Brake Warning Light
Discussion in 'XJ Technical Chat' started by LeClairerog, Apr 24, 2017.
  1. XJ550H
    check your alternator brushed and clean the copper rings with a hard eraser and clean with electronic spray to remove eraser bits and any crud
    low voltage is indicative of brushes and alternator
    also if lead acid battery check level and replace missing acid with distilled water
    clean battery connectors then if still a problem clean grounds at motor and frame
    this link also has in depth charging system info
  2. robbo
    robbo Member
    uk
    thanks,will check all that and report back
  3. robbo
    robbo Member
    uk
    update,checked all above.battery level was low on 2 of the cells and filled with distilled water,only checked battery a couple of months ago.on startup battery light went out and charging was 14.6v.think the battery may be on the way out will keep a check on it.
  4. robbo
    robbo Member
    uk
    update,have been out on the bike three times since ,battery seems fine but the battery warning light stays on all the time (resistor fitted see above)
  5. Rooster53
    You need to revisit this. You must have continuity through the ignition switch W/R wires or you will get the battery warning.
  6. robbo
    robbo Member
    uk
    went through and cleaned connectors again and now light goes off and stays off,although not been out for a run yet.
