Cables and Master Cylinder Questions - Bar Change
Discussion in 'XJ Technical Chat' started by Jmkrull, Oct 18, 2017.
  1. Jmkrull
    Jmkrull Member
    Minneapolis
    So, I mounted a set of Clubman bars upside down/inverted (basically dragbars with a little downward point and angle towards the rider) instead of the bullhorn ones on my XJ650. Couple of questions
    Master Cylinder needs to be changed I've heard to a "Flat Orientated" one. Does anyone know one in particular that would work? Does the brakeline have to be changed along with this?
    Right now, I have all the cables on there and they feel alright (Clutch, Throttle, Choke). Do I have to change these out? I found a decent way to route them and the wires don't bother me much. Moreso concerned if there's a safety issue here I'm just waiting for to happen.
    Thanks.
    as long as cables are not binding that should not be a problem. turn handle bars full left to right try them at all points for proper function.
  3. jayrodoh
    jayrodoh YimYam
    Cleveland
  4. Jmkrull
    Jmkrull Member
    Minneapolis
  5. Jmkrull
    Jmkrull Member
    Minneapolis
    Thank you!
