carb bowl gasket cement
Discussion in 'XJ Technical Chat' started by XJ550H, Jun 17, 2018.
  1. XJ550H
    I have never had to replace the carb to bowl gasket in my several cleaning rebuilds, but now I have a set of carbs that need gaskets.
    I have black fuel/oil resistant RTV, Indian Shellac , and red spray high tac.
    what sealer/cement is best to use?
    can I use the Indian shellac ? it is my go to gasket cement in auto applications.
    what do you use?
    I just use new gaskets. You can cut one from a cereal box if need be.
    Chitwood and Polock like this.
  3. Polock
    i lay a sheet of 1000 flat on the table saw and make a few figure 8's lightly to check for high or low spots then put it on dry, seems to work for me
    Chitwood and k-moe like this.
  4. Jetfixer
    I use rtv and glue gasket to the bowl , and light smear of grease on the matting surface to carb body . Makes it easy to pull bowl and does not stick gasket ,so it won't tear gasket.
  5. XJ550H
    ok because I am asking about gasket sealant. I have gaskets.
  6. mlew
    mlew Well-Known Member
    Apex, NC
    Be a
    Be aware that gasoline will soften or dissolve most silicone sealants.
    Just make sure the carb and bowl are clean and the gasket will seal just fine. The carb bodied have a small ridge built in that helps sealing against the carb bowl.
    If you are worried about the gasket sticking apply a thin smear of grease . They will come apart easy the next time.
    Jetfixer, Chitwood and k-moe like this.
  7. k-moe
    Tha gaskets are meant to be put on without any sealant or dressing. As mentioned, a thin smear of grease on one side is fine.
    TheCrazyGnat and XJ550H like this.
  8. TheCrazyGnat
    Central PA
    May or may not be applicable to your situation, but I get the high quality aftermarket ones from Len and I never have to put anything on them.
