Brake caliper noise Seca (4ko)
Discussion in 'XJ Technical Chat' started by Andyam5, Sep 3, 2018.
  1. Andyam5
    Andyam5 Member
    Luton, UK
    Anyone else have experience of this? My calipers rattle and rumble after braking, sounds like they're falling apart. They have some play very much like the ones in this vid
  2. Jetfixer
    Did you replace pads recently? There is a shim that is behind the pad was it reinstalled?
    Andyam5 likes this.
  3. k-moe
    There is also a shim that acts as the bearing surface between the caliper and the caliper mounting block. If that were missing the caliper would rattle.
    The sliding pins can wear (though that's unusual) and also introduce slop.
    Andyam5 likes this.
  4. Andyam5
    Andyam5 Member
    Luton, UK
    Pads have done a couple of hundred miles and all shims were re-fitted, though I have ordered a new set of the sprung H shaped ones as the old ones are fairly corroded
    I'll take a look at the pins, I seem to remember I had an issue with them a while back, can't remember what it was but maybe they're nfg
