped and clean a couple of new seals required
    • 2nd hand exhaust welded up as required and painted with VHT paint.
    • Engine just cleaned and serviced before re fitting
  9. Fuller56
    Glad to hear the refurbish is going well. Looks like it is going to be a real nice job, something to be proud of. Watch your budget creep. I have a Midnight Maxim 750 I picked up VERY inexpensively (initially anyway) and had it going nicely and then decided to fix this, then that and now have got my own Project Creep going on! But is not going to be as extensive as yours.
    John
    biggo likes this.
  10. biggo
    biggo Member
    Good degrease and clean off of engine . Some of the exhaust studs were quiet rusty when dismantled so run a die down then an I dont want to shear one of those off.
    As I am doing this on my own in lockdown I think I will fit the frame to the engine while its on its side. Airbox fitted first as I know there is no wat to get it in after motor installed. I want to keep this stock no pod filters etc . Also checked generator brushes which were like new and cleaned and painted starter motor and generally cleaned up all electrical connections etc. 20200328_131713.jpg 20200328_195824.jpg 20200329_095357.jpg 20200329_095405.jpg 20200329_095413.jpg
    Franz and Yammaat like this.
  11. Marchy
    Marchy Member
    Canada
    Wow seeing that gets a little intimidating on me doing mine.......I’m still on fence about picking up this 84 750s motor wise.....any suggestions when I go have a look ?
  12. biggo
    biggo Member
    These bikes are not the most difficult to work . I would check engine out if it runs that may be the difference between an engine re build or not which can add plenty of $$.
    My Plan is to get this running a good functional bike not a show bike but safe and practical > I intend to leave it standard except maybe some minor Farkles . Good luck with your bike :)
    Phil
  13. Marchy
    Marchy Member
    Canada
    Hey Phil so just got back from a 4h round trip to pick it up I couldn’t resist it....but severe rust in tank should I just assume and go ahead with motor tare down or just the carbs?
  14. biggo
    biggo Member
    Hey Marchy. Personally I would try and get it running first just so you can make a reasonable assessment before stripping . unless you are going for full rebuild anyway.
    My other XJ rusted ot the back of the tank many years ago, I was able to solder up pinholes and used POR15 tank liner kit that was about 20 years ago and its still holding up OK
  15. Marchy
    Marchy Member
    Canada
    Hey Phil
    got ahold of the bike yesterday night and
    ya think I am going rebuild just cuz the neglect and I am planning on putting money into this one as a show piece......could you direct me to any good threads
  16. biggo
    biggo Member
    So engine in and secure next I think is rear swingarm.
    Replaced swingarm bearings getting outer race out of swingarm proved challenging.
    I had a bearing puller I used on some head bearings that looked like it may do the job . Needed a bit of modification and then how do I knock it out of a blind hole :rolleyes:
    Solution was to drill a hole to allow a punch through from the other side .
    New bearings in so clean off swingarm and paint then fitted to bike 20200329_121537.jpg 20200329_123812.jpg 20200329_121537.jpg 20200329_123812.jpg 20200329_154032.jpg 20200329_154035.jpg 20200331_104149.jpg 20200331_104156.jpg
  17. Marchy
    Marchy Member
    Canada
    So that swing arm is painted right?
  18. biggo
    biggo Member
    Correct I just used spray can of wheel silver. Happy with result
  19. biggo
    biggo Member
    Next to put on new Steering bearings trfot front forks and wheels on so I can stand bike up . All going to plan so thats good :) 20200331_110608.jpg 20200331_114257.jpg 20200331_123024.jpg 20200331_123031.jpg 20200331_130657.jpg
    Minimutly, Franz and Yammaat like this.
  20. biggo
    biggo Member
  21. Franz
    It is great seeing these old Yamaha's put back on the road.
