Carbs questions...
Discussion in 'XJ Technical Chat' started by Rod1, Dec 27, 2017.
  1. Rod1
    Rod1 Member
    San Luis, Argentina
    Hi guys...bike been running great since I fixed the light on the valves...but now I need to find a good carburation kit to replace the factory (I guess) since in the really hot days and between 1000 and 2500 rpm the bike start to "studder" and she is way rich on gas. So question here are: 1- how do I know what carbs are on the bike since the carbs does not have any name print on them? And 2- Carburation kits from a xj 750 or other c.c. will fit ? Mine is a xj700 1985. Thanks...
  2. Toomanybikes
    Tsawwassen bc
    Should have small logo on the side like this one in photo is Hitachi
  3. Rod1
    Rod1 Member
    San Luis, Argentina
    Hi toomanybikes...ok, yes these are hitachi...
  4. Toomanybikes
    Tsawwassen bc
    90 % of these carbs are identical, one exception is some have fine threat mixture screws and of course different jets and vacuum pistons and needles are slightly different. The best way is have Len @xj4Ever get you the correct parts the first time and in truth will save you money by not buying more than you need to end up with the right parts
  5. Rod1
    Rod1 Member
    San Luis, Argentina
    Things is I dont know what I need that is why my option for the kit. Second, I live in Argentina I can get the kit wich is usually offered for maxim 750, but if Len send it to me chances are that is going to get lost in custom upon arrival.
  6. chacal
    ???? This has never happened before, has it?
  7. k-moe
    In Argentina, in general, yes. Anything coming into Latin America from the U.S. is high on the list for being pilferd.
  8. hogfiddles
    Send it somewhere else, first, then.......
  9. Rod1
    Rod1 Member
    San Luis, Argentina
    Happened to a couple of friends and not to others...that why I asked if rhe maxim 750cc carries the same kit as the 700cc since I can get the 750 kit here...someone knows??
  10. hogfiddles
    If the 750 kit is available there, why isn't the 700 kit available there?
    The two are very close, but the 700 kit has extra o-rings for the overflow T's. Len can tell you more particulars
    Dfox
  11. Rod1
    Rod1 Member
    San Luis, Argentina
    Thanks...
  12. Rod1
    Rod1 Member
    San Luis, Argentina
    Is this what I need??
  13. hogfiddles
    If it's not OEM, or it's not from Len, I WOULD NOT BUY IT,OR TRUST THAT SET FOR ANYTHING I REBUILD.
    I've had too many racks come in that have had sets like that put in... while they LOOK good, the numbers match, etc...they don't work. Put correct parts in and they work perfectly.
  14. Rod1
    Rod1 Member
    San Luis, Argentina
    Things is I dont know exactly what parts I need to rebuilt...I know a little about carbs and the more I read the more confuse I am...
  15. Rod1
    Rod1 Member
    San Luis, Argentina
    Even reading the church of clean...!!
  16. hogfiddles
    Get the complete kit-- I recommend the deluxe kit. Everything you'll need is in it.
    Stumplifter likes this.
  17. Rod1
    Rod1 Member
    San Luis, Argentina
    Yes, about that I started a conversation with Chacal, awaiting an answer with prices, parts, and shipement methods. Thanks you
