Bleeding brakes
Discussion in 'XJ Technical Chat' started by pikeymick, Mar 10, 2009.
  1. wontonrunner
    wontonrunner New Member
    I washed the bike afterwards :D But i didnt clean up the spills on the concrete floor...it will get acid etched this summer and a coat of epoxy put on.
  2. pinson1971
    pinson1971 New Member
    North Wales, UK
    Thanks pvtschultz followed your instructions..15 minutes later fully bled..dry mc with new braided lines...who needs fancy bleeding kits.. :lol:
  3. RideAlong420
    RideAlong420 Active Member
    USA
    would reverse bleeding mitigate this as well?
  4. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    I reverse bled mine in about 20 minutes. Used a big syringe I got at Tractor Supply and some 1/4 inch clear tubing. Just be sure to get any bubbles out of the tubing if you disconnect to refill. I tied the brake lever down when bleeding. Once both sides were done I wiggled the lever a few times and got a couple of very small bubbles and that was it.
