Carburetors xj750 question
Discussion in 'XJ Technical Chat' started by Codysc843, Mar 20, 2020.
  1. Timbox
    Timbox Well-Known Member
    [​IMG]carbs_floatbowl_choke by Tim Brown, on Flickr
    Looks something like this, if that little hole is not leaned out bike will not run right. I use a thin stiff wire and compressed air. A bread tie with the insulation stripped off of it works well.
  2. Codysc843
    Codysc843 Member
    Sc
    Anybody got a video on how to rebuild these specific carburetors for 82 xj750? These pos carbs got me burning my starter up
  3. Timbox
    https://www.xjbikes.com/forums/threads/in-the-church-of-clean.14692/
    That is the church of clean the best I can do for you. Once you get the operation of the carbs down, they are all more or less the same. The throttle body seals and fuel O rings will give you the most hassle. Getting all the jets our and all the little springs, O rings and little washers is also a little challenging. Once the carbs are good, then check the valve specs. With both those being in tune and good compression the bike should start right up. My 700x did.
  4. XJ550H
    Timbox likes this.
