Broken Carburetor Body
Discussion in 'XJ Technical Chat' started by ZVZ, Oct 5, 2020.
  1. ZVZ
    ZVZ New Member
    Tacoma, WA
    I was disassembling the carburetor rack off my XJ550 Seca but was struggling with a stripped/rusted screw. I was using an impact driver to attempt to remove it and busted the corned of the body completely off. I was looking for a replacement but everything I'm finding is either crazy expensive or just in bad condition. Hoping that maybe someone here has an extra carb body sitting around that I buy??
    Picture shows the broken corner but I'm not sure if this is Carb #1 or #4. Also, I started to separate the carbs, which is why it looks wonky.
    Any help would be greatly appreciated. Thank you everyone!
  2. ZVZ
    ZVZ New Member
    Tacoma, WA
    Any luck finding an extra carb body? Thanks!
  3. bigfitz52
    That is the #1 carb and "sitting around" isn't applicable. I haven't had a chance yet, but I will pull the #1 carb from my parts rack and see what shape it's in; unless somebody beats me to it and hooks you up. Did you find a factory service manual yet?
  4. ZVZ
    ZVZ New Member
    Tacoma, WA
    Yes I got a parts manual and a service manual
  5. a100man
    a100man Well-Known Member
    Bedford, UK
    You might get away with gluing (epoxy obvs) that - if you add some reinforcing material.