  22. biggo
    biggo Member
    Got her all running been for some good long runs . Clutch is breaking away at high speed in top gear thought it may have been because it was frozen when I first got it running but know so new Clutch to be done next :)
  23. XJ Nine Hundred
    XJ Nine Hundred Member
    PA
    That is beautiful! NICE JOB!!!
  24. biggo
    biggo Member
    New Clutch fitted sorted out perfectly with new cable as well.
    Have been using as my main bike really enjoying riding her.
    I made up a mudflap try and keep front of engine clean but this ended up after a couple of thousand KM,s cracking the mudguard . Had a spare one to use while I repaired white one but now decided not to worry about keeping engine clean ! The motto for this bike is definitely " Ridden not Hidden "
    I have now done about 5000 kms since rebuild and she is running sweet :) 20201002_112645.jpg 20201002_112653.jpg 20201002_112730.jpg 20201029_104432.jpg 20201113_134139.jpg 20201220_163728.jpg
  25. Fuller56
    That is a sweet setup. Well done sir! I do like the fairing stays that sweep around the side of the tank. I can see where in a drop they would bugger the tank but the answer to that is don't drop it. Very nice. I like.
    John
  26. Franz
    Nice machine what make are the engine bars?
  27. biggo
    biggo Member
    Fennick I think they are called. I got them in the UK late 1980s
    Very well made and good protection
  28. biggo
    biggo Member
    Sorry Renntech is the make
  29. Franz
    Cheers l will try and get a set.
  30. biggo
    biggo Member
    Done a few more thousand kms. and worn out my tyres. Fitted set of BT46. Very pleased with them so off on a motorcycle rally later in the week to South Island of New Zealand. Should do 4 to 5000 kms.
    https://www.tt2000.org/index.html
  31. Brent NZ
    Brent NZ Active Member
    Tauranga, New Zealand
    If you can do 5k in a week you're tougher than I am!
    For those not familiar with nz roads, we don't have many straight bits. The roads are narrow & windy with patches of gravel here & there to keep you awake. So after 6-700 kms you feel like you've been put through the wringer, but if you know where to ride the traffic's not bad and they are great m/c roads. I went for a high speed run around the back roads of Rotorua on Sunday, was worn out after only 200km. Anyway good luck with the rally.
  32. biggo
    biggo Member
    Hi Brent.
    Always found the XJ comfortable on long rides . My plan for Rally at the end of the week is about 500 kms on Friday then 1100 kms on Saturday finally about 400 Sunday Morning . I will then do another 2 - 3000 plus getting to and back from Oamaru for TT2000 Rally . I will be getting ferry to south island in the morning .
    I will have a spotwalla tracker on tomorrow if anyone is interested :)
    https://spotwalla.com/tripViewer.ph...9hFi35_xPrARXFN0u_H798mNwf6MzgHK0LsRZ7GuZk0Tg
    Brent NZ likes this.
  33. Simmy
    I am sold!
    How does a 60 yo frozen Canadian ready for retirement immigrate to this enchanted land?
    Rooster53 and biggo like this.
  34. Brent NZ
    I kept an eye on your tracker, what an epic trip!
  35. biggo
    biggo Member
    3000 kms so far. Epic roads lots of curves gravel roads too. XJ has been flawless.
    500kms today then home the following day. Bike needs to a good clean. 20210221_164453.jpg 20210221_164513.jpg
  36. Brent NZ
    A question for when you are finished - what was the best road? Queenstown to Glenorchy?
  37. biggo
    biggo Member
    Hard to choose.
    Great ride through haast pass this morning and I love Arthur's pass but Glenorcy rd always good.
    The south island is all motorcycling heaven
  38. biggo
    biggo Member
    Bach home now after 4600 Km,s of great riding . A few pics from the Rally
    IMG_1293.JPG IMG_1298.JPG IMG_1316.JPG IMG_1321.JPG IMG_1327.JPG IMG_1329.JPG IMG_1331.JPG IMG_1344.JPG IMG_1347.JPG IMG_1363.JPG IMG_1361.JPG
    FJ111200 and Franz like this.
