Carburetor Cover & Special Screw
Discussion in 'XJ Technical Chat' started by MechE, Apr 18, 2018.
  1. MechE
    MechE New Member
    Edwardsville, IL
    I was curious how important the "Cover" (#13) is that is screwed into the carb body over the main and pilot air jets. I have a rack of carbs and only one of the carbs has a threaded slot for the "special screw" (#14) that holds the cover on.
    I'm assuming that the cover helps to provide non-turbulent air and therefore better airflow into the air jets. However, three of my carbs have the hole drilled out for the cover "special screw", but they aren't threaded.
    My 1980 650 had the covers over the air jets.
    Thanks,
    Blake
  2. Polock
    Thomer69 and Nic like this.
  3. MechE
    MechE New Member
    Edwardsville, IL
