Broken Pilot Jet housing on 3rd Carb
Discussion in 'XJ DIY How-To Instructions' started by Kevin Duby, Aug 2, 2017.
  1. Kevin Duby
    Kevin Duby New Member
    Michigan
    Hello everyone, I am a new XJ550 owner. It is my first motorcycle for the street and I have decided to start a cafe racer project with a 1982 XJ550 Maxim. I bought the bike non running and with carb issues. when i opened the carbs yesterday i noticed that on the 3rd carb i opened, its pilot jet housing was cracked in half. i think i found the issue with the bike :)
    My question is if there would be any Slide Carbs that people have switched too, where i can buy a set of 4 slide carbs and mount them to this bike. i am not a big diaphragm carb fan but if i need i will buy a new carb for the set i have. If there are not other carbs that work with this bike, then i am curious if anyone knows of where i can buy a single carburetor to attach to my existing 3 that are in perfectly good condition. I have found 2 different sets of carbs on ebay for roughly 200-250 dollars, and was hoping to not have to spend this much on carbs, when only one is broken.
  2. Polock
    someone on here should have a #3 body they will part with. as for slide carbs, that's going to be big bucks and all sorts of fitting problems.
    diaphragm carbs work well once dialed in
    Kevin Duby likes this.
  3. XJ550H
    there used to be aftermarket slide racks available. mfg is mentioned to in the clymer manual looking at $1000 or more Specialists II or Barnett Tool & engineering
    start a conversation with me about # 3 carb body
  4. Toomanybikes
    Tsawwassen bc
    Hey Kevin
    Ricardo Anaya has an xj550 max parts bike ask him to sell you carbs. I gave him your name
