Bike still won't start after Starter rebuild
Discussion in 'XJ Technical Chat' started by brycematheson, Apr 23, 2015.
  1. bubba650
    bubba650 Member
    Miami
    Just jumped it and starter does spin
  2. Toomanybikes
    Tsawwassen bc
    So that means the motor turns as well??
  3. Rooster53
    So good news on the starter spinning when jumping the solenoid. Now it's time to test the solenoid and verify wiring. Not sure if the solenoid is new, you said starter relay was replaced, and that is a different part than the starter solenoid.
    Here is a link on testing the starter / solenoid and safety circuits, it is for an 82 so a little bit different than your 81, but the first few steps are the same for testing the starter and solenoid. Step 3 for testing the solenoid since you already did step 2.
    http://www.xjbikes.com/forums/threads/how-to-test-your-starter-circuit.7828/
  4. bubba650
    bubba650 Member
    Miami
    So umm did a spark test on one Sparks is that odd or what?
  5. bubba650
    bubba650 Member
    Miami
    Now I have spark, starter turns motor turns but not fast enough to start. Could valve clearance make it hard to start if they are off
  6. k-moe
    More likely that the battery needs charged/replaced, or you have dirty/ bad ground.
