Carburetor Vacuum Diaphragm
Discussion in 'XJ Technical Chat' started by Andy Dobkins, Mar 20, 2021.
  1. Andy Dobkins
    Andy Dobkins Member
    Lonedell Mo
    Got a question I have seen on Amazon ,Ebay and a few other sites .Like this
    labwork Pack of 4 Carburetor Vacuum Membrane Diaphragm and wondering if any one has used them looks like all of them go on the same way. Even from JBM Industries I cant see any difference . Through I would
    ask and see what has been used
    jbm are a suitable substitute.
    you can go direct to their web site he is starting to list what fits xj's
    Franz and k-moe like this.
  3. k-moe
    The differences that you can't see will be what matters. I've not used them, but what rubber is used matters a lot. The JBM diaphrams are known to work.
    Andy Dobkins and Franz like this.
  4. XJ550H
    our supporting vender sells oem and aftermarket diaphrams too.
    Andy Dobkins, Jetfixer and k-moe like this.
  5. XJ550H
    this does concern me for the ;abwork
    Item model number XJ550 XJ650
    Manufacturer Part Number XJ550 XJ650
    I will check in morning if a 550 and 650 will swap I dont think thay are the same size.
  6. Andy Dobkins
    Andy Dobkins Member
    Lonedell Mo
    Was just trying to save a few on a fixed income. 1 had a hole in it fixed it last year but noticed engine not running right pulled carbs off and the liquid tape came off need to replace shaft seals so was going to strip down break rack and now that I got an Ultrasonic cleaned an a cheap soda blaster I could do a good job on rebuilding them. right now 100 bucks is a lot.
  7. Andy Dobkins
    Andy Dobkins Member
    Lonedell Mo
    this is a air cold xj 700n maxim with Hitachi HSC33
    XJ550H likes this.
  8. chacal
    They are absolutely NOT the same size nor fit!
    Simmy likes this.
  9. XJ550H
    i did not think they were thanks for the reply.
  10. XJ550H
    you should add your bike to your signiture line thanks for the clarification
  11. Jetfixer
    There is a way to repair small holes in diaphragms, don't laugh a trojan condom cut a piece slightly larger than hole overlap by an inch all around , use rubber contact cement apply on both diaphragms and patch put it in place and let it set up for an hour or so you could also put a patch on the opposite side of hole as well . I once had an 82 Virago and was on the Vrago forum and this was a tip I picked up , several members said this worked for them , definitely cheaper than buying a new diaphragm.
    Franz and Andy Dobkins like this.
  12. a100man
    a100man Well-Known Member
    Bedford, UK
    I hesitate to ask but what's a 'trojan' condom?
  13. Jake750
    Jake750 Member
    Detroit
    Just a popular brand of condom in the US. I dont think there's anything special about the material compared to other brands.
  14. Franz
    Just don't say they are for carburettors :D
  15. a100man
    Bedford, UK
    Phew. Not just for use by ancient Greek warriors then?
  16. XJ550H
    my concern is they are latex and do not play well with petroleum products.......
  17. Andy Dobkins
    Andy Dobkins Member
    Lonedell Mo
    If I use a trojan condom cut a piece of and use it on my bike going to start howl going down the road ? Or get all horny at the next bike that goes by and do wheelies just asking to be ready?
  18. XJ550H
    I had 1 bike in the garage then 2 and all of a sudden it jumped up to 10 should have gone the trojan route.....:eek:
    Andy Dobkins likes this.
  19. a100man
    Bedford, UK
    I'm afraid that prompts more questions than answers - an Otter??
    On second thoughts I think I prefer to remain in ignorance
    XJ550H and Andy Dobkins like this.
  20. JCH
    JCH Active Member
    seattle wash
    What symptom's do you notice when you have a torn diaphragm ?
  21. Simmy
    wife or GF will develop a large belly.
    Seriously, the carb throttle slide will not rise with your right wrist as it needs the vacuum to open.
    Bike will stutter on that cylinder that is torn.
  22. JCH
    JCH Active Member
    seattle wash
    Thank you otherwise run lean on that cylinder.
  23. Jake750
    Jake750 Member
    Detroit
    Difficulty breathing and severe chest pain.
    Simmy likes this.
  24. Andy Dobkins
    Andy Dobkins Member
    Lonedell Mo
    that carb with the bad diaphragm leans out at higher rpm like 3000 + starts cutting out .
    Jetfixer likes this.
