Can you identify these OEM Connectors or where to find some?
Discussion in 'XJ Modifications' started by Dr. Awesome, Feb 12, 2017.
  1. Dr. Awesome
    Dr. Awesome New Member
    MN
    I have been working through electrical stuff on the bike and I am building all new wiring harnesses, but I can't find these style connectors anywhere! I have gotten the other kinds, but these don't show up, does anyone know where I can get them or some keywords that might lead me there? These ones are used on the handlebar controls. I can completely replace them with other ones I have, but would like to tie in if I can. Any help would be great, thanks!
  2. hogfiddles
  3. chacal
    Unfortunately, we DON'T have that style connector (one of the few that we do not have). About the only solution is to replace those with the more commonly available "flat blade" style terminals and shells.
  5. Dr. Awesome
    MN
    Tried a few places, cycleterminal was great for my other connectors, looks like I'll be changing them out. Thanks guys!
  6. hogfiddles
    Radio shack
  7. Toomanybikes
    Tsawwassen bc
    Are the plastic blocks ok ,or just bad internal connections
    The socket and pin metal connector can be replaced.
    There are spring tabs that hold them in place
  8. hogfiddles
    Try some of these addresses, too--- it's a picture, so don't bother trying to click on them
    Toomanybikes likes this.
  9. Toomanybikes
    Tsawwassen bc
    I have that kit from my Honda days
    Very good setup made by Hitachi
  10. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Hey, then the connectors would match the carbs!
  11. hogfiddles
    Maybe you could connect the carbs together----
  12. k-moe
    Electric carburetors....ugh...never again.
    hogfiddles likes this.
  13. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    Radio Shack sells cell phones now. They aren't the Shack I remember.
  14. k-moe
    My local (before they were dropped) carrries components, including molex pins.
    The Shack that I remember isn't much better than what's been around for the past ten years. That might have something to do with having access to the Tectronix Country Store when I was growing up. RS was to Tec as Kroger is to Home Depot.
  15. Timbox
  16. MattiThundrrr
    They don't even call it Radio Shack around here anymore, it's The Source. More like a Best Buy than anything. More appliances and gadgets than parts for electronics.
  17. Polock
    why would you want to put the original type connectors back on when modern waterproof ones are so much better?
    you can make it original or better than original, i won't tell anybody.
    those connectors are a headache for a lot of people, one of the first things to check on a old bike
  18. hogfiddles
    I have no problem with the idea of replacing with new bones of the same type.... if they last for 35 years again, I'll be in my upper 80's by then----
  19. saftie
    New York, NY
    I bought a set on vintage connections but the connectors are huge. A six pin connector is at least an inch wide and doesn't look great and takes up a lot of space.
  20. Yu Tanaka
    Yu Tanaka Active Member
    Shizuoka, Japan
    Dr. Awesome and k-moe like this.
  21. Dr. Awesome
    MN
    Awesome, thanks a bunch!
  22. MattiThundrrr
