Can stuck clutch cause high idle?
Discussion in 'XJ Technical Chat' started by saftie, Oct 28, 2015.
  1. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Here they call it Blue Planet fuel. The stuff loaded with ethanol and is oxygenated. It attracts moisture like crazy.
    I got the Allen head bowl screws from Chacal and with tee handle Allen wrench it takes less than a minute to drain my carbs.
  2. Polock
    you could just drain the gas and put a few gallons of kerosene in it
  3. SQLGuy
    SQLGuy Well-Known Member
  4. quebecois59
    I was told that some stations sell ethanol-free, and yes, they are hard to find around here. But the question was: for short storage (6 months or so), how better could it be to fill the tank and carb bowls with ethanol-free gasoline, if available?
  5. BigT
    BigT Active Member
    Airville, Pa
    If it's available locally I would use it for storage along with some stabilizer, but I wouldn't go out of my way to get it. They do have fuel stabilizer that is supposed to counteract the effects of Ethanol, that's what I use along with starting the bike once a month or so.
  6. SQLGuy
    From the horror stories out there it sounds like you could easily make your own:
    1. buy some E10
    2. let it set for two months (maybe longer if you're in a dry environment)
    3. siphon off the top 80% or so, which should be pure gasoline, while the bottom 10% should be the phase-separated ethanol/water mix
  7. quebecois59
    Well, well, it would be simpler to use kerosene as suggested by Polock.
  8. Alan63
    Alan63 Active Member
    Saskatoon,sask. Canada
    Check with where you buy your fuel,
    Wher I get my fuel reg can be 15 percent ethanol , premium is 0 percent and mid grade is 10
  9. Polock
    around here the pump says UP TO 10%.
    i think if you follow the money as the price of ethanol goes up, the % goes down. Someone at the refinery knows the real % but i doubt the guy at the gas station knows.