  39. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Excellent, New Zealand on my bucket list. What's with all the ladies underwear on that fence?
  40. biggo
    biggo Member
  41. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
    The old 900 still looks good compared with the newer stuff. Well done mate.
  42. Franz
    I like bikes where the engine is not covered with fairings, they look good and there is ease of access for maintenance. .
  43. biggo
    biggo Member
    A local guy made me a nice sheepskin cover for the XJ Very comfy had one on my FJ1200 a few years ago .
  44. biggo
    biggo Member
    Done just over 12000kms now since rebuild. Service time including valve clearances using the wire under the valve method :) , need to order some shims tomorrow . Bike going great :) 20210426_152727.jpg 20210426_152742.jpg 20210426_154220.jpg
  45. biggo
    biggo Member
    Planning to do an Iron Butt SS1600 ride on the old XJ :)
    Ride will be Winter Solstice ride on 21st June ( Winter in southern hemisphere )
    I will only go if weather reasonable I dont see it as fun to be riding 1000 miles in pouring rain !
    Map of planned route below
    https://goo.gl/maps/cii852KusS3WqqRq5
  46. biggo
    biggo Member
    Been in lockdown again here in NZ.
    Few jobs to do on the old girl .
    Slight fuel leak from No3 carb appeared to be float chamber gasket so off with the carbs and new gasket fitted . What a bastard getting the Inlet rubber that have gone hard over the years back on . Ended up boiling them in water before inserting through the air box onto carbs.
    I followed the bike when I let my son have a ride a few weeks ago after long downhill sections using the engine as a break getting a puff of smoke from left exhaust . It is using about 1 litre of oil every 1200 km,s . I suspect the valve stem seals have gone hard so another job for the list but for now I can live with a bit of oil consumption.
    Fitted some extra spotlights for night riding as the original headlight leaves a bit to be desired .
    I am still loving this bike and look forward to plenty of happy KM,s this year :)
  47. biggo
    biggo Member
    Well I haven't been giving my XJ the love . Decided to take it for it Warrant of Fitness inspection last week as havnt used it for a few months and it had expired. Left home early going well then Rev counter dropped to zero and bike died . Coasted to the hard shoulder lucky not much traffic around.
    Checked over electrics everything working but no ignition starter turning over and all lights working properly. Fiddled around with all wiring blocks fuses etc but no good.
    Phoned my Son in Law and asked him to rescue me with his trailer. Loaded on bike and took it home . Got bike off trailer and though I will just give it another go and off course it started first time !!!!
    I cant get the fault to re occur but suspect it could be TCI unit so lucky I have a spare I will pop it under the seat so I can quickly swap if require in future.
    Don't you just love intermittent electrical gremlins !!!!
  48. biggo
    biggo Member
    Tried another TCI unit and seems to run OK . I am also thinking about new ignition coils as they are nearly 40 years old.
    Going to put bike away for the winter so will get her back out around Christmas :)
  49. biggo
    biggo Member
    Time to get out my other XJ900F.
    This one is a 1986 model I brought with me from UK. A friend of mine bought it brand new and I took it off him when about 4 years old so owned it about 33 year's.
    The frame has rusted out so time for some major work.
    20230107_151809.jpg 20230107_151809.jpg 20230107_151809.jpg 20230107_151813.jpg 20230107_162042.jpg
  50. biggo
    biggo Member
    After a few Months of not doing much I spent the weekend re assembling my XJ900 . Just clean up and refit mainly.
    I did find some bad burnt wiring connectors from Alternator so fitted ne terminals .
    Hope to give the carbs a clean in the ultrasonic cleaner next week then be ready to fire her up after 4 years :)
    20230418_080045.jpg 20230418_091433.jpg 20230418_150322.jpg 20230418_150327.jpg 20230418_150336.jpg 20230418_150345.jpg
    Simmy and Fuller56 like this.
