carb sync..??
Discussion in 'XJ Technical Chat' started by xj_crazy, Apr 24, 2009.
  1. xj_crazy
    xj_crazy Member
    is it possiable to sync my carbs one at a time???
  2. greggvickrey
    greggvickrey Member
    Smyrna, Tn
    Yes, look in the FAQ forum section for Rick-o-matics old school carb synch. It tells you haw to do it, make the gauge, etc.
    Gregg
  3. TIMEtoRIDE
    Well sorta, but no, all carbs are sync-ed to #3 while running.
    Unless you're talking about a bench sync, which adjusts each buterfly to a specific setting, done one at a time.
    Afterwards you always do a running sync. Doing all 4 at the same time. Or two at a time, depending on the technique. Or one at a time, using the one gauge technique.
  4. RickCoMatic
    Before Gang Nanometers were invented; you HAD to use ONE Gauge.
    I learned how to do it from a Tech who used a Yellow China Marker to Mark the face of the Vacuum Gauge.
    The MOST Important factor for doing a ONE GAUGE SYNC is:
    You MUST fabricate and use a VACUUM LINE RESTRICTOR!
    Otherwise the Needle on the Vacuum Gauge is going to be fluctuating so wildly it will be useless.
    Get a "Union" used to join to sections of hose together.
    Stick a Carb Cleaner Red Tube through it.
    Fill the Union with Epoxy.
    When the Epoxy dries ... Cut off the ends leaving the Restrictor you need.
    Restrictor:
  5. ktcubed
    ktcubed Member
    St. Augustine, FL
    Rickomatic, You getting attacked by some really small "homies" lately?
  6. xj_crazy
    xj_crazy Member
    i think im goning to make the 2 boddle sync tool and give it a try
  7. Thee_oddball
    Thee_oddball Member
