Bobber builf
Discussion in 'XJ DIY How-To Instructions' started by Chrisdecalise, Jun 25, 2022.
  1. Chrisdecalise
    Chrisdecalise New Member
    Canada
    Looking into turning my xj700 into a bobber? Anyone have an idea where to start? Fyi first ever bike so I'm new to this world.
  2. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Can you weld? Are you creative and artistic? How much mechanical engineering experience do you have?
    If the answers are no, no and not much I would advise against it. Whatever you do make sure it's safe.
  3. k-moe
    Start by riding her for a few years, taking a welding class at your local community college along with some engine repair classes, and in the meantime look for someone's unfinished project that you can buy for cheap and then fix all of the things that were done wrong.
    Modifying bikes isn't anywhere near as easy as all of those TV shows make it look.
    Now if you've already been sucessful at building a hot-rod then all that advice is wrong.
  4. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    Does it run? Make sure it does, before you start anything else. The ads are littered with "project bike, needs a little TLC", which translates to "I cut and welded, and can't make it work"
    Also. If this is your first bike, what makes you think you want a bobber? Have you actually ridden one?
    Bobbers are all looks, and usually uncomfortable as hell. You won't be improving the performance any. XJ isn't an old Harley, and the relatively small amount of weight you lose when bobbing isn't going to get you much of anything.
    Franz, k-moe and Huntchuks like this.
  5. a100man
    a100man Well-Known Member
    Bedford, UK
    This.. with bells on.
  6. a100man
    Bedford, UK
    ..and this.
