Carb diaphragm replacement
Discussion in 'XJ Technical Chat' started by wcd, Aug 7, 2018.
  1. wcd
    wcd New Member
    Canada
    Alrighty folks, here's the sitch. I ordered some carburetor slide diaphragms for my '82 750 Maxim. I have a small tear in one of em and the other ones are surely original. I figure I would just replace all 4 in one go. One of my cinch rings is split and I think I maaay see a crack starting in another one.
    It seems to me like the cinch rings are pressed on though and they do not seem serviceable at all...
    Is there a way to replace the diaphragms and now that I've noticed the split in the cinch rings, I guess I would ideally be looking to replace that too.
    Thanks,
    Cole
  2. hogfiddles
    There is a company that is making diaphragms,
    I can't remember the name.... maybe BT-sonething or other, but someone here will know. I've seen some of them, I'm not to keen on them yet.
  3. turpentyne
    turpentyne Active Member
    Desert SW
    There's this place, but I have no idea how good they are: http://jbmindustries.com/HITACHI.html
    I've heard of issues with just replacing the diaphram, so I patched with Chacal's RnR Fluid and I'm saving my money for a day I can buy the whole diaphram and piston assembly.
    But I just had pinholes. Not sure about small tears.
  4. hogfiddles
    Yup.....that's the one....
  5. Toomanybikes
    Tsawwassen bc
    Have installed a couple of sets and very happy with the results.
    They do not have an index bump on the outside, so care must be taken when installing them with orientation of the slide so the air holes in bottom are towards the engine.
    Stumplifter likes this.
  6. turpentyne
    Desert SW
    I've been curious about the longevity of them, compared to originals. Your thoughts, @Toomanybikes ?
  7. kerriskandiesinc
    NY
    NRP-Carbs.co.uk does them too....in the Uk, obviously, he sourced them from longer lasting rubber ( ask me how I know) the cinch rings can be removed but it's NOT easy !!
  8. Jetfixer
    You can repair them with a latex condom or glove cut a patch rubber cement or light RTV , when I had my Virago , on the forum seen posters that stated this trick worked great .
  9. hogfiddles
    You can do a lot with those....
    Colin 85 700 likes this.
  10. Colin 85 700
    Colin 85 700 Active Member
    Thunder Bay, ON
    Thats why i got the saddlebags... Gotta store all those thing somewhere ;)
  11. chacal
    I can sense Matti hovering somewhere close by, any minute now...........
  12. turpentyne
    Desert SW
    oh... are we waiting for an odd comment on rubbers and diaphragms? I know I’ve been fighting the urge all day! :)
  13. Toomanybikes
    Tsawwassen bc
    What ! A saddle bag full of condoms... you do get around
  14. mr blackstock
    mr blackstock New Member
    Victoria, Australia
    On the subject of the jbm diaphragms, I've had them in my fj1100 and xj650 for over 5 years and they work without fault.
    The jbm site offers all the info you need, best money you'll ever spend
  15. wcd
    wcd New Member
    Canada
    Thanks a bunch folks.
    I'll try the patch-job for now and see how that treats me. If it doesnt work out then its great to know there are alternative!
    Cheers
  16. Toomanybikes
    Tsawwassen bc
    Cole where in Canada are you ? I have a few sets of carbs that have been cannibalized for spare bits and I probably have a couple of slides that are good.
  17. wcd
    wcd New Member
    Canada
    I'm near High Level, northern Alberta, right now. If these fixes don't end up working for me then replacing the whole slide looks like it'll be the way to go.
    What would you be wanting to get for them?
  18. Toomanybikes
    Tsawwassen bc
    Are they all bad? May be easier to set you up with a complete set of good carbs
  19. Toomanybikes
    Tsawwassen bc
    Have a set that has been “done” including jbm diaphragms, throttle shaft seals. Full tear down. Just plug and play for your bike.
    82,83 XJ750 Maxim Canadian spec.
  20. Toomanybikes
    Tsawwassen bc
    Have a look at Toomanybikes on Facebook to see what I do for xj owners.
  21. wcd
    wcd New Member
    Canada
    They aren't all bad, just one of them has the hole in it, but I was going to replace all 4 just for the helluvit. That was until I realized they werent really serviceable.
    I'd like to keep the parts original to the bike if I can (its a bit of a sentimental bike). So I'll see what I can do to make these ones work first. But if not, I would LOVE to finally be able to get some parts from and work with other Canadians. (No offence meant to anyways else!! Its just always nice to work and support local ya know??)
    Toomanybikes likes this.
  22. turpentyne
    Desert SW
    Toomanybikes is in Canada.
  23. Toomanybikes
    Tsawwassen bc
    I’m 1 province west of @wcd
  24. wcd
    wcd New Member
    Canada
    Yeah, exactly! That's why I would love to take Toomanybikes up on his offer if need be. There are certainly other great people to deal with on this forum, but it would be nice to develop a bit of a network up here!
  25. wcd
    wcd New Member
    Canada
    Do you folks know if the diaphragm replacements that @chacal sells are of the same style as the JBM ones mentioned earlier? I hadnt actually opened up the bag and looked at them properly since I got them (I know... shame on me!) but they seem like they might be designed to fit into that slot like the JBMindustries ones do. I don't wanna cut my cinch rings off on the ones I already have to compare, cause then I'd be hooped if they were the wrong ones...
  26. chacal
    Yes they are!
  27. wcd
    wcd New Member
    Canada
    Awesome!! Haha you know about the problems I'm gunna run into before I even do! Thanks a ton Len!
  28. Noah Holbert
    Noah Holbert New Member
    I had a question I'm new to the forum and wasnt sure where to ask, I have an 83 xj 750 and it runs good idles good but it's only running on 3 cylinders the dead cylinder has spark it has fuel in the bowl but wont run, i know there is a hole in the diaphram from when i was cleaning the carbs would a hole in the diaphram cause a cylinder to get no fuel? If I spray starting fluid in the dead cylinder it fires right up.
  29. Jetfixer
    A small hole in the diaphram can be repaired with of all things a condom cut a piece about a 1/4 inch around hole , apply rubber cement to diaphram and put piece of rubber in place , place another small amount over patch let it set up and should be good to go. This was off the Virago forum it does work .
    Noah Holbert likes this.
  30. Noah Holbert
    Thanks for the reply I went ahead and bought a new one, the carb is getting fuel to the bowl but the one cylinder wont run? All three other cylinders run good but the one wont, it has spark and runs on starting fluid. Not sure where to go from here the carb has fuel in the bowl but wont run on that one cylinder
  31. Toomanybikes
    Tsawwassen bc
    Compression test
    Valve clearance.
    hogfiddles likes this.
  32. fossilbike
    fossilbike Member
    converse tx
    put patch on inside of diaphr or outside?
  33. hogfiddles
    I patch them on the TOP surface
    (Spring side)
    Timbox likes this.
