Brake bleed XJ650J Maxim I read....
Discussion in 'XJ Technical Chat' started by StahlMaster, Jan 17, 2019.
  1. StahlMaster
    StahlMaster Active Member
    Southgate, Michigan
    I read all the information I can find on this site (and others). I have a "Mity-Vac". Rebuilt M/C, Rebuilt caliper and new SS hoses. When doing the caliper I was able to remove the piston with compressed air. I polished it to a mirror finish. I ran a cylinder hone into the bore of the caliper. Do you think I should push the fluid up from the bleeder screw or let gravity help and go from the master cylinder?
    D
    go from the MC
  3. k-moe
    +1 The maxim 650 brake system is easy to bleed.
  4. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    When I rebuilt my front brakes—everything new or rebuilt just as you did—I pumped the fluid through the bleeder valves (2 calipers on my XJ700) and was finished in about 15 minutes. With the system completely empty I just figured the reverse bleeding with the air being pushed up and out made more sense. But it might be different for your bike.
