Carb confusion IDK
Discussion in 'XJ Technical Chat' started by Joe34, May 28, 2021.
  1. Joe34
    Joe34 Active Member
    Halifax nova scotia
    So tore down more carbs after they been sitting around for ever. Did a through cleaning.
    I Put new dyna coils on new wires, because I though the coils was the issue. So the carbs are on, everything is synchronized, wet sync as well. All good.
    One thing new that's happening is, when I prime it has comes out the overflow on 3 and 4.
    Bike idles fine takes gas great in neutral but taking off in first has a small hesitation. After I'm on the gas it's fine, tons of pull.
    Checked plugs 1,2 and 3 are a nice tan, number 4 is black chalk.
    Compression is good all across. When I mess with the pilot mixture it seems to do nothing on where I set it. On the number 4
    Also has an amazing spark but when it's running and I pull number 4 wire off plug there's no change. The rest does change.
    I'm lost. Been at it for days, any advice and knowledge would be great thank you.
  2. StahlMaster
    StahlMaster Active Member
    Southgate, Michigan
    Swap the plug and see if the issue follows?
  3. Joe34
    Joe34 Active Member
    Halifax nova scotia
    Yep did the same, also tried multiple TCI's
  4. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Stuck float needle on carb 4 also?
  5. Joe34
    Joe34 Active Member
    Halifax nova scotia
    Checked float seems fine. Never checked needle but never touched it also.
  6. k-moe
  7. Huntchuks
    East Rochester, NY
    This seems to indicate float needle(s) stuck open.
  8. Joe34
    Joe34 Active Member
    Halifax nova scotia
    Yes wet set is on par. And I did reuse them, the rack was a full rebuild I did few years ago.
  9. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    If gas is flowing out on Prime it would seem to me to indicate a needle valve not sealing. When I wet set mine I let them sit for about an hour and moved them around a little bit. They didn't leak at first but over time they did. Did that several times with the same results. Replaced my rubber tip needles and seats with solid brass needles and seats (from Chacal) and that solved my problem.
    k-moe, Jetfixer and Joe34 like this.
  10. Jetfixer
    Did you look at the tip of the needle if it has a groove and is stiff , this can cause issues like not shutting off fuel flow when engine shut off and fuel left on PRI . I just went through a carb problem with my JCB ...If you have the carbs off check slides , I had one that would not go up all the way , and another that dropped with no resistance, yes bike ran fine at idle , but you had to stay on throttle and felt like it was running on three cylinders. Fixed it with another slide and one slide was not fully in the groove , now bike runs great .
  11. Joe34
    Joe34 Active Member
    Halifax nova scotia
    Just found out the if I take the little sync plug cap off of intake boot almost instantly comes out of its issue.
  12. Joe34
    Joe34 Active Member
    Halifax nova scotia
    Took off carb checked floats and needles. Still doing same thing. Unless I take this cap off the intake boot it runs better. Makes no sence
  13. Jetfixer
    Did you do a clunck test on the slides? Pull them up fully see if the slide drops fast or drops slowly...slowly is what you want.
  14. Joe34
    Joe34 Active Member
    Halifax nova scotia
    They all drop evenly at a slow pace
    Jetfixer likes this.
  15. k-moe
    Which carb?
    Removing that plug leans out the mixture.
    It seems to me that if it's the same carb that gives you a black sooty plug, then that carb is setup to be too rich.
    Did you do anything to the idle mixture screws?
  16. Joe34
    Joe34 Active Member
    Halifax nova scotia
    Carb 4 every time. I'm confused because that carb is set up the exact same as the other 3. I can turn the idle mixture screw all the way In. Small difference, all the way out no difference.
    Same wet set for floats, same dry measurements. Even running sync is straight across the bord with my carb tune.
    Only thing I can think of is that the wrong pilot jet is in.
  17. k-moe
    Check the air jets first.
  18. ManBot13
    ManBot13 Well-Known Member
    Fairfax, VA
    You are just letting in a bunch of air, which makes it run better because it burns some of the fuel that is flooding #4. This is not a solution.
    All four carbs are not “set up” the same if #4 flat bowl is overflowing. Fix one problem at a time, and the first problem is there. Messing with mixtures or sync down stream won’t get it running right, you’re just covering up the problem. And you’ll need to redo all of that once you fix the float/needle.
  19. Joe34
    Joe34 Active Member
    Halifax nova scotia
    It's not overflowing now on prime as I fixed the float needle.
    Still not getting enough air.
  20. Joe34
    Joe34 Active Member
    Halifax nova scotia
    And also does the pilot jets have two different sizes with same size number stamped ??
  21. Joe34
    Joe34 Active Member
    Halifax nova scotia
    Thanks for the help everyone. It's all fixed running well adjusted float a little bit and changed out pilot jet that looked concerning it was one of the other or combination of both. But she's all tuned working like a top glad to have her back and running it's been 3 years
    Jetfixer and Huntchuks like this.
