Bike not starting
Discussion in 'XJ Technical Chat' started by Jenkins, Nov 6, 2017.
  1. Jenkins
    Jenkins New Member
    Queensland
    Hi everybody,
    My bike is not starting. When I try to start it it seems it’s draining the battery very quickly. (From trying to wind over to Click Click Click..) it seems she want to start but just doesn’t. Any ideas?
    bad battery or needs a good charge.
  3. Timbox
    ^^^^^+1 Need to take the battery in and have it "load" tested. If it is bad and you have the coin, get a good AGM type, it will really help.
  4. Jetfixer
    ^^^^+2 get a new battery , if you keep trying to crank with a weak battery , you cause the starter to draw down and this puts a load , your TCI will not activate to allow spark ...+ 1 on the AMG battery , I will not go back to a messy lead acid battery !!!
  5. hogfiddles
    Battery
  6. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Just to prove it, try jumping it with a car battery.
  7. XJ550H
    without the car running
