Bummed... Snapped off two hex bolts to the carb intake
Discussion in 'XJ Technical Chat' started by vintagerice, Dec 27, 2009.
  1. vintagerice
    vintagerice Member
    New Hampshire
    Yes... not a good day yesterday. As carefull as I was two out of the eight bolts snapped off leaving just a nub. Was trying to replace the rubber carb joints. Need to find a way to get them out. Tried filing the nub square so I could get a small wrench on it but so far no luck.
    Think the metal is too soft. Will try some other things later today. Wish me luck
    Rob
  2. seaguy
    seaguy Member
    Coastal,AL
    If you have a mig stick a non plated nut on the nub and center weld it. The heat does wonders for loosening the threads up. Good luck . I just went through the same thing (4) . Had to pull the head and get a machinest to do it. Those bolts have to be the sorryest steel ever made.
  3. mcrwt644
    mcrwt644 Member
    Winchester, VA
    Me? I'm taking it to the machine shop up the street that pulled my broken exhaust studs out. WELL worth the $25. I'm not messing with that, nope, that head/base is something you don't want to mess up. Unless you really know what you are doing, you are probably going to make it worse by trying to fix.
  4. streetbrawler750
    streetbrawler750 Member
    Minnesota
    I was taught to loosen stuck screws bolts etc, to tap (not to hard) with a good pliers, not a hammer, straight into the screw on the end of the tool you are using, if that makes sense, use a little pressure turning and they generally come out. Its the only way I could have gotten the p/u coil cover off and carb bowls without stripping the head of the screws, on my bike that had sat for 3 years.
  5. RickCoMatic
    The truly sad part about the Intake Manafold Cap Screws being of such poor quality and seizing in the Head; is that removing the Manifolds is a necessary Maintenance chore. You have to be able to remove the Manifolds at some time and face the dilemma of the seizure problem.
    If the Factory had treated the fasteners with anything to prevent the two metals from seizing ... life would be so much easier for the owners and those working on these bikes of ours.
    The problem is so common that those who don't find theirs seized or have some treated by an PO to prevent the trouble are the exception ... (it seems.)
  6. vintagerice
    vintagerice Member
    New Hampshire
    yeah still no progress... I may end up pulling the head... this blows.
    Rob
  7. wizard
    I am so scarred by the last experience, that on the latest 900 project, I havn't even attempted to remove them. :(
  8. streetmaster
    streetmaster Member
    Sorry about your luck dude, Yeah i got lucky that all the intake bolts came out nicely for me, though all the screws in my carb pack gave me a hard time, but got them out to.
    I plan on replacing every bolt and screw with stainless allen's. :idea:
  9. wizard
    Be sure to use anti-seize.
  10. vintagerice
    vintagerice Member
    New Hampshire
    yeah sure wish Yamaha used it.. Judging by the material on the others that came out almost looks like they used a thread loc on them. However it could just be age and rust.
    Rob
