Bike doesnt want to start....
Discussion in 'XJ Technical Chat' started by Rod1, Feb 3, 2022.
  1. Rod1
    Rod1 Member
    San Luis, Argentina
    Hello everyone! I sent my bike to the mechanic for a carburation problem...she, yes SHE, took everything apart, cleaned them, putted them back together, I bought a new battery too, she started the bike left it running for a while and called me to pick it up... Two days after that call, she told me that the bike wont start due to the batterie wont hold the charge (battery was charged as indications said) so I stoped by, charged then battery again, pushed to make it start and nothing, not even an explotion in the cylinders...have gas to the carbs, She is checking sparks today... What you guys think we are missing here? It happened before that the old battery wont hold the full charge but I pushed the bike for a few meters and started right up... If She (the mechanic) find out that there is spark, I dont know what else to check here.... Any ideas? Thank you so much...
  2. short_circutz
    short_circutz Active Member
    Sault Ste Maire, On, Canada
    If the battery isnt holding a charge, then the charging system needs to be looked at.
    And, the charging system on these bikes wont keep the battery charged at idle speeds. They need to have the revs up above about 1100 rpm
  3. Rod1
    Rod1 Member
    San Luis, Argentina
    The idle was set as manual at +- 1300 rpms.... But stayed idle for a couple of minutes only just to see if ther is nkt backfires or if it idle was smooth and then turned off...
  4. Rod1
    Rod1 Member
    San Luis, Argentina
    Can the charging system go off just like that? No prior glich or anything? How can I test that then?
  5. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    oh , dear,
    what bike is it ?
  6. short_circutz
    Go to https://www.xjbikes.com/forums/threads/the-information-overload-hour.27544/
    Then ELECTRICAL SYSTEMS
    Which will be where you can get a lot of info on the charging system, which at one point states:
    "Your charging system output VOLTAGE should be checked, again at the battery terminals, while the engine is running. The measured voltage should be:
    * 14.2 - 14.8 Volts at about 2,000 rpms for all non-X models, and the same voltage for "X" models, but at about 3,000 rpms. Again, you would measure these voltages at the battery terminals with your voltmeter."
  7. XJ550H
    new battery can be bad charge it out of bike then let sit overnight and measure voltage should be 12.8 volts
    then test battery voltage drop when cranking wants to stay above 9.8 volts any less it will not fire
    brushes could be bad worn down. the copper rings could be dirty
    you can ohm out the brushes.
    use a meter to test voltage regulator
    battery charges back through switch and main fuse. could be dirty contacts in switch or dirty battery wires.
    there is the wire that runs to main fuse from battery check it out for good connection. check the connector to voltage regulator. make sure the grounds are clean where they connect to motor and from motor to frame.
    bottom of this thread has info on charging system and what to look for
    as far as spark if you still have the old fuse box that could be the issue
    the clips crack and cause issues
    Jetfixer and Franz like this.
  8. Rod1
    Rod1 Member
    San Luis, Argentina
    I will check all that, but the bike started 2 days before all these and nothing was done after.... So, even if the battery wont hold charge with a little charge you should be able to push it to start... But in this case it wont, even with battery at 11.25, that is what confuse me
  9. XJ550H
    I always start by looking where the work was done,
    so carbs were worked on and battery changed.
    I agree you should be able to bump start the bike.
    I would check to see if the throttle cable and choke cable are connected to carbs in correct locations. I do assume the carbs were removed when they were worked on.
    I mention this because the choke will be needed to bump start the bike.
    I would also make sure battery connections are tight
    this next suggestion is going to sound dumb. but how much fuel is in the tank? could be to low to supply carbs.
    also check the fuel and vacuum hoses are connected at both ends and not kinked
  10. bensalf
    yorkshire ,england
    its pointles telling him solutions, untill he tells us WHICH BIKE it is
    some xj's dont have brushes, some xj's dont have choke cables
  11. XJ550H
    it may be
    Xj700 1985
  12. bensalf
    yorkshire ,england
    it may be
    Xj700 1985
    i apologise, if i missed that, but where does it mention that
  13. XJ550H
  14. Rod1
    Rod1 Member
    San Luis, Argentina
    All cables were checked,there is gas...sorry didnt mention the xj model is a xj 700 1985. Yes, the carbs were remove, cleaned, diaphragms were change... And bike started.. abd nothing was done after that. But the battery wont hold charge and didnt start again not even pushing it
  15. Rod1
    Rod1 Member
    San Luis, Argentina
    Thanks.. I will look on that..
  16. Rod1
    Rod1 Member
    San Luis, Argentina
    Someone said about the fusebox...its the original now but what you mean by replace it? For a new one o other one? Fail to mention that Im not in the USA or Europe... Im in Argentina, parts are hard to find and usually I use the Virago 750 o 1100cc, with that being said...if I have to change the fusebox what should I use?
  17. hogfiddles
    -Why were the diaphragms replaced?
    -Check fuses/clips
    -did the bike get shifted into gear? Check safety relays
    shooting in the dark .....
  18. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    The 1985 XJ700 does not have the issue of a glass fuse type box under the seat that can be a problem. The blade fuses are safely nestled under the indicator light section below the instruments and is rarely a problem, I think.
  19. hogfiddles
    There is still a main fuse under the seat, and fuses can still go bad, get corrosion on the ends, etc.....
  20. Rod1
    Rod1 Member
    San Luis, Argentina
    Diaphragms were crack. Im checking fuse box, relays, everything...take me some time due to my work I cant be working on the bike as much as I want to do it...
  21. hogfiddles
    Ok, just checking. Did you orient the diaphragms and slides correctly?
    none of us can be working on our stuff as much as we want due to work—- lol
  22. Rod1
    Rod1 Member
    San Luis, Argentina
    i assume were correct since first the diaphrams were change and the bike had the same problem to idle...was the float levels totally off...then the bike started one more time and kills the battery and never started again...this afternoon I will have time just to check the sparks, maybe 2 or more are not working
  23. Rod1
    Rod1 Member
    San Luis, Argentina
    Update. Finally had some time to sit and check the electrical system. Everything looks and measure normal but when I got to the TCI this little box was burnt in one corner an opened on top. I have to replaced that but here is the cacht...in this country (Argentina) the only company we have that made that TCI for this model comes with two connector not one as the one in the bike (thinking that one in the bike is the original one). This new TCI comes with a little manual that indicate what to connect where with cable colors included...so, I have a little challenge ahead. Is this bike has any wet coil start (sorry for my technical english) or something like that? Bike of this years ussually have some as the susuki...
