Black sooty dry sparkplug
Discussion in 'XJ Technical Chat' started by Jostein, May 8, 2018.
Tags:
  1. Jostein
    Jostein New Member
    norway
    Hi all. I have a 1983 xj750 Seca.
    I recently had the bike in the shop and had a service and synchronization of the carbs. Bike runs OK but is hard to start cold. I replaced sparkplugs today and noticed that the outer sylinder plug on the throttle side is sooty,dry black. The rest of the plugs are fine. I don't want to start adjusting on the carburetor but are wandering if one sparkplug can be bad or if something else is wrong.
    I appreciate any advice on the subject
    You're going to have to. A bad sparkplug would be wet and not at all sooty.
    Given that she's hard to start when cold, I'm suspecting that cylinder (at least) is a tad rich.
  3. Jostein
    Jostein New Member
    norway
    Thanks k-moe . I am a dummy with carburetors . Is there a detailed description /pics of where adjustment screws are and which one to turn in or out?
    There must be one for air and one for fuel? If I can get instructions for dummies I will try :)
  4. kosel
    MInneapolis, MN
  5. Jostein
    Jostein New Member
    norway
    Thank you so much kosel :)
    I will try to adjust. Is it in or out for a leaner fuelmix.?
    I ordered a kit from gunson. It's a sparkplug with a glass plate which allows you to check the combustion color and adjust the fuel/air . I'm exited to try. Will come back with a happy end I hope.
  6. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    In=leaner, out=richer
  7. Jostein
    Jostein New Member
    norway
    Thanks Chitwood. :)
